| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
Hey Everyone, Just want to make sure I'm doing this right. Suppose I have a voltage divider like in the first attachement. You'll see that R1 = 680Ω and R2 = 20k giving me an output voltage of 8.7V [Vout = R2/(R1+R2)]. Now, to calculate the output current of the voltage divider, you do the following: Iout = Vin/(R1+R2). So my current output is approximately 435μA. Let's say I want to have 2.5μA for my output, I simply add a resistor like in the second attachment. What would the output current be now? Also, wouldn't there be a voltage drop across R3 so I would have to make the voltage a bit larger to compensate for that drop? Ignoring the voltage drop, this is what I did: 435μA - 2.5μA = 437.5μA. So, 8.7V / 437.5μA = 19885.71429Ω ≈ 20k. Please let me know if I'm doing this right! This is to get the correct base current and voltage to an NPN transistor. | |
Hi Austin. The way I would approach this is to first just look at just the voltage divider R1 and R2. As you have already worked out, that by itself will give an open circuit output voltage of 8.70406 Volts (when the output is not loaded). The next thing you need to do is work out the source impedance at the junction of R1 and R2, which is just R1 and R2 in parallel. That works out to 657.6 ohms. The power supply source at the junction of R1 and R2 now looks like a perfect 8.70406 volt battery in series with 657.6 ohms. You can now use this Thevenin equivalent to calculate how the voltage divider is going to behave when further loaded by "something else" connected to the junction of R1 and R2 as a load. Last edited by Warpspeed; 18th September 2009 at 08:30 AM. | |
First of all the 435μA is not a output current. It is a current that is flow form Vs1 trough R1 and R2. Vs1+--->R1--->R2--->-Vs1 So output voltage is equal Vout=I2*R2 = Vs1/(R1+R2) * R2 = R2/(R1+R2) x Vs1=8.7040619V And the output current without a load is 0A and I1=I2 ![]() And now if we connect the load that draw 25uA of current we get this situation: ![]() The solution can be find quite easy with a little help from algebra and KCL, KVL. Vcc - I1*R1 - I2*R2 = 0 I1 = I2 + Ip Vcc - (I2+Ip)*R1 - I2*R2 = 0 Vcc - I2*R1 - Ip*R1 - I2*R2 = 0 Vcc - I2*(R1+R2) -Ip*R1 = 0 Ip*R1 + I2*(R1+R2) = Vcc I2 = ( Vcc - Ip*R1 ) / (R1+R2) Vout=I2*R2= [ R2*( Vcc - Ip*R1 ) ] / (R1+R2) And R_load=Vout/Ip=8.687V/25uA=347kΩ And if you still want Vout=8.7V then you must correct R1. New R1=(Vcc-Vout)/(I2+Ip)=(9V-8.7V)/(453uA+25uA)=0.3V/478ľA=627Ω=620Ω Last edited by Jony130; 19th September 2009 at 06:59 PM. | |
| | #4 | |
If i understand your question right you want to reduce the current through the voltage divider while still maintaining 8.7v output. To get there, start with your current of 2.5ua and 8.7v and use RL=V/I which is: RL=8.7/0.0000025=3.48 megohms. To get the lower resistor. To get the upper resistor take the same 2.5ua and Vcc-8.7v to get that resistor: RU=(Vcc-8.7)/0.0000025=(9-8.7)/0.0000025=0.3/0.0000025=120k. You should realize however that any small load connected to the output of the divider will change the output voltage. If the load connects to ground it will reduce this voltage, if it connects to Vcc it will increase this voltage. You should also realize that if that 9v supply is a battery that will eventually drain down and the output will drop because of that too. Last edited by MrAl; 20th September 2009 at 10:34 AM. | ||
This transistor is biased completely wrong. It is almost saturated. The collector is +9V and the base is +8.7V. I can't find the other thread that talks about it.
| divider, verification, voltage |
| Voltage divider | Electronics4you | General Electronics Chat | 15 | 28th October 2009 06:23 PM |
| voltage divider | AtomSoft | Electronic Theory | 28 | 16th August 2009 10:54 AM |
| voltage divider needed | goldenwords | Electronic Projects Design/Ideas/Reviews | 3 | 27th October 2007 11:32 AM |
| voltage divider | samtheboxer | Electronic Projects Design/Ideas/Reviews | 3 | 25th July 2007 02:19 PM |
| Voltage divider | raphaelriv | General Electronics Chat | 11 | 26th July 2006 09:13 PM |
