| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
Hi Can i drive 3 triac in parallel style connect ( T1s to T1s and T2s to T2s and Gates Pin to Another Triac Gates Pin) and drive three them whit only one Opto-coupler ? | |
you can not, in general, drive triacs in parrallel-they do not current share well resulting in catastrophic failure if you force current sharing you can connect the main terminals in parrallel, but this is very clumbsy. you can not tie the gates together as one tends to fire first and will rob the others of gate drive, again resulting in catastrophic failure | |
Ok , If i connect terminals together , how can i trigger triacs?! use 3 Opto-couplers!?
Any one help me please. | |
Hi, Are you trying to create an 'OR' circuit where any gate drive can turn the circuit on, or are you trying to increase the current rating of a triac by using three of them in parallel? From what you say it sounds like you are trying to put three of them in parallel in order to increase the total current rating and therefore be able to drive something that uses a higher current than any one triac is rated for. Unfortunately, this is a problem. The problem starts where any one of the three may turn on first, taking a high current before the others can turn on, but that's not the worst of it. The bigger problem is that any one of the triacs might force the other two to turn off if the gate drive is a pulse rather than a continuous drive signal. This could happen because the other two may be robbed of all of their original current and so their conduction current falls below the holding current and they turn off. This means one triac carries the full load for the entire half cycle, and that's not good. This of course means that a gate that pulses can not be used so a continuous gate signal is mandatory. Ok, so we know now that a continuous gate signal is needed, but also as someone said the gate voltages may be different so that means each gate has to be driven individually. Also, driving the gate negative for any conduction angle is a good idea to keep gate current and power low. Next, one triac may turn on before the others and carry the full load for some time period. Now they are quite hardy devices, but this still isnt a good idea so perhaps some resistance in series with each main terminal. A small amount resistance may help match the triacs up a bit better. Im not sure what your total load current is, but since each device is rated at 16 amps you probably dont want to use too much resistance or it will eat up too much voltage and also some energy. If you were to use 0.1 ohms for example, that would drop 1.5v at 15 amps. Also, some fuses in line with the main terminals is a good idea too. Perhaps rated for 15 amps. Ok so here is the list: 1. Resistors in series with the gate to allow individual gates to get their required voltage 2. Continuous gate drive mandatory using a negative gate signal only, and pulse drive not allowed 3. Small resistors in series with main terminal to help match devices 4. Fuses in the main terminal lines Note that this discussion is more or less theoretical, as i have never had to do this in real life. Also, the best idea is to purchase a triac that has the rated current so that you can use a signal device rather than three in parallel, which basically is not a good idea. Since each device you mention has a rating of 16 amps each, you may be able to find a 45 or 50 amp device that can handle the full load. If not, you would still be better off to make your own triac out of two 50 amp SCR's, which has been done quite a bit in the past and always works fine. You could drive the gates perhaps with two opto couplers. If you do attempt the three triacs in parallel, at least test them to make sure they all turn on and stay on once installed. If the construction works at all, you can test each triac for temperature rise to see if any one triac is taking much more current than the other two. If one gets very hot while the other two are cool that means you may have to replace that one with another one that has similar turn-on characteristics as the other two. Lastly, GE makes a manual for SCR and TRIAC operation in parallel and other configs, and i think it is the sixth edition of their scr and triac manual. You might find one on Amazon or somewhere like that or maybe even online. This should have more information about this topic. Last edited by MrAl; 7th October 2009 at 02:45 PM. | |
| | #6 |
Thanks for you attention My Current is 10 amp and i need 3 triac to reduce the temprature on my triac hit sink ( this is necessary for my project) . I use BTA40 and it is huge for my use. so can u send me link or complete name of GE manual? | |
| | #7 |
Hi again, Sorry i dont have a link to that manual. You would have to look for the sixth edition of their manual on triac's and scr's, but i dont have the exact name handy either. Perhaps on Amazon? | |
| bt139, optocoupler, triac |
| Opto coupler erratic behaviour | dark | General Electronics Chat | 17 | 20th August 2009 02:52 PM |
| Opto coupler from mice | mcs51mc | Datasheet/Parts Requests | 8 | 13th February 2006 04:18 PM |
| opto coupler | jin29_neci | General Electronics Chat | 4 | 7th September 2005 09:35 AM |
| Opto-coupler | Styx | Electronic Projects Design/Ideas/Reviews | 4 | 5th January 2005 07:47 PM |
| How to use an opto-triac? | davepusey | General Electronics Chat | 18 | 10th August 2004 09:14 AM |
