| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
how to build a circuit that acts like this graph http://i32.tinypic.com/ivfipx.gif i am only allowed to use a linear components a simple diode,simple E1 source simple E2 source simple resistor i know that the middle climb is a charging capacitor there so many switching of modes i dont know how to start thing of that? i dont want the solution right away i want guidance so by answering your questions i will get to the solution myself | |
Two comments: 1) It could be a diode creating the jump at the beginning 2) What happens when a capacitor is full? It levels off. I might be way off, but hey, you never know | |
a diode is like a switch if it has a negative voltage on it we would have open circuit then if we switch the voltage to positive then it will remain an open circuit but after the transition period it will be short circuit so i think that it cannot create a jump | |
Hi, There is a discontinuity in the circuit where it jumps up suddenly. That means there has to be at least one switch in the circuit. | |
only diodes can act as a switch no actual switches allowed | |
| | #6 |
A diode will not conduct until there is the 0.7V drop (for silicon) requirement met.
| | #7 |
i attach it
| | #8 |
how you came up with this sketch ? | |
| | #9 |
Hello, Sorry, i couldnt get that three diode circuit to produce the required waveform. I might have missed something so let me know if so. Here is a circuit that provides the required waveform using only diodes, resistors, constant voltage sources, and one input voltage (V1). Im not sure if this is the kind of solution you wanted or not so take a look... | |
| | #10 |
Hi again, Here is a more straightforward circuit. You can try to figure out why the resistor values are such that they are and why the voltage levels are what they are. All the knee places are easy to set with this circuit. Last edited by MrAl; 1st August 2009 at 05:15 PM. | |
| | #11 |
here is the solution of the teacher: can you describe it so i could understand what is the inner logic in here: http://i32.tinypic.com/28b7j7n.gif | |
| | #12 |
Hello again, The original waveform has these characteristics in the order shown: 1. The output starts out negative (E2). 2. While the input is still negative, the output jumps up suddenly through zero. 3. The output ramps up, passes through the x axis, then stops rising at E1. 4. The output remains at E1 after that. The above gives us three corners: 1. At some negative Vin and Vout 2. With Vout positive and Vin still negative 3. With both Vin and Vout positive I dont see three corners in your teachers solution, only two. The input starts off very negative, and R conducts and D2 conducts and E2 keeps the output clamped at -E2. As the input rises, eventually it reachs the same voltage as -E2 and that means there is no current flowing in R and D2 stops conducting. The output is now still at -E2 though because the input is at -E2. Now the input rises a bit more and so the output rises too, but it must be ramping already because Vin is ramping over time. Thus, the output ramps through zero and does not jump up suddenly as the waveform picture shows it should. Eventually the input reachs E1, and then diode D1 clamps the output to E1 so it remains at E1. What the above means is that there is no jump discontinuity as the original waveform drawing shows. You'll have to ask the teacher why the waveform shows a jump when the circuit given does not seem to have that kind of response. By adding R2 in the drawing below i can get it to look like a jump occurs, but the jump only happens near the x axis, not before it. The entire jump is supposed to be over with before the input reaches zero. Also, then the output ramps up but there is no clamp at the end. I included the original waveform drawing and the circuit your teacher gave too, and the last schematic is the new circuit but that doesnt work exactly right either. Last edited by MrAl; 2nd August 2009 at 01:54 AM. Reason: Added pic | |
| | #13 |
It's not that circuit. That circuit clamps the output if input is less then E2-diode drop or greater then E1+diode drop. Between these two points Vout = Vin. Last edited by RCinFLA; 2nd August 2009 at 01:48 AM. | |
| | #14 |
Hi, I gave a full description in my previous post, you may have posted at the same time that i did. | |
| | #15 |
Hi again, Here is the drawing of the original waveform along with the teachers solution and the teachers solution with an added resistor just to show how the resistor forms a slope. The waveforms for each circuit are shown just to the right of each circuit. | |
| acts, build, circuit |
| Build Circuit Using PIC Microcontroller | young707082 | Electronic Projects Design/Ideas/Reviews | 24 | 22nd June 2009 09:21 AM |
| how to build this circuit?? | italianman1987 | General Electronics Chat | 1 | 4th December 2008 09:22 AM |
| Circuit acts unexpectedly...please explain | strokedmaro | General Electronics Chat | 3 | 26th February 2008 04:47 AM |
| 3 acts in a row! | ThermalRunaway | Chit-Chat | 16 | 6th September 2007 08:45 PM |
| Pls Help me build this circuit | Fuad | Micro Controllers | 0 | 24th May 2003 11:52 PM |
