Go Back   Electronic Circuits Projects Diagrams Free > Other Forums > Feedback/Comments
Feedback/Comments Let us know your comments/feedback about this site. Even if its to complain or simply complement the webmaster.
Old 1st April 2007, 12:19 PM   #1
Default asm attachments
Is it possibile to enable .asm attachments? I think it would be often useful in the micro controllers forum.
eng1 is offline
Old 1st April 2007, 01:19 PM   #2
Just rename them as .txt or zip them.
Old 1st April 2007, 01:28 PM   #3
I don't see the point in attaching code, it's far easier to use [code][/code] tags.
if I know the answer.
Hero999 is offline
Old 1st April 2007, 01:55 PM   #4
I would agree, but don't the code tags have a smaller maximum size?.
Old 1st April 2007, 02:02 PM   #5
Wouldn't it be easier to load the asm file into MPLAB if you need to assemble it?
Have you noticed that C and H files are allowed?
eng1 is offline
Old 3rd April 2007, 03:06 AM   #6
asm file extension has been approved for uploads. You may now upload asm files.
Electro Tech Online Owner
Need to contact me? Send me a Private Message.
Verification Email didn't arrive? See this thread.
ElectroMaster is offline
Old 14th September 2007, 04:01 PM   #7
submittin for a sample . i shall see whether i could retrieve it
; * Main loop calls all tasks as needed  *
main_loop
        CALL    task_scan       ; Scan the next LED digit.
        MOVF    TMR0,W          ; Place current TMR0 value into W
        XORWF   PREVTMR0,W      ; Lets see which bits have changed...
        MOVWF   TEMP            ; All changed bits are placed in temp for test
        XORWF   PREVTMR0,F      ; Update Previous TMR0 value.
        BTFSS   SECBIT          ; Skip if it is not time to increment second
        GOTO    main_loop       ; Go back to main loop if 250 mS not passed
        MOVLW   b'00100000'     ; Bits 6 and 5 of FLAGS used as divide by 4
        ADDWF   FLAGS,F         ; Add one to bit 5
        BTFSS   TIMENOW         ; Check bit 7 - if four adds occur, skip
        GOTO    skip_timer      ; One second has not passed - skip timers
        BCF     TIMENOW         ; Clear out second passed flag
        MOVLW   CLK_SEC         ; Place pointer to increment clock
        CALL    inc_time        ; Increment the clock
        CALL    check_time      ; Check for alarm or timer conditions
        BTFSC   EGGNOW          ; Do NOT decrease timer if zero
        GOTO    skip_timer      ; Jump out if egg timer is zero
        BTFSC   UPKEY           ; Skip if UP key is NOT pressed
        GOTO    skip_timer      ; Jump out if UP key is pressed
        BTFSC   DOWNKEY         ; Skip if DOWN key is NOT pressed
        GOTO    skip_timer      ; Jump out if DOWN key is pressed
        MOVLW   TMR_SEC_LD      ; Place pointer to decrement timer
        CALL    dec_time        ; Decrement countdown timer
        MOVLW   ALARMCYCCNT     ; Place the number of alarm beeps into W
        MOVWF   ALARMCNT        ; Move beep count to ALARMCNT
skip_timer
        BTFSS   ALARMOK         ; Skip if this is the first pass into alarm
        GOTO    skip_wakeup     ; Second pass - do not re-init ALARMCNT
        BTFSS   ALARMNOW        ; Skip if this is alarm pass
        GOTO    skip_wakeup     ; Countdown timer - do not re-init ALARMCNT
        BCF     ALARMOK         ; Clear flag for second pass
skip_wakeup
        BTFSC   ALARMNOW        ; Skip if alarm clock is not set
        GOTO    send_alarm      ; Blast out a beep
        BTFSC   EGGNOW          ; Skip if countdown timer is not alarming
        GOTO    skip_alarm      ; Skip beeping and continue
send_alarm
        MOVF    ALARMCNT,W      ; Place ALARMCNT into W
        BTFSC   STATUS,Z        ; Skip if not zero
        GOTO    skip_alarm      ; We are done beeping - skip and continue
        DECFSZ  ALARMCNT,F      ; Decriment beep count and skip when zero
        CALL    buzz_now        ; Blast out the beep!!!
skip_alarm
        BTFSS   FLAGS,5         ; Skip if it is time to scan the keys 1/2 sec
        goto    finish_update   ; Jump to finish updates - don't scan
        CALL    scan_keys       ; Scan the keys and load value into KEYPAT
        BTFSS   MODEKEY         ; Skip if the MODEKEY is pressed
        GOTO    same_mode       ; Not pressed so it is the same mode...
        BTFSS   MODEKEYCHG      ; Skip if the is pressing edge
        GOTO    same_mode       ; Button is held so it is the same mode...
