Hello
This is the project that I want your help on it and I will show the schematic first :
when I connect the power to the circuit I have to press the switch first witch is coming from pin number ( 2- RA0 ) and the led from pin num ( 11 RC0) will be on , and then it will wait 15 second then activate the sensor . when any detection happen to the sensor the buzzer and the Led will start to beep . in form of : beep off - beep off beep off beep - off etc
And then to set this circuit I have to press 2 buttons :
_ first one the MCLR which is coming from pin num ( 1).
- The second one is I have to press the switch that is coming from pin num (2- RA0) .
- Then the process will redo again. Wait 15 second first then activate the sensor
What I want you to modify is the program inside the PIC . My request is : the beep from the buzzer I want to be only beep one time and for 4 seconds . in the original program it will beep off - beep off beep off beep - off etc. and then I want to reactivate the circuit automatically witch mean I dont want to press the 2 switches witch is coming from( pin number 1 and pin number 2). Also want the waiting of 15 seconds I want it to be 1 or 2 seconds .
This is the program that I want to be modified :
HTML Code:#include <pic.h> // configuration //========================================================================== __CONFIG (0x3F32); // define //========================================================================== #define alarm_set RA0 #define sensor RB2 #define led RC0 #define buzzer RC4 // main function //========================================================================== void main(void) { unsigned char status; unsigned long temp1,temp2; ADCON1 = 0x06; //Congifure Port A as digital I/O TRISA = 0b11111111; //Configure Port A as Input TRISB = 0b11111111; //Configure Port B as Input TRISC = 0b00000000; //Configure Port C as Output status=0; led=0; buzzer=0; while(1) //Infinity Loop { //scan input if((alarm_set==0)&&(status!=3)) //Alarm set { while(alarm_set==0) continue; status=1; temp1=0; } if((sensor==1)&&(status==2)) //Motion detected status=3; //processing output switch(status) { //Permitted period mode (15 seconds) case 1: led=1; temp1+=1; if(temp1<10000) buzzer=1; //Sound 'Beep' else if(temp1>1000000) { temp1=0; status=2; } else buzzer=0; break; //Scanning mode case 2: temp2+=1; if(temp2<2500) led=1; //LED blink else if(temp2<200000) led=0; else temp2=0; break; //Detected mode case 3: temp2+=1; if(temp2<40000) //LED blink & buzzer activated { led=1; buzzer=1; } else if(temp2<60000) { led=0; buzzer=0; } else temp2=0; break; } } }
