| hello! | |
| That's a good place to start learning about TTL. Do it in stages. Get the breadboard, 5V power source and make 1Hz clock signal (to start with experimenting, you can use 555 chip or whatever). The stuff you learn by experimenting is great basis for future projects so don't hesitate.Download datasheets for your chips (just search the web using Google or whatever you like). They often show sample diagrams. Your counter chip is presetable so try to use this feature. For example, put dip switches from +5V to preset inputs and resistors from preset inputs to 0V. When you pull pin 11 down (load input ius inverted what can be seen by line over word LOAD) the binary combination that is at the preset inputs is loaded to counter. LOAD input can be momentary button wired from pin 11 to 0V (GND) and maybe a pullup resistor (1k from pin 11 to +5V for example). You should see the same state on the outputs so when you bring the clock signal to the inputs UP or DOWN, counter will count from this number. Clear (CLR) does the same job but it always loads value 0 (resets all outputs). Note that CLR input is not inverted (no line over CLR signal name). This means to issue CLR signal, you have to bring "1" to pin14 and to issue LOAD you have bring "0" to pin11. And don't forget to bring counter ouputs (pins 7,6,2 and 3 of your counter should go to pins 6,2,1 and 7 of decoder chip) to inputs of the decoder chip. Make sure that decoder is enabled and display is not blanked so you can see your circuit counting. To do so, you have to pull some of the 7447 inputs high or low. The easiest way to find out how this works is like described - use dipswitches and pull down (or pullup) resistors so you can toggle the state of inputs like LT, RBI etc. Happy experimenting... | |
| Don't waste your time with TTL, start lerning about CMOS, is better than TTL, easier to use, faster in HC version, low power, and so on... | |
| who cares if it is TTL or cmos, just do it! Note: although i would recommend TTL over CMOS purely because they are so annoying when you turn the circuit on only to find out that they have been fried thanks to static electricity...that is a trade off for low power though.
__________________ www.winpicprog.co.uk - Great PIC language tutorials. | |
| 40-series CMOS are very well protected against static electricity. In fact, I dont give them any special treatment and yet I never had a defective one due to static electricity ... I'm not saying it can't happen, just that is rare... | |
| Hi there, I think I can help U with the 7 segments display here R 2 pdfs which may help U I found them on the net | |
aurosunil | ||
aurosunil | ||
| those are common parts. just google for datasheets... | |
| Hello there! Im trying to make the clock count down using minutes and seconds but it seems there something wrong with the circuit. Im using 4 74Ls192, 4 7447 decoder and 7 segment display. I connected the pin 4 to pin 13 of the 192 and the pin 4 of the last 74192 to the clock. The minute counter would show up to 15 and not 9. Also, how can I stop the clock if i set the minute to a value. Thanks | |
