Very educative, ElectroMaster. Thanks.
Especially the bit of info that modern ATX come with higher capacity on their 12V rail. Good Video.
Converting Computer ATX Power Supply to Lab Bench Power Supply
Description
Small tutorial on Computer ATX Power Supplies. How to use them, how to connect them in series, in parallel. What is 12V rails? Is it possible to connect 12V rails together? ATX connector wiring explained. What is difference between old computer power supplies and new ones? And finally how to make Lab Bench Power Supply from Computer ATX Power Supply.
By JumperOneTV.
Have you designed a circuit? Publish it in our Circuits directory! It's easy!
Latest Articles: 555 Timer, 4017 Decade Counter, Common Resistor Values (The 'E' series)
Regards,
Sarma.
This was a great video, but I do have one big issue with it: His drilling "technique":
1) You should -never- use a power drill while holding the part being drilled by hand. If the drill should catch or slip on the material, things could get nasty (I've learned that lesson the hard way more times than I can count - I guess I am a slow learner!)
2) When modifying a case, you should remove all electronics from the case first, then reassemble after modification (I don't know how none of the chips/swarf from drilling out those holes didn't short out the power supply, but by disassembly, you can make sure the supply is clean of this debris before re-assembly)
I did like that small heat-gun (or SMT resoldering station? Couldn't tell) he was using - I wish I had one for my bench...
Couple of little bit falls. He talked about placing a minimum load dummy resistor on either the 5v or 12v rails. This is because the primary feedback for voltage regulation is accomplished on these rails (5v old, 12v new supplies). Without them the power supply will likely be unstable.
He did not mention the other rails' voltage is solely based on the transformer turns ratio of each winding of the secondary. There is no individual regulation control on these other lines. The primary control voltage regulation is only on the 12v supply for new power supplies. This make the voltage regulation on the other voltage supply outputs rather poor as their loading varies.
The outputs are rather noisey due to the direct switching regulator output. I would not use them directly for any analog circuitry where power supply noise level is important. The audio circuitry on a computer motherboard has power supply filters and on board linear regulators to create a clean supply.
Perhaps in this case the regulation would be on 3.3V that draws more current, I suppose.
Regards,
Sarma.
Drilling technique apart, it's a good use of an unwanted SMPS - but I'd like to know what noise is on the rails -
For general use I like to have Plus/Minus 15v rails. That bit more than standard 12v so maybe use several SMPSs and Linear Regs to provide some variable element - but then sudenly it gets a bit larger and more difficult....
I'm soon building a variable lab-psu and think I shall need conventional transformers - that way I can switch the LV (by turning off the primaries?) so the OP voltage is kept managabe. Heat in Linears is always an issue for long-term reliability.
I bought some 2A 5v regulators which can beused at higher voltages to cut the noise, then into a 1.2v variable...Hey-Ho.
I know this is an old post but I think all of these converting ATX Power supplies are way over-rated. I simply just bought a old dvd/cd/video cd sharp dv-740 player from a junk sale for 3 dollars took out the entire first pc board and hook up some alligator clippers to it anytime I need power supply. It is so well built that noise is minimum and best of all it is already ready to go.
BCHS/3v0's PIC C18 Tutorials
Mondo Tech's Super Probe
Brian Schmalz's USB Bit Whacker
No Beef. I have one also. But doing it the other way offer same thing without going through so much trouble. Just take out a couple of screws, plug in and hook up your alligators. Just wanted to let others know there are better alternatives and cheaper. It does make a nice weekend project, hope I did not sound rude.
drilling with PCB in there? way too many places for metal shavings to get into....
to err is human. to blame someone else shows good management skills...
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Converting PSU from PC to bench power supply? | Leezygeezer | Electronic Projects Design/Ideas/Reviews | 7 | 26th September 2011, 08:59 PM |
| Running a computer power supply from car | truenoteno | Automotive Electronics | 7 | 6th February 2011, 10:07 PM |
| ATX power supply -> lab bench power supply | Cobalt60 | Electronic Projects Design/Ideas/Reviews | 30 | 26th January 2011, 09:29 AM |
| atx power supply datasheet baz1670347e, cosmo/1010/817/d36/c | andhi_132 | Datasheets, Manuals or Parts | 1 | 14th August 2009, 08:59 PM |
| converting an ATX power supply | avz | General Electronics Chat | 2 | 11th December 2008, 07:54 PM |
