View Poll Results: Interested in transformer design
wow, yes, it's fascinating 12 85.71%
nahh, I hate robots in disguise 2 14.29%
Voters: 14. You may not vote on this poll
Old 28th June 2009, 08:03 PM   #16
I'd like that, it also be good if you released the source code.
if I know the answer.
Hero999 is offline
Old 28th June 2009, 10:33 PM   #17
there isn't any source code, as i said before, DATASTAR is a database application that can perform very basic lookup and calculations.
I have been using it for 15 years, the folder contains the .com files, all my database definition files, all the data files and every design i have done in that time.
3.84mb
gotta love dos
Drake Transformers Transformer Designer. 1992-1997
Dagnall Electronics / Clairtronic Transformer Designer. 1997-2009
Now going it alone
grim is offline
Old 28th June 2009, 10:44 PM   #18
3.84MB is monstrous for a DOS application that isn't a game.
Most DOS programs tend to be under 1.44MB, one floppy disk.
Hero999 is offline
Old 28th June 2009, 11:28 PM   #19
Well grim, shouldnt the data and calculation formulas be an a form that anyone
can read? What is this DATASTOR?
MrAl is offline
Old 29th June 2009, 09:48 AM   #20
the .com file is 32k, it's the 15 years of records that have got it to this size..anway, i digress
Now going it alone
grim is offline
Old 29th June 2009, 06:33 PM   #21
Hi Grim. I don't see a link to your site. Do you have it set up? Can we have a peek?
Bob
Bob Scott is offline
Old 30th June 2009, 05:06 PM   #22
nooo it's a secret
I would love to say it is under construction, but it's more like 'under construction once i learn dreamweaver'
Now going it alone
grim is offline
Old 30th June 2009, 05:37 PM   #23
Hi again grim,
So when can we expect to see some of this transformer work materialize?
MrAl is offline
Old 30th June 2009, 05:53 PM   #24
Originally Posted by grim View Post
nooo it's a secret
Hahahaha......its more like...when I learn how to use a pc for me....
If you need any help with DW let me know, my son is a wiz with computers ( J.Rudd Bsc Hons, Computer Science 2008)
Eccentric millionaire financed by 'er indoors
Chippie is online now
Old 30th June 2009, 08:05 PM   #25
I think its a excelent idea .
For a lot of people magnetics design borders *black magic*
Although i did design a few transformers by now i must confess that i used shortcut's
Better said i cutted out half of the calculations ,and withdrew my lines to the most important .
Skindepth ,current density ,the amount of windings for the desired fieldstrength in the core and further it was Vpri/Vsec = Npri/Nsec .
All the finer details like temperature rise of the wire & core etc. etc. are for now lost in the process .
(although when i ever get the time to study the topic further i certainly will)
For now it works ,and it did do the job but i would love to learn more about magnetic design .
Probably like many of us i neglected the subject after school and only got to use it 15 years later (damn that math cracks my nutt)
walkura is offline
Old 1st July 2009, 01:39 AM   #26
Yes, that would great if you could post your design program or site. I actually just accepted a engineering job a few weeks ago, and am getting into single and three phase power transformer design now. It would interesting to see what you have, especially any tips. It is quite an undertaking to design some of the larger three phase transformers, especially when you go from design in college, to design in a career where it seems already the largest constraint is MONEY.
That would awesome. Especially if it could be changed and redone to run on Linux.
PhillDubya is offline
Old 1st July 2009, 09:52 AM   #27
ALL the program does is speed up the calculations, and i will explain those.
like everything, it's complicated and mystical until you understand the how and why - which you can then promptly forget.
The industry hasn't changed in the last 50 years probably, so every design that can be done, has been. I am amazed I even have a job - or had one.
For example there is probably a formula somewhere for calculating the power you can get on a core size, but no one uses it, because we all know that a 29 by one is 50VA. I have access to over 10,000 designs. Somewhere the one you want has been done before.
What I would say to anyone thinking of making their own transformer is, DON'T. There are hundreds of transformer companies in the country, and I suspect that applies to a lot of other countries. they have access to the materials and equipment, and can design it for you. Unlike virtually every other component out there, you can order a small batch, or a one off.
If you wanted a 50va that was really special, with 12.43V secondary and a 123v secondary and a primary of 98V, it would be the same as ordering a Big Mac, no relish. They don't have to order in different buns and processed meat substitute, they just make you a standard burger, and don't put in relish.
It's not like asking Intel for a Pentium chip with a slightly different clock frequency
Now going it alone
grim is offline
design, transformer
Have you worked with AT25128A flash? rainman1 Micro Controllers 1 16th March 2009 12:22 PM
how is this worked out? ohms law question gjpollitt General Electronics Chat 11 10th August 2005 11:29 PM
how to design ei transformer butobhones Electronic Projects Design/Ideas/Reviews 1 3rd August 2005 04:00 PM
Have I worked it out? tim_l_012 General Electronics Chat 2 23rd February 2004 03:20 PM
IT WORKED!!!!!!!!!!!!!! ElectroGeek_87 Micro Controllers 0 13th September 2003 06:46 PM
