I need a 75 to 75 ohm balun antenna matching transformer.
12 Last »
  1. #1
    gary350 gary350 is offline
    I can not find anything but 300 to 75 ohm balun antenna matching transformers at Radio Shack or any other place in town.
    I found instruction how to make a 1 to 1 balun but there are no details on the, number of turns, wire size, or ferrite donut.??????????
    I have several ferrite donuts, small, medium and large. Picture in Amateur Radio Handbook looks like 8 turns of enamel coated copper wire but picture online shows about 20 turns of insulated house wire. I need LOW LOSS for a 16 element collinear array TV antenna for my HDTV.
    I could buy a balun if I could find one at a reasonable price. I don't think $15 plus $10 postage is a good deal.
    My antenna is a 16 element collinear array 75 ohms with a 75 ohm coax cable to the HDTV. Frequency range is 180 to 692 MHz.
  2. #2
    crutschow crutschow is offline
    75-75 ohm baluns are not common since you seldom find a balanced 75 ohm source. What do you need this balun for? Most antennas are 300 ohms balanced.
    0
    Zapper
    Curmudgeon Elektroniker
    --Inside every little problem is a big problem trying to get out.--
  3. #3
    MikeMl MikeMl is offline
    If you are connecting a 75Ω spigot on the antenna, to 75Ω coax, why do you need a balun? Do you want DC isolation; i.e. a two-winding transformer?
    0
    Mike ML.
  4. Thread Starter #4
    Balun stops some unwanted stuff, static, ghost. etc. I have a 16 element collinear array antenna it is 75 ohms. I am using 75 ohm coax to my HDTV. It is working fine without a balun I just want to try it with a balun to see if it makes it any better.
    0
  5. #5
    kchriste kchriste is offline
    Try 2 back to back 300-75Ω baluns first. They used to be pretty common. Maybe some of your buddies have some laying around.
    You could also try a coaxial balun, but they are relatively narrow bandwidth so it would be to trial on one or two channels only.
    0
  6. #6
    Quote Originally Posted by gary350 View Post
    Since HD is digital, if it's working fine then you can't do any better. You said a balun stops static, ghost, etc. (which I don't see how. All it will likely do is reduce the signal amplitude) but you apparently don't have any of that. Seems like a waste of effort.
    0
    Zapper
  7. Thread Starter #7
    You are right it will reduce the signal a little. I read ferrite type baluns are only 90% efficient. I have a 300 to 75 ohm balun that I tried I can't tell it make any difference signal seems to be the same.
    I made some changes again to my antenna today. I re scanned and now I can receive 8 more stations. One station is channel 7 Knoxville TN that is 120 miles away. That totally freaks me out I can pick up Knoxville it has been coming in pretty good 70% strength all evening. I watched a 2 hour movie on channel 7.2.
    0
  8. #8
    Space Varmint Space Varmint is offline
    Oh, this is a receiving antenna. Well then the enameled wire is fine. You can use the smallest ferrite core you have also.
    0
  9. #9
    unclejed613 unclejed613 is offline
    try 3-5 turns of twisted pair on the smallest ferrite donut you have. one wire is the primary, the other wire is the secondary. since it's twisted pair, and it's on a ferrite donut the coupling coefficient is very close to 1.
    0
    E=mc˛ (+/-1dB)
    "If a curl of smoke is seen, the technician will soon experience the cause of difficulty"........ CTX arcade game monitor service manual 1985
    DC-to-Daylight Blog (on this forum):
    http://www.electro-tech-online.com/blogs/unclejed613/
    Vintage Audio and Pro-Audio Repair, ampz(nospam-removethis)@sohonet.net
    fight spam: http://www.robietherobot.com/spamfight.htm
    http://www.spamhelp.org/harvesterkiller/
  10. #10
    Quote Originally Posted by unclejed613 View Post
    I like your slogan UncleJed. Also don't you have to put the smoke back in to fix it? I know I've had allot of capacitors that went bad when the smoke leaked out
    0
12 Last »
Board Mountable Video Isolation Transformer / Coupled Inductor / Balun Mikey0727 Datasheets, Manuals or Parts 3 7th August 2009, 08:46 AM
How do you tell if an antenna BalUn is bad? blueroomelectronics Repairing Electronics 11 16th June 2009, 08:35 AM
600:600 ohm center tapped line matching transformer dramrattan Datasheets, Manuals or Parts 4 30th January 2009, 01:26 AM
why must the matching impedance be 50 ohm fstspec General Electronics Chat 18 14th October 2008, 08:38 AM
Antenna matching Vaibhav Birit General Electronics Chat 3 20th September 2004, 11:35 AM
Page Time: 0.12282 seconds      Memory: 7,715 KB      Queries: 16      Templates: 0
