| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
what's the main purpose of connecting two zeners facing each other?
It's for over voltage transient suppression. The breakdown voltage is equal to the Vf plus the reverse breakdown voltage. You can buy transient suppressors which are just two zeners connected back-to-back. The advantage is that it can be used for AC.
The usual application for this is for use in ac circuits to clamp an ac voltage equally on both positive and negative halves of each cycle.
bipolarity clamp ±(Vz + Vd) It is also used across the capacitor in OPAMP integrator circuit to clamp the output to a know level and stop the OPAMP driving itself into saturation (and thus cause issue and delays if/when it is winding out of saturation) | |
This back-back connection can also be used to clip the sinusoidal signal depending upon i/p and Vz of diode.This can be extended further to generate square wave.
| zeners |
| Risistors and Zeners | AboZakaria | General Electronics Chat | 5 | 17th March 2008 03:39 AM |
| Zeners Short Circuit Problem | proksima | Electronic Projects Design/Ideas/Reviews | 6 | 26th August 2006 02:45 PM |
| Power Supply Design & Zeners | Noggin | General Electronics Chat | 2 | 6th October 2003 03:38 PM |
