| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
| | #16 |
Those are cool! but requires about 3 weeks wait in the mail heh. Version 2 of this sounder would incorporate it. I will place a order tomorrow for the 3.3v version (LE33ABZ (1% version)) For now since its somewhat built and i can use a small RS(Radioshack) case i will not use it. Its running perfect on 2 AA batteries tho. I might just use 3 AA alone and sleep mode. Im off to print out some pages on the sleep mode of PIC micros (im using a 18F1320) at my job since we have a laser printer (fast) and boss says its ok for me to use it whenever i need. Thats where i print my PCBs now Thanks guys!!!P.S. Can someone please post some tips on sleep mode and how to enable it and use it.. Also i have a new button on RA0 can i use this to wake up?
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #17 | |
Hi again, Take a look at the data sheet for the PIC part you are using. Look for the description of the 'sleep' instruction. That should tell you most of what you need to know to use this. It's not hard at all really. I think you can have it wake on io change too, so you might be able to set it up so that it doesnt do anything until a button is pressed, then it wakes up and does whatever you want it to do (like play a tone). This is nice because the kiddies cant forget to turn the device off and run down the batteries as the PIC consumes very little power in sleep mode. If not you can wake it every half second or so and read the buttons with the same power savings. | ||
| | #18 |
ok cool i printed the stuff out and ill try it soon it looks too easy lol
| | #19 |
heh here we go: Code: #include <p18Cxxx.h>
#include <delays.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO2
#define button1 PORTAbits.RA3
#define button2 PORTBbits.RB2
#define button3 PORTBbits.RB3
#define button4 PORTBbits.RB4
#define button5 PORTBbits.RB5
#define WakeMe PORTBbits.RB0
char pos;
int time;
void PlayTone(char num);
void high_ISR (void) ;
void high_interrupt (void);
void NightTime(void);
#pragma code high_vector = 0x08
void high_interrupt (void){
_asm goto high_ISR _endasm
#pragma code
#pragma interrupt high_ISR
void high_ISR (void) {
INTCONbits.INT0IF = 0;
INTCONbits.RBIF = 0;
LATAbits.LATA0 = 1;
void main(void){
int k,j,i;
OSCCON = 0x72; //8MHz clock
while(!OSCCONbits.IOFS); //Wait for OSC to become stable
pos = 0;
ADCON1 = 0xFF;
TRISB = 0xFF;
TRISA = 0x00;
TRISBbits.TRISB1 = 0;
TRISAbits.TRISA3 = 1;
LATBbits.LATB1 = 0;
INTCON = 0b10010000;
INTCON2 = 0b11110000;
INTCON3 = 0x00;
RCON = 0b10000000;
LATAbits.LATA0 = 1;
while(1){
if (button1)
PlayTone(0);
else if (button2)
PlayTone(1);
else if (button3)
PlayTone(2);
else if (button4)
PlayTone(3);
else if (button5)
PlayTone(4);
Delay10KTCYx(50);
time++;
if(time == 20){
NightTime();
void NightTime(void){
LATAbits.LATA0 = 0; //Turn off LED
OSCCONbits.IDLEN = 0; //Clear he IDLEN and SCS1:SCS0
OSCCONbits.SCS1 = 0;
OSCCONbits.SCS0 = 0;
Sleep(); //Call Sleep instruction
void PlayTone(char num){
int k,j,i;
int len;
time = 0;
switch (num){
case 0:
len = 100;
break;
case 1:
len = 150;
break;
case 2:
len = 200;
break;
case 3:
len = 250;
break;
case 4:
len = 0;
break;
if(!len) goto skipit;
for(k=80;k>0;k--){
LATBbits.LATB1 = 1;
for (i=len; i>0; i--);
LATBbits.LATB1 = 0;
goto doneit;
skipit:
if(pos){
for(k=0;k<30;k+=1){
for(j=0;j<70;j++){
LATBbits.LATB1 = 1;
for (i=k; i; i--);
LATBbits.LATB1 = 0;
for (i=k; i; i--);
pos = 0;
} else {
for(k=30;k>0;k-=1){
for(j=0;j<70;j++){
LATBbits.LATB1 = 1;
for (i=k; i; i--);
LATBbits.LATB1 = 0;
for (i=k; i; i--);
pos = 1;
doneit:
Nop();
| | #20 |
I changed it to turn off in 15 seconds since there is a 250ms delay for each time it loops i went and chaged time to equal 15 * 4(250ms delays) = 60
| | #21 |
| If you decide to go the NiMH rechargable route, go for the ones with a low self discharge. Panasonic calls it R2 technology. They have a lower capacity than regular NiMHs, but when used in low drain applications like yours, will last much longer.
