| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
why when when we connect capacitators in a row(not paralel) the capacitance gets smaller i need the physical explanation for it | |
| | #2 | |
Capacitors in Series | ||
Lets take an example of two equal value parallel plate capacitors. The capacitance is directly proportional to the amount of charge it is holding and inversely proportional to the voltage applied that is pushing the charge onto the opposite plates. Remember, the net amount of charge a capacitor holds is always zero, but we talk about the numerical value of +ive (or the equal -ve) charge as the charge stored by the capacitor. When we connect capacitors in series, we are connecting a +ive terminal of one to the -ive terminal of other that results in the summing up the potential differences, and the net voltage across the connection is the sum of individual voltages. However, when connecting a +ive to a -ive terminal, the opposite charges get cancelled, and you will be left with the same amount of charge as in a single capacitor. So the situation is like you require more potential difference to hold the same amount of charge, which means less capacitance (C=Q/V). - Raj Experiments with PIC16F628A | |
i agree with this line "Therefore, at least in theory, we can reduce it to atomic thickness without any effect on the capacitance of the series combination" but i cant understand why we can remove the center plate?? "Since the outer plates are still parallel to each other, removing the center plate won't change the total electric field" why the iron plate is not changing the total electric field? i know that when we put dialectric plate in a capacitor the capacitance changes | |
Having a positive and negative charge next to each other virtually cancels them out. Capacitance is based on charge separation over a distance. We do not make up the laws of physics, we follow them | |
| | #6 |
ahh the positive and negatie charges cancel each other in the added plates so the is no chrge and no electric field of this center plate. and we have one capacitor with twice the distance of each and thecapacitance gets smaller by half too thanks | |
| | #7 |
No problem, just went over this in class today actually (Review from High School)
| | #8 |
my prof said that its not working for non lenear capacitators (it works only for a tiny central plate) he said that the correct answer is: the total charge is constant and because q=cu i dont understand this logic your explanation was much clearer i cant see how the total capacitance reduces Last edited by transgalactic; 11th November 2009 at 07:45 PM. | |
| | #9 |
If the potential is fixed he is wrong.
| explanation, physical, question |
| Any explanation for this flashing LED schematic? + one small question | Triple-H | General Electronics Chat | 8 | 1st July 2009 08:33 PM |
| IR wall detection -- physical setup. | 3v0 | Robotics Chat | 2 | 16th April 2008 10:21 AM |
| Physical size of capacitors? | Andy1845c | Electronic Projects Design/Ideas/Reviews | 14 | 18th November 2006 08:35 AM |
| Base physical quantity: Current? | Cifrocco | General Electronics Chat | 36 | 7th July 2005 08:21 AM |
| making a physical calculator!!! | maria | Electronic Projects Design/Ideas/Reviews | 2 | 17th June 2003 10:05 AM |
