| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
This might be a hairbrained scheme, but need to check this. If I have a capacitor bank consisting of 20 3300uF capacitors, that should give me 66F right? If I charge this bank to 15V that should be 7425 Joules of energy, + or - the 20% tolerance of the caps. Since 1J = 1W/S[econds] I should be able to draw 7425W for 1S or 1W for 7425S. Am I right so far? Ok If I have a circuit that draws 500mA or 7.5W, I should be able to power it for 990S, or 16.5 minutes, disregarding losses. Realistically I would expect it to work no longer than 5-7 min. Have I done the math right? BTW this is not a homework question, it is for a project I am currently working on. | |
1 Farad = 1000000 microfarads so i think your capacitance calculation is a little off. Check it again. Also, the total energy available is 1/2 C*v^2 so check that calculation again too. You also have to consider the drop in voltage over time when loaded to see if what you are powering will still work after some time period. For example, a 66 F capacitor charged to 15 volts and loaded with 15 ohms will discharge to about 5.5 volts after 990 seconds. It will also discharge to about 12v in 12 seconds. This of course will affect the load. It certainly does not deliver 15 volts for the entire time it is discharging. If you need that kind of operation, you'll need to use a voltage regulating boost circuit between caps and load. With a regulating boost converter that can operate between 15v and 5v and put out 15v for example, you can get the full 15v output for approximately 440 seconds and then the output will drop down suddenly (assuming 66F charged to 15v again and 15 ohms load on the output of the boost converter, and not including the inefficiency of the boost converter). If the boost converter itself dissipates about 1 watt then the total run time will drop to about 412 seconds. Last edited by MrAl; 9th October 2009 at 04:44 PM. | |
Ok thanks. So, this would still be a "fool's errand" to try to use cheap caps as a battery replacement, for a keep-alive for a couple of minutes. It would therefore be cheaper to use a rechargeable battery bank to keep the circuit active. That is what I needed to check. Thanks! Last edited by charlie_r; 9th October 2009 at 04:49 PM. | |
Hi again, Well, if you have a constant current like 500ma then you can use: dv=i*dt/C to calculate the time dt, and doing that we get about 7.9 seconds until the output reaches 9v at which time the circuit will stop working. That's if you charge the 0.66F caps to 15v though, if you only charge them up to 12v (because circuit is limited to 12v max) then you will only get about 3.9 seconds of operation. Last edited by MrAl; 9th October 2009 at 04:54 PM. | |
As stated in the OP, the bank would be 20 3300µF (25V) caps, that I would be charging to at least 15V. If I could get a run time of 2 minutes minimum I would try this. But as the [corrected] math is showing me that it won't work as desired, I will do the smart thing and abandon the idea. Thanks for your help. | |
| | #6 |
Hi again Charlie, I just thought i would let you know that when longer run time is needed usually the solution ends up being batteries instead of capacitors. The batteries are the rechargeable type like NiCd or Lead Acid. NiMH are not used as much for this kind of thing because they have specialized charging requirements. You can also look into Li-ion cells, as three in series would give you enough voltage and run time would probably be over two hours. You could get a charger off the web or build one yourself (carefully of course). Just some ideas there. | |
| | #7 |
Stored energy is proportional to voltage squared. (1/2CV^2) And at some minimum voltage, your circuit will stop working, so you cannot keep extracting power from it right down to zero volts. Capacitors are only really suitable for that type of energy storage application if charged to truly lethal voltages to begin with, and then run all the way down to some much lower voltage. your example of 20 x 3300uf is 0.066 Farads Charged to 15v is 0.033 x 15 x 15 = 7.425 Joules Suppose your circuit stops working at 5v Energy at 5v = 0.033 x 5 x 5 = 0.825 Joules. The energy you can actually recover as it discharges from 15v to 5v will be 7.425 - 0.825Joules Now think about one only 3300uF capacitor charged up to 400 volts. Energy for 0.0033 Farads. 0.00165 x 400 x 400 = 264 Joules. And you only need ONE capacitor to store that much. | |
| | #8 |
Hi again, Yes a bank of 20 caps each 3300uf is only 66,000uf, which is really not much at all. For your constant current of 500ma then you can still use: dv=i*dt/C to calculate the time dt, and doing that we get about 0.79 seconds until the output reaches 9v at which time the circuit will stop working. That's if you charge the 0.066F caps to 15v though, if you only charge them up to 12v (because circuit is limited to 12v max) then you will only get about 0.39 seconds of operation. As i was saying before, this application would probably be better off using rechargeable batteries unless you feel like also building a voltage converter so you can make use of the cap's energy better. | |
| check, math |
| Math Help | shermaine | Homework Help | 1 | 14th June 2009 04:57 PM |
| i think it's math! | t.man | Math and Physics | 0 | 17th October 2008 01:05 PM |
| Math Help | Burnt | Math and Physics | 4 | 16th October 2008 10:23 PM |
| Math Help | shermaine | General Electronics Chat | 9 | 21st April 2004 02:39 PM |
| Need Help In Math | shermaine | General Electronics Chat | 6 | 8th March 2004 02:46 PM |