__________________ Inside every little problem, is a big problem trying to get out. | |
| | #22 |
I have a LED using about 7-10ma when on (run mode) and my pic is taking about the same i suppose in run mode. So im using about 20mA of current + buzzer when in use. Now in sleep mode im using almost no current so i suppose it will last a mighty long time while sleeping I will look into those batteries thanks.
| | #23 |
Hi again, I am happy to hear you got the sleep mode working. I am always amazed at how little power the PIC chips can use when powered down and how useful this feature can be with todays battery operated devices. I was using a wireless thermometer as a refrigerator monitor that used three batteries about every two months. I got tired of changing the batteries, so with a $2 PIC chip and a cheap thermistor and a few tiny resistors and an LED i made a monitor myself, and it powers down for 3 seconds at a time, waking only to take a measurement and yell if something is wrong (temperature too high). Now the predicted life of the batteries is about 2 years. Quite a difference :-) Last edited by MrAl; 12th August 2009 at 08:12 PM. | |
| | #24 |
Nice work! Smart thing to use batteries. Some might tap off the frig. itself. But wounder why it wont scream when the temp is high if power gets cut you cant take temp or warn user. With batteries. Its on when it has to be and working with no external power... I feel like making a wireless sensor now lol
| | #25 |
hey guys more fun for my son lol i found a older toy ... its a green bow and arrow thing plastic. Without the bow part. It kind looks like a shotgun. But green lol I might mod it.... I made my buzzer make a cool laser shooting sound and i want to through it in it. With a nice RBG LED for when he presses the trigger it hits the button and plays the laser sound and flashes the led cool colors... here is the sound part i got so far...(also includes the sleep code too! Code: #include <p18Cxxx.h>
#include <delays.h>
#define button1 PORTBbits.RB0
#define MainButton PORTBbits.RB0
#define MainButtonT TRISBbits.TRISB0
#define MySec 3
char pos;
unsigned long time;
void ShootLaser(void);
#pragma code
LATAbits.LATA0 = 1;
ShootLaser();
void main(void){
int k,j,i;
pos = 0;
ADCON1 = 0xFF;
TRISB = 0x00;
TRISA = 0x00;
MainButtonT = 1;
INTCON = 0b11010000;
INTCON3 = 0x00;
RCON = 0b10000000;
time = 0;
while(1){
time++;
if(time == (MySec * 200000)){ //x seconds @ 8 MHz
NightTime();
void ShootLaser(void){
int k,j,i;
for(k=0;k<80;k+=1){
for(j=0;j<5;j++){
LATBbits.LATB1 = 1;
for (i=k; i; i--);
LATBbits.LATB1 = 0;
for (i=k; i; i--);
time = 0;
| | #26 |
Hi again, Just wondering, did you measure the chip current while it is in the sleep mode? Just to make sure it really went to sleep...i guess you read up on all this by now though anyway. | |
| | #27 |
heh never really checked it. Will do! thanks
| | #28 |
hey this is the outcome of my latest toy mod lol i find it cool! It was just a normal plastic gun nothing electronic inside. (not anymore) Toy Gun Mod
| | #29 |
Hello Jason, Here is a simple formula to use for finding the V-junction between 2 resistors V-junc = V x resistor B / total resistance of A & B where resistor A is connected to V+ and B is connected to ground. I found this formula in an electronics book. Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | |
| divider, voltage |
| Voltage divider | Electronics4you | General Electronics Chat | 15 | 28th October 2009 06:23 PM |
| voltage divider for oscilloscope. | fugrammer | General Electronics Chat | 3 | 13th November 2008 11:58 AM |
| Voltage Divider Question. | shaneshane1 | General Electronics Chat | 9 | 13th May 2008 03:47 AM |
| voltage divider | samtheboxer | Electronic Projects Design/Ideas/Reviews | 3 | 25th July 2007 02:19 PM |
| Voltage divider | raphaelriv | General Electronics Chat | 11 | 26th July 2006 09:13 PM |
