Old 27th October 2009, 01:58 AM   #1
Default Fourier transform and Laplace transform
I'm not very sure if this is the right forum to post this, but didn't find a better one.
I would like to know if the Fourier transform can always be achieved by finding the Laplace transform, I'm asking because I find in a Signals & Systems book, a problem that said Find the Fourier transform using the Laplace transform, well, actually it was the solution manual, and what they did was find the Laplace transform and change S for jω. Is that always possible?
Karkas is offline
Old 28th October 2009, 10:56 PM   #2
Yes, from what I can remember my studies in differential equations, about 20 years ago.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is online now
Old 29th October 2009, 01:12 AM   #3
well most of the time but not always because for example laplace transform of the step frunction is 1/s evaluating at s=0+j*2*pi*f but that wont give you the right trans form value. the unit step transform is 1/(j2pi*f)+(1/2)delta(f)
Also i was wondering if any one knew the transform of sinc(t)u(t)
tau17 is offline
Old 29th October 2009, 02:50 AM   #4
Thanks for the answer, but the unit step transfomr is not 1/jω + πδ(ω)?
But anyway you're right, it is not always the same, is that the only case you know? because if there are more, then is not a very sure thing to do.
Karkas is offline
Old 29th October 2009, 03:00 AM   #5
i thought that was the the transform for unit step . thats what my book says ..........
tau17 is offline
Old 29th October 2009, 03:48 AM   #6
I don't have a book here but I looked it up in the web and I found it that way in two sites, and nonde of them is wikipedia.
Karkas is offline
Old 29th October 2009, 04:14 AM   #7
I think its rect(w)
Fourier transform have a property called duality, which basically means that if you have
if the following is a transform pair s(t)<-->S(w) then S(t)<--> s(w).
The fourier transform of a rect pulse is a sinc function, so by duality, a sinc funtion would have a rect as its fourier transform.
tresca is offline
Old 29th October 2009, 04:31 AM   #8
well u can derive it for unit pulse
u know that transform of delta is 1 and derivative of unit pulse is delta
so by integration rule
taking integral of delta
integral of g(t) transforms to (G(f)/(j2*pi*f)) + ((G(0))/2 )*delta(f)
now for
values of G(F) and G(0) are 1 because delta transforms to 1 so thas how i got that equation
Tresca
i dont want sinc (t)
i want transform of sinc(t)u(t)
tau17 is offline
Old 29th October 2009, 05:06 AM   #9
also i just wana check if i am getting duality right
g(t) <--->G(f)
and g'(t) <----> j2*pi*f*G(f)
so is t *G(t) =j g'(f)
*= multiplication not convolution ...
tau17 is offline
Old 29th October 2009, 05:06 AM   #10
sorry = j*f*G(f)
tau17 is offline
Old 8th November 2009, 02:59 PM   #11
The fourier and laplace transform are pretty much the same thing except σ is nonzero when talking about "laplace" transforms . Fourier transform is laplace evaluated with σ=0.
Fourier transform is the jω axis of the laplace transform. If you "draw" the laplace space. And only take a look at the slice which goes along the jω axis then that is the fourier "space".
Fourier transformation is only a "thin slice" (the jω axis) from the s plane. Stable systems contain laplace transforms that converge on the jω axis and thus have a fourier transforms assuming dirichlet conditions are fullfilled. If you have a laplace transform for a stable system. You can simply put σ=0 and volla you have your fourier transform.
Keep in mind that S = σ + jω. So puting σ=0 you have.....jω .
You can only do this for systems that have laplace transforms that converge for the jω axis.
steinar96 is offline
Old 8th November 2009, 09:21 PM   #12
That was the answer I was looking for, thank you very much steinar96, and the other posters too.
"A person who never made a mistake never tried anything new"
Albert Einstein
Karkas is offline
fourier, laplace, transform
Fourier Transform question tresca Math and Physics 2 28th February 2009 10:13 PM
Inverse Laplace Transform drolex Math and Physics 7 10th November 2007 05:25 PM
Laplace transform help... elec123 General Electronics Chat 1 16th October 2005 02:27 PM
LAPLACE TRANSFORM cyprio7 General Electronics Chat 6 20th April 2005 10:48 PM
Fourier Transform shermaine General Electronics Chat 2 20th March 2004 02:50 PM
