| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
Hey, I started reading the Frequency Responce chapter in my book, and in the section where they analyzed Short Circuit Current Gain of the CE amplifier, it was said that: "The quasi-static model is not valid at frequencies higher than the point at which the magnitude of the current gain is equal to one". Could you please explain to me what is the quasi-static model which represents a CE amplifier, and why is it valid in freq. below the transition frequency? (in which the current gain equals to one). Thank you. | |
The current gain or "beta" of a Common Emitter (CE) amplifier is always measured with dc currents. However, if you drive the base circuit with an ever increasing frequency, the ac current gain falls as the frequency increases. Eventually the current gain will fall to one, where the change in collector current then equals the change in base current. That is known as the "Transition Frequency", or Ft of that particular transistor. Beyond that frequency is ceases to amplify ac signals, and becomes pretty useless. Any modelling that assumes the transistor can amplify becomes invalid, and any circuit will fail to work as intended. Last edited by Warpspeed; 13th September 2009 at 03:34 AM. | |
Thank you fellow. Its much appreciated! | |
| frequency, related, response, transition |
| Speaker Frequency Response | Frosty_47 | Chit-Chat | 8 | 24th July 2009 12:52 AM |
| Frequency response of IR LEDs | TheVictim | Datasheet/Parts Requests | 8 | 6th November 2007 02:04 AM |
| Frequency response using SPICE | slackjack | General Electronics Chat | 12 | 17th May 2007 04:54 PM |
| Multimeter frequency response | gjpollitt | General Electronics Chat | 4 | 17th August 2005 01:14 AM |
| PWM and frequency response | DigiTan | General Electronics Chat | 5 | 13th June 2005 04:14 AM |