        INCF    FLAGS,F         ; Advance the mode by incrimenting bits 0,1
        BCF     FLAGS,2         ; Force mode to wrap-around by clearing bit 2
        CALL    turnon_scan     ; Mode button pressed - must turn on LEDs
same_mode
        call    task_scan       ; Scan the next LED digit.
        BTFSC   UPKEY           ; Skip if the UP key is not pressed
        GOTO    serve_up_key    ; UP key is pressed - jump to serve it!
        BTFSC   DOWNKEY         ; Skip if the DOWN key is not pressed
        GOTO    serve_down_key  ; DOWN key is pressed - jump to serve it!
        MOVLW   INIT_MODE_COUNT ; UP and DOWN not pressed - re-init mode count
        MOVWF   MODE_COUNT      ; Change back to lower digits for setting
        MOVF    DISPONCNT,F     ; Update Z bit in STATUS reg display on time
        BTFSS   STATUS,Z        ; Skip if displays should be OFF
        DECF    DISPONCNT,F      ; Decriment display ON counter
        GOTO    finish_update   ; Displays are ON - jump to finish updates
        BCF     FLAGS,0         ; Restore the mode to displays OFF
        BCF     FLAGS,1         ; Restore the mode to displays OFF
        CLRF    PORTB           ; Clear out segment drives on PORTB
        CLRF    PORTA           ; Clear out common digit drives on PORTA
        GOTO    finish_update   ; Jump to finish updates
serve_up_key
        BTFSC   FLAGS,0         ; Skip if not in TIMER or CLOCK mode
        GOTO    no_up_display   ; Currently in TIMER or CLOCK - keep mode
        BTFSC   FLAGS,1         ; Skip if not in ALARM mode
        GOTO    no_up_display   ; Currently in ALARM - keep mode
        BSF     FLAGS,0         ; Set to CLOCK mode
        BSF     FLAGS,1         ; Set to CLOCK mode
no_up_display
        CLRF    ALARMCNT        ; A key was pressed, so turn off alarm
        call    turnon_scan     ; Turn on the LEDs
        BTFSS   MODEKEY         ; Skip if MODE is pressed as well
        GOTO    finish_update   ; MODE is not pressed - jump to finish update
        MOVF    MODE_COUNT,W    ; Update STATUS Z bit for mode count
        BTFSS   STATUS,Z        ; Skip if we have counted down to zero
        DECF    MODE_COUNT,F    ; Decriment the mode count
        MOVF    MODE_COUNT,W    ; Update the Z bit to check for zero
        BTFSS   STATUS,Z        ; Skip if we have incrimented for 7 times
        GOTO    serve_min_up    ; Incriment the minutes digits
        DECF    FLAGS,W         ; Place current mode into W
        CALL    mode_timer      ; Look-up register RAM address for current mode
        CALL    inc_hour_ld     ; Add one hour to the current display
serve_min_up
        CALL    inc_min_ld      ; Add one minute to the current display
serve_down_key
        GOTO    no_dn_display   ; Currently in TIMER or CLOCK - keep mode
        GOTO    no_dn_display   ; Currently in ALARM - keep mode
no_dn_display
        CALL    turnon_scan     ; Turn on the LEDs
        GOTO    serve_min_down  ; Decriment the minutes digits
        CALL    dec_hour_ld     ; Subtract one hour from the current display
serve_min_down
        CALL    dec_min_ld      ; Subtract one minute from the current display
finish_update
        BTFSC   FLAGS,0         ; Skip if in mode OFF or ALARM
        GOTO    new_display     ; Jump to update LED display registers
        BTFSC   FLAGS,1         ; Skip if in mode OFF
        CLRF    DISPSEGS_A      ; Clear display regs to Shut off LED display
        CLRF    DISPSEGS_B      ; Clear display regs to Shut off LED display
        CLRF    DISPSEGS_C      ; Clear display regs to Shut off LED display
        CLRF    DISPSEGS_D      ; Clear display regs to Shut off LED display
        GOTO    main_loop       ; We are done - go back and do it again!
new_display
        DECF    FLAGS,W         ; Move current mode state into W
        CALL    mode_timer      ; Look-up register address of value to display
        CALL    disp_value      ; Update display registers with new values
; * Set up and initialize the processor  *
init
        MOVLW   OPTION_SETUP    ; Place option reg setup into W
        OPTION                  ; Set up OPTION register
        MOVLW   PORTA           ; Place beginning of RAM/Port location into W
        MOVWF   FSR             ; Now initialize FSR with this location
clear_mem
        CLRF    INDADDR         ; Clear the FSR pointed memory location
        INCFSZ  FSR,F           ; Point to the next location
        GOTO    clear_mem       ; Jump back to clear memory routine
        BSF     ALM_HOUR_LD,3   ; Place 8:00 into alarm register
        INCF    CLK_HOUR_LD,F   ; Place 1:00 into clock register
        MOVLW   0EEh            ; Turn on display A scan line, others off
        MOVWF   PREVSCAN        ;
        CLRW
        TRIS    PORTB           ; Make all Port B pins outputs.
