| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
for this signal i have this equation then the next line is why they substitute j=I_s | |
put in your mind that j = 90 Deg
__________________ Its what your friend in Your mind, what you in your friends mind | |
no its not 90 deg Last edited by transgalactic; 18th July 2009 at 06:54 AM. | |
| | #4 | |
the formula of the signal is then we transform it to the phasor representation formula so we get and when we look at this expression as oilers formula we get the Is=-j so why its written Is=j ? Last edited by transgalactic; 18th July 2009 at 07:38 AM. | ||
Hi, Isnt that just j*w with w=1? sin(t) is sin(w*t) or sin(1*t). For ac analysis, s is made equal to j*w and j*w is used to represent a sinusoidal source. Last edited by MrAl; 18th July 2009 at 03:18 PM. | |
| | #6 |
| and it is 90 deg for example: 2j = 2 at angle of 90 deg
| | #7 |
by what formula?
| | #8 |
| without formula it is well known in Electrical engineering that the difference between 2 which means ( 2 ± 0j ) and 2j which means ( 0 + 2j ), is that although they are representing the same magnitude, but the are 90 deg apart. If you added them together, they gives 2 + 2j in rectangular form , which equals to 2.83 with 45 deg or in polar form. complex number is explained in: Complex Number -- from Wolfram MathWorld check Euler formula link, you may find the answer for your problem.
__________________ Its what your friend in Your mind, what you in your friends mind Last edited by aljamri; 19th July 2009 at 10:29 AM. | |
| phazor, question |
