Rolling shutter effect on Apple products
12 Last »
  1. #1
    Sceadwian Sceadwian is offline
    I had a thought about the rolling shutter effect some people have played with using the Iphone that I'd like to investigate, I believe the Ipod touch (with camera) has the same rolling shutter. I however do not have an Iphone or Ipod with a camera nor do I intend to get one anytime soon, my brother in law has one but the earliest I'd be able to get to him to test this would be two weeks from now.
    It requires only one thing, a RED LED as close as possible to the camera lens connected to a micro controller, it does however require some tricky timing of the LED to last only 1/4 of the time it takes the camera to scan a single line of video (the math would be worked backwards from the resolution and framerate the video is recorded at) repeated 4-5 times with 10-20 time gaps inbetween.
    Anyone here up to the task over the weekend? Should be trivial to write code with delay loops, to do this. If anyone is interested please post in this thread or contact me in a private message. The scope of what I want to do is relatively complicated this simple test is just a first step as the results are critical to the large concept working. All I need is a short video of the LED blinking at these high on/off rates
  2. #2
    davenn davenn is offline
    Interesting experiment you are working on .. Will be interested to see the results that others get as well
    Rolling shutter technology is the curse of my storm filming
    All the newer cameras... Last ~ 5 years have CMOS rather than CCD sensors and they all use the rolling shutter
    The hi speed of a lightning flash is destroyed by the rolling shutter.
    I still have a Fuji S9500 digital camera that uses a CCD image sensor with the standard full chip shutter
    Cheers
    Dave
    0
  3. Thread Starter #3
    No responses yet from anyone that might have an Iphone and the ability to generate the pulses. I'll whip up a circuit and go visit my brother in law within the next few weeks, it's just exploratory right now to see how the rolling shutter actually functions in a detailed way.
    I'm still using a Cannon A530 which is a CCD based but it's just a 'point and shoot' with an a manual mode, nothing like the camera you have, as much as photography interest me my other hobbys are far in front of it as far as what I have to spend.
    0
  4. #4
    thehaag thehaag is offline
    Would you recommend CCD or CMOS? I seem to find CCD faster but lower resolution. I like my camera to be able to shoot a photo of some that well that you can analyse the environment around them so you could zoom in an read a distant title of a book for example. CCD just does not seem to offer that. What are everyone else's view.
    -1
  5. #5
    harold777 harold777 is offline
    For video cameras "Rolling shutter" is a bind, but just as in the early days of Hollywood "we" have to get round the limitation of the tools we use.
    My own movie-camera is CMOS and I try to keep large rotating parts out of the picture (eg flywheels, props, etc), but I sometimes wonder how broadcast cameras overcome this.... or do they splice-in some "real-film" footage? I rather doubt that, but then they have much faster data-paths, with correspondingly larger memory demands.
    Consumers want their whole holiday on one memory card. (least that seems to be the view taken by consumer camcorder makers).... so this means some economy in pixel rates.
    One benefit of CMOS sensors is they work better in low-light - and are cheaper to make ... strong benefits, I guess.
    Will be interested to know what use OP will use this experimental Info for - it's npot as though Apple will change their design, - anyone?
    0
  6. Thread Starter #6
    This is not true. Charged couple devices are superior in low level light, lower noise. CMOS sensors have had their effective ISO levels sky rocket in recent years, but this comes at a cost of increased noise, CCD's produce a superior quality image.
    This has nothing to do with improving the cameras, it's exploiting them for a specific effect. I believe there's a way to do scan line image creation on something like the Iphone's image sensor. I may be able to test it within the next few weeks, mind you I said that a few weeks ago =>
    I have the board that will test it on my desk, but I've been short on time seeing as my son was born 6 1/2 weeks early, I was going to finish this a month ago, but life happens! I still don't know if the effect I want to exploit exists, that's the reason for the testing. As far as I know typical CMOS sensors are rolling shutter, but per line. My theory is that the Iphone's camera is a per pixel rolling shutter, the effect will only occur on a per pixel rolling shutter.
    0
  7. #7
    rthuey rthuey is offline
    looks like you might still be looking for some help. we have an original iPhone, 3gs and 4s in the house at your disposal.
    0
  8. Thread Starter #8
    Do you have a micro controller dev board, such as a PIC or AVR and know how to program it? All this will require otherwise is a red LED.
    0
  9. #9
    will an arduino suffice?
    0
  10. Thread Starter #10
    Sure as long as you can program a software or hardware PWM at a decent frequency.
    You need to output a 1mhz square wave with a 25% duty cycle for a starter test, the PWM drives the LED (directly without a current limit resistor) If you can adjust the voltage of your Arduino down a bit that would be ideal, as at 5V you'll probably be over driving the LED a bit not to mention stressing the I/O pin, I don't want to hurt your board.
    All you have to do is take a single photograph of the LED while the code is running and the LED is lit, but the LED has to be RIGHT up against the window of the camera so that any light coming from it will be out of focus and saturate the entire sensor.
    0
12 Last »
Interfacing a Apple Portable LCD panel LV426 Electronic Projects Design/Ideas/Reviews 0 6th July 2003, 04:38 PM
how to reduce loading effect eeglp Electronic Projects Design/Ideas/Reviews 2 22nd April 2003, 05:46 PM
Hall Effect ankurchanga General Electronics Chat 4 18th April 2003, 10:55 AM
Hall Effect ankurchanga Electronic Projects Design/Ideas/Reviews 1 16th April 2003, 11:43 PM
Submarine Sonar sound effect (echo sounder)? mazfg Electronic Projects Design/Ideas/Reviews 0 19th February 2003, 02:22 PM
Page Time: 0.07908 seconds      Memory: 7,670 KB      Queries: 16      Templates: 0
