Old 10th August 2009, 12:35 PM   #1
Default LTSpice
is it possible to simulate (plot) max. power transfered to load by changing R load in LTSpice?
t.man is offline
Old 10th August 2009, 12:41 PM   #2
What do you mean?
It's easy to plot the power dissipated by a load, just set the trace expression to (V(nXXXX)-V(nXXXX))*I(Load)
V(nXXXX) are the nodes at either side of the load.
if I know the answer.
Hero999 is offline
Old 10th August 2009, 01:02 PM   #3
Originally Posted by Hero999 View Post
What do you mean?
what i mean is that; i want to vary the value of R load and plot the power dissipated to load resistance. hence be able to see the maximum power dissipated to the load.
ok?
t.man is offline
Old 10th August 2009, 01:15 PM   #4
No, I don't know how to do that.
Hero999 is offline
Old 10th August 2009, 01:21 PM   #5
hi t,
Is this what you are asking.?
File Type: asc ParaTherm1a.asc (498 Bytes, 15 views)
ericgibbs is offline
Old 10th August 2009, 01:35 PM   #6
hi t,
Another example.
Click RUN, place the cursor on the load resistor so that the meter icon is displayed and press the ALT key to show a thermometer icon.
File Type: asc ParaTherm1b.asc (538 Bytes, 12 views)
Old 10th August 2009, 03:29 PM   #7
ok?
Do you mean the peak power or the average power?
The peak power can be had the way Hero told you about.
If you need the average power you would integrate i(t)*e(t)
over all time, which is the same as using an RC filter on i(t)*e(t)
where the time constant is large compared to the change in
the amplitude of the waveform.
MrAl is offline
Old 11th August 2009, 09:43 AM   #8
Originally Posted by ericgibbs View Post
hi t,
hi eric,
ok, i'm using PSpice now.
actually what i was thinking is this (if i'm right, ok?);
looking at the circuit below, RL (or R9) will dissipate maximum power when equals to thervenin resistance( which equals 230.8k if i'm correct).
i was expecting power to increase till R9= 230.8k then decrease afterwards.
am i right? if yes, why isn't the case here looking at the plot.
t.man is offline
Old 11th August 2009, 10:16 AM   #9
hi eric,
hi t,
Please post your asc file.
Old 11th August 2009, 11:45 AM   #10
hi t,
hi, eric
i think i've got it.
i've created RL as a global parameter.
isn't what i should expect?
t.man is offline
Old 11th August 2009, 12:08 PM   #11
hi, eric
hi t,
Please post your asc file, in that way I can compare your results without having to build the sim.
I would suggest that you look in spice tools menu and change the plot background colour to white , also make the plot lines wide/thick.
Old 11th August 2009, 02:06 PM   #12
hi t,
i can't identify asc file in my project files. where can i find it?
t.man is offline
Old 12th August 2009, 03:47 AM   #13
Eric, he's using Pspice now. I suspect that's why he can't find the .ASC file.
Ron
Roff is offline
Old 12th August 2009, 07:37 AM   #14
Thanks Ron for confirming that.
ltspice
LTSpice codan General Electronics Chat 14 5th May 2009 10:47 PM
LTSpice issue... smanches General Electronics Chat 14 24th April 2009 12:50 AM
How to add subcurcuit into LTspice? victous General Electronics Chat 0 18th February 2009 01:26 PM
LTSpice op-amps CynicalMan General Electronics Chat 9 22nd November 2008 06:05 PM
Ltspice or Sim Electronics!! silvarblade Electronic Projects Design/Ideas/Reviews 0 23rd June 2008 07:39 AM