        TRIS    PORTA           ; Make all Port A pins outputs.
        BSF     FLAGS,1         ; Set up current mode to CLOCK, display ON
        BSF     FLAGS,0
        BCF     ALARMOK         ; Don't want to trigger alarms
        BCF     EGGOK
        BSF     DISPON          ; Turn on the displays
mfg_checkkey
;        CALL    scan_keys       ; Lets see what is pressed
;        BTFSS   UPKEY           ; Goto self-test if UP key is pressed at pwr up
        GOTO    main_loop       ; Normal operation - Jump to the main loop
; * Self-test code for manufacturing only - test buttons and LEDs *
mfg_selftest
        MOVLW   b'01110000'     ; Place all key on pattern into W
        MOVWF   CLK_MIN_HD      ; Use CLK_MIN_HD for keystuck ON test
        CLRF    CLK_HOUR_HD     ; Use CLK_HOUR_HD for keystuck OFF test
mfg_display
        MOVF    CLK_SEC,W       ; Current segment display count -> W
        CALL    mfg_led_lookup  ; Look-up the next segment pattern to display
        MOVWF   PORTB           ; Move the pattern to PORT B to display it
mfg_timer
        BTFSS   TEMP,7          ; Skip if it is not time to increment second
        GOTO    mfg_timer       ; It is not time to move to next digit - go back
        INCF    CLK_SEC,F       ; Move to the next display pattern
mfg_check_digit
        BTFSS   CLK_SEC,5       ; Skip if we have timed out waiting for button
        GOTO    mfg_doneclk     ; Jump to check for the next button press
mfg_nextdigit
        CLRF    CLK_SEC         ; Clear out timer
        CALL    buzz_now        ; Send out a buzzer beep!
        BTFSS   PREVSCAN,3      ; Skip if we have NOT tested the last digit
        GOTO    finish_mfg_test ; Jump to the end after last digit tested
        RLF     PREVSCAN,W      ; Select the next digit through a rotate..
        RLF     PREVSCAN,F
        MOVF    PREVSCAN,W      ; Place next digit select into W
        MOVWF   PORTA           ; Update port A to select next digit
mfg_doneclk
        CALL    scan_keys       ; Scan the keys to see what is pressed...
        MOVF    KEYPAT,W        ; Place pattern into W
        ANDWF   CLK_MIN_HD,F    ; Make shure keys are not stuck ON
        IORWF   CLK_HOUR_HD,F   ; Make shure each key is pressed at least once
        BTFSS   PREVSCAN,3      ; Skip if we are NOT at the last digit
        BSF     KEYPAT,7        ; Set flag bit to indicate we are done!
        MOVLW   .8              ; Place 8 into W
        SUBWF   CLK_SEC,W       ; CLK_SEC - W => W
        BTFSS   STATUS,C
        CLRF    KEYPAT
        SWAPF   KEYPAT,F
        COMF    PREVSCAN,W
        ANDWF   KEYPAT,W
        BTFSS   STATUS,Z
        GOTO    mfg_nextdigit
        GOTO    mfg_display
finish_mfg_test
        MOVF    CLK_MIN_HD,F
        BTFSS   STATUS,Z
        GOTO    bad_switch
        MOVF    CLK_HOUR_HD,W
        XORLW   070h
        BTFSS   STATUS,Z
        GOTO    bad_switch
mfg_cleanup
        CLRF    CLK_HOUR_HD     ; Restore temp registers to zero
        CLRF    CLK_MIN_HD      ; Restore temp registers to zero
        GOTO    main_loop       ; Jump to main loop
bad_switch
        COMF    CLK_MIN_HD,F
        SWAPF   CLK_MIN_HD,W
        MOVWF   KEYPAT
        BSF     CLK_HOUR_HD,7
        SWAPF   CLK_HOUR_HD,W
        ANDWF   KEYPAT,F
        MOVLW   07Fh
        MOVWF   PORTB
        CLRF    CLK_MIN_LD
        BSF     CLK_MIN_LD,5
loop_bad_sw
        CALL    buzz_now_dispon ; Beep the buzzer constantly for a few secs
        DECFSZ  CLK_MIN_LD,F    ; Decriment counter and skip when done
        GOTO    loop_bad_sw     ; Not done buzzing - go back and do it again
        GOTO    mfg_cleanup     ; Done buzzing - clean-up and run clock
        END
Regards,
Sarma.
mvs sarma is online now
asm, attachments
16f84 asm to 16f628 _ab Micro Controllers 17 14th November 2008 09:05 PM
do you avoid threads with attachments ? williB Chit-Chat 14 8th October 2005 10:33 PM
Why are my attachments not allowed? audioguru Feedback/Comments 8 30th March 2005 11:54 PM
Attachments Ravi Feedback/Comments 3 18th September 2003 03:08 AM
Attachments to Posts Gene General Electronics Chat 2 8th March 2003 08:17 PM
