are there different kinds of 8 lead PICs or are they all the same
There are many different kinds of PICs available in 8 pin packages.
straight answer, har har."
well im tryin to figure out which one this is. im tryin to modify an xbox controller and this guy shows you everything but he calls the chip a PIC and doesnt specify which one it is here is the web page i am looking at maybe somebody can tell me which PIC it is
Xbox 360 rapid fire controller! matrix instructions
Eccentric millionaire financed by 'er indoors
FWIW, you'd be better off just buying his mod kit, or anyone else's mod kit and proceeding to invalidate your warranty.....or perhaps not.
There are quite a few 8-pin PICs around and even if you could identify which one has been used, regardless of his attempts to scratch off any identifying marks, it's quite likely that the contents (program) will be code-protected.
A PIC is a microcontroller, which can be internally configured to perform certain functions, limited only by the hardware capabilites/number of IO lines available to that particular chip. Program code is used to configure the chip and tell it what to output in response to inputs on configured pins.
As Nigel says, without the actual code that the seller is using, simply buying the same chip is useless. Useless, because buying that chip would only give you a piece of plastic with 8 pins that does nothing until it is programmed.
HTH.
Unacceptable sig deleted - moderator.
Damn you Chippie!!!
It would be cheaper to buy an Xbox controller with rapid fire than it would be to modify one.
