| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
How accurate does it need to be? The simple approximation is to simply subtract the typical forward voltage drop from the power supply then perform the normal RC transient calculation. The more precise is to use the diode equation in conjunction with the RC transient differential equation. My maths isn't good enough to work it out so I'd turn to SPICE for help.
Hi again, Hero: Yes in many of these circuits they are using an ideal diode, with no voltage drop, but in these circuits they appear to be using a first approximation to a real diode which is an idea diode with a voltage drop. Transgalactic: In circuit 1 you have to figure out the initial capacitor voltage for when t<0, and that shouldnt be too hard. Then you have to find the time response up to the point where the diode conducts (sometime after t=0) and then the diode acts as a voltage 'clamp'. When the diode acts as a voltage clamp, it looks like an ideal diode (no voltage drop) in series with a small battery equal to the voltage drop v_0 with the (+) terminal connected to the cathode of the diode. In circuit 2, the diode is probably the same as in circuit 1, where it drops v_0 volts. The only difference here is that if it drops v_0 volts then it will affect the step response by subtracting v_0 voltage from the source. In the following drawing, Vb=v_0 Last edited by MrAl; 20th July 2009 at 02:56 AM. | |
in the second circuit will the diode be open circuit or short circuit in the transition period ?? | |
Hi, It will be short circuit, unless you consider it to be like the diode in the first circuit when then it will drop a voltage equal to v_0 volts. For example, if v_0=0.7v then the diode will drop 0.7 volts. This means 0.7v will be subtracted from the unit step input. If you consider th diode to be totally ideal, then it will not drop any voltage. | |
| | #6 |
1. regarding the first circuit: "when then it will drop a voltage equal to v_0 volts. For example, if v_0=0.7v then the diode will drop 0.7 volts. This means 0.7v will be subtracted from the unit step input." i know that when we have a positive voltage the diode will be short circuit so in time t>0 we have a positive voltage why its still an open circuit??(it should be short circuit) i cant understand this drop thing 2.in both circuit there are cap's which in parallel to the diode so the voltage on the diode is the voltage on the cap and because vc(0-)=vc(0+) in 1st circuit vc(0-)=-v0 in 2nd circuit vc(0-)=0 so both diodes has to be open circuit in the transition period because there is no positive voltage on them ??? Last edited by transgalactic; 20th July 2009 at 07:04 AM. | |
| | #7 |
[1] For the first circuit... For the time between t=0 and t=t1 the diode is an open circuit. It is open until Vc comes up to equal v_0. This means you have to solve for the time t1 when this happens. Since Vs=-Vo for t<0 that means you have to first solve for Vc(0-) and then take it from there to solve for t1. Keep in mind that in that drawing v_0 is not Vc(0), it is the diode drop (assumed to be constant). If you need to see the math let me know. [2] For 1st circuit, you have to solve for Vc and since Vs=-Vo then the voltage on the cap will be the voltage as if the diode wasnt there. When Vs goes positive, the cap starts charging positive and you then solve for t1. For the 2nd circuit, we assume Vc(0)=0, and for the unit step the peak voltage is 1-Vdiode, and so instead of the unit step we have (1-Vdiode)*u(t), which is less than u(t). For the impulse source however, the diode is insignificant even if it has a voltage drop, so the diode is a short for the impulse source. It will also be a short for the unit step response too but only if you consider the diode voltage drop to be zero (ideal diode). For the first approximation diode (vdiode=0.7) we would end up with a 0.7v voltage drop, for example, so the source would be u(t)-0.7 which is 0.3*u(t). For the impulse source, delta(t)-0.7=delta(t) which is no change. Note that in the 2nd circuit there is a postive voltage on the diode at t=0+ because the unit step or the impulse puts it there immediately and the cap voltage is zero. Last edited by MrAl; 20th July 2009 at 11:10 AM. | |
| | #8 |
there is no u(t) in the circuit ??? what is a drop? | |
| | #9 |
Hi, Sure there is... u(t) is the unit step function. A voltage drop is an increase or decrease in voltage between two nodes in the circuit. Code: o----R----o n1 n2 a 2v voltage 'drop' between n1 and n2. If n1 is at 3v and n2 is at 5v, we still say there is a voltage drop between n2 and n1. Thus, when we say 'drop' the polarity is obvious from other references. Last edited by MrAl; 20th July 2009 at 03:19 PM. | |
| | #10 |
ok so there needs to be a positive drop on the diode in order for it to work how the drop on the diode changes in both cases?? | |
| | #11 |
Hi again, Yes the diode needs a positive drop (anode positive, cathode negative) in order to conduct current. There are a few differences with different diode models however. Here are three types: ['Vanode' is the voltage at the anode referenced to ground, and 'Vcathode' is the voltage at the cathode referenced to ground] 1. Ideal (perfect diode): This diode conducts perfectly when Vanode>=Vcathode. In other words, this diode is a short when Vanode>=Vcathode. and there is no voltage drop. This diode is a complete open circuit when Vanode<Vcathode. We might call this diode the 'perfect' diode, but it's often called 'ideal'. 2. First approximation Ideal Diode (perfect diode with voltage drop): This diode conducts when Vanode>=(Vcathode+vd) where vd is the voltage drop of the diode when conducting, considered to be a constant over all time and for all currents. This diode does not conduct when Vanode<Vcathode. Once conducting, the diode acts as an opposing voltage source who's voltage equals vd, the characteristic voltage drop of the diode. 3. Ideal Diode with Exponential Response: This diode uses the "Ideal diode equation" and that involves either an exponential or a log to calculate. This diode is like the first approximation diode, except that it has a voltage drop that depends on a log and a current that depends on an exponential: I=IS*(exp^(v/(N*Vt))-1) V=N*Vt*ln(i/IS+1) where N and IS are constants, and Vt is the 'thermal voltage' equal to k*T/q which equals about 26mv at 27 degrees C. This diode is used in more advanced studies though, and often includes a series resistance Rs. Now for these problems they are probably using either the perfect diode or the perfect diode with voltage drop. The two different diodes will make a difference when we go to analyze the response to a unit step because the one that has a voltage drop (like 0.5 or 0.7) will act like a small battery in series opposing the source and so that subtracts from the unit step to produce a smaller driving voltage step. The diode that does not have a voltage drop (diode 1) will not subtract anything from the driving source, so the unit step remains the same as if no diode were present. On the other hand, when we go to analyze the response to an impulse it doesnt matter what diode we choose (1, 2, or 3 above) because the voltage drop does not matter. Thus, we can short out the diode when we analyze the response to an impulse, except that we also remove the short after t=0+. Thus, the diode conducts only around t=0, after which the cap charges up instantaneously and and when the impulse goes back to zero the diode goes to an open circuit. Last edited by MrAl; 21st July 2009 at 07:57 AM. | |
| act, diode, period, situations, transition |
| How to say which board was the first to detect a transition | atferrari | Micro Controllers | 2 | 24th August 2007 12:35 AM |
| Transition to widescreen monitor | SimonW | General Electronics Chat | 5 | 31st July 2007 02:37 PM |
| Testing for transition 255 to 0 | atferrari | Micro Controllers | 10 | 28th January 2007 03:42 PM |
| Pulse in negative and positive transition | leonel | Electronic Projects Design/Ideas/Reviews | 12 | 5th January 2006 09:00 AM |
| state transition matrix | niga | General Electronics Chat | 9 | 10th July 2005 05:10 AM |
