+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 25
Thread: Problem understanding led's behavior
  1. #1
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    Default Problem understanding led's behavior
    Hello
    I have a problem understanding a led's behavior and generally some things about electricity.
    I have a led, I connect it to two AA batteries (2,4V) and it lights up. When I connect the same led to a COM port (6,4V - that is what I measured) it lights up again but not as brightly as before. Why is that?
    Tipsy Newbie
    Join Date
    Nov 2009
    Location
    South Coast UK
    Posts
    113
    Google "Ohms law", it will give a hint that Voltage isn't the only element that makes up electricity.
  3. #3
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    I did so but didn't understand what each one actually is ... that's why I came here.
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    After I googled "ohm's law" I got to this:
    Current is what flows on a wire or conductor like water flowing down a river. Current flows from negative to positive on the surface of a conductor. Current is measured in (A) amperes or amps.
    Voltage is the difference in electrical potential between two points in a circuit. It's the push or pressure behind current flow through a circuit, and is measured in (V) volts.
    So since I have just that led and I apply more "pressure" shouldn't it be brighter?
  5. #5
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,862
    The com port supplies less current than the battery. You measured the voltage of the com port when it was not loaded.
    You should never connect an LED directly to a battery without a series current-limiting resistor. If your AA cells were alkaline and were brand new then their voltage would be 3.2V and their current into the LED would be enough to burn out the LED.
  6. #6
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    Thanks for your reply.
    The thing is I measured the batteries without any load as well and that leaves me a bit confused again.
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,862
    Two AA alkaline batteries that have a total unloaded voltage of only 2.4V are dead.
    Since you didn't use a current-limiting resistor then you are lucky that the batteries had a high internal resistance.
    If the batteries were new then your LED would have burned out.
  8. #8
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    Mm ... I see. About the internal resistance, I found this:
    I = E / (r + R)
    So what exactly is E and how can I calculate it and the internal resistance?
    Thanks.
  9. #9
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    By the way, the batteries are rechargeable (Ni-MH).
  10. #10
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,013
    Quote Originally Posted by sakishrist View Post
    I = E / (r + R)
    Thanks.
    E stands for electromotive force and is the voltage (V).
    To measure the internal resistance of a battery, connect two different resistors, say 2Ω and 4Ω (R1 and R2), to the batteries and measure the voltage across the load for each load (V1 and V2). The internal resistance is then (V2-V1) ÷ (V1/R1 - V2/R2). The internal resistance equals the change in voltage divided by the change in current.
    Carl
    Curmudgeon Elektroniker
  11. #11
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,862
    Ni-MH cells (I wish you told us earlier) have a very low internal resistance. They can supply 5A or 10A of current. They are about 1.25V each at low current so two make 2.5V.
    You are lucky that your LED works on 2.5V because many red LEDs are 1.8V and the current in them at 2.5V is enough to melt them.
  12. #12
    sakishrist Newbie
    Join Date
    Nov 2009
    Posts
    9
    So, is it because of the internal resistance that the led does not light up that brightly?
    And you said: "the current at 2.5V"
    So what is practically the connection between Current and Voltage?
  13. #13
    QuietMan Newbie
    Join Date
    Nov 2009
    Location
    Dallas, TX
    Posts
    81
    V = i1* r1 .........
    "Good enough is enemy of the best." An old engineering saying, Author unknown.
  14. #14
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    sakishrist with semi conductors there is no practical connection it's VERY complex. V = I * R can be used to calculate the instantanious values in an active circuit but circuits do no respond like static loads to.
    straight answer, har har."
  15. #15
    QuietMan Newbie
    Join Date
    Nov 2009
    Location
    Dallas, TX
    Posts
    81
    I treat an LED like I would a zener diode, subtract its Vf and then use the remaining voltage with Ohm's Law.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. ACPL-782T problem understanding datasheet
    By raphraph in forum General Electronics Chat
    Latest: 25th November 2009, 01:48 PM
  2. Driving Multiple LED's - Problem
    By SpecialAgentBob in forum Micro Controllers
    Latest: 20th August 2009, 07:39 AM
  3. Problem understanding CDI circuit
    By Futterama in forum General Electronics Chat
    Latest: 25th June 2008, 07:13 AM
  4. Adding high brightness LED's...problem!
    By crunchy in forum General Electronics Chat
    Latest: 13th February 2007, 04:55 PM
  5. Help understanding behavior of Seven-Segment LED circuit.
    By DaKandEKid in forum General Electronics Chat
    Latest: 4th September 2004, 06:09 AM
Tags for this Thread
