| I was trying to measure roughly 100K resistance on my digital meter. On the 2meg range it came up as .100 I then changed the range to 200k, but the reading was 50 I repeated the above measurement on another meter and got roughly the same values. I'm wondering if flat batteries cause wrong readings. I took one of the battries out of its meter ,and measured its voltage.It is reading above 9volts. Are analog meters more reliable? | |
| Thats kinda odd, the first thing I always do if I doubt my readings is test the resistance of the probes Im using. Shouldnt read more then an ohm when touched together, otherwise maybe a bad connection. | |
| Were you taking these readings with the circuit powered up? That'll produce some wierd readings, weak batteries can do the same. Jerran has a good point also, check the leads. I personally don't think analog meters are any more reliable than digital, (that'll start something) :twisted:
__________________ gerty | |
| If there is a transistor or diode in the circuit you are measuring. it would explain the strange readings. The apparent resistance of a semiconductor junction varies with the current in a non linear manner. | |
| You don't mention if the resistor is in circuit or not, you really need it out of circuit to test it reliably - you may well get different readings on different ranges if it's in circuit, as it could be affected by other components. | |
| As a hobbyist I find that I have to warm up, so to speak, when making measurements. I'll take a minute to measure some things that are more or less "known" to me - the voltage of a new battery, the resistance of some resistors, etc. With the scope I'll check to see if I can make sense of the calibration voltage then proceed with making measurements. That tests my skills as well as the integrity of probes and leads - possibly the instrument itself.
__________________ stevez | |
| Hi! It's stupid, but, did you test the resistor during it was in your finger? Body resistance greatly modificate value. | |
| Thanks and Yes you were all right. The resistor(pot) was on a circuit, but not powered up. The third leg of pot is not connected to anything. Yes there are transitors and diodes in my circuit , but not in line with the pot and multimeter. I have from time to time tested high ohm resistor with my fingers :? , but not this time. | |
| | (permalink) | ||
| Thanks Nigel. | |
| I had something similar happen when one of the two fuses in my multimeter got toasted. | |
| I have the same prob in my digital multimeter , already changed fuse and battery but the problem remains . The resistors arenīt connected , the probes are OK ! Any clue ? Thanks ! | |
| The things that I might do would relate to verifying that the DVM is functioning properly. I'd check the voltage of some good batteries to see if the readings are reasonable. Check some other resistors - some low and some higher. I've had several of the lower cost DVMs fail because of the range/function switch. There was little that I could do about it on those models.
| Get a fluke :!: | |
