Old 23rd June 2009, 09:41 PM   #1
Default Why is LED controlled by current?
Hey,
In one of the threads in the General Electronics forum I wrote about a problem that I encountered.
I wanted to design a driver circuit for a blue LED which its VF has spreaded out from 3V (min) to 3.8 (max), that is according to datasheet.
The blue LED IF is 20mA.
I was adviced to use a current source, that will provide 20mA for every of these blue LEDs, and was told that both 3V and 3.8V blue LEDs consume 20mA current.
Therefore I wanted to ask, how come 3V and 3.8V LEDs consume the same current in order to illuminate at the same intensity?
Thank you.
alphacat is offline
Old 23rd June 2009, 10:42 PM   #2
Manufacturing tolerances?
Eccentric millionaire financed by 'er indoors
Chippie is offline
Old 23rd June 2009, 11:15 PM   #3
I meant, if a 3V blue LED consumes 20mA, wouldnt you expect a 3.8V blue LED to consume more than 20mA, in order to illuminate at the same intensity as the 3V one?
alphacat is offline
Old 23rd June 2009, 11:38 PM   #4
No, the 3.8V LED should require less current assuming the efficiencies are the same which they won't be.
if I know the answer.
Hero999 is offline
Old 24th June 2009, 12:31 AM   #5
Do not confuse current with power.
Power in Watts = Amps x Volts
or
P=IV
BCHS/3v0's Tutorials
3v0 is online now
Old 24th June 2009, 10:16 AM   #6
Thelink below is from the Otherpower Forum and is the 5th installment of the LED masterclass written by a user called commanda.
the Otherpower.com Discussion Board || Led master class pt 5
Just click on the link at the start of the thread to go back to the first one ( just remember to make sure it opens in a new tab or window) and I recommend every Newbie to read what those threads have to show as some very ingenious circuits for driving multiple led's. I have made the circuit up myself using 4 off 550,000mcd white leds in series and for the last 3 years it's been going 24/7 in my shed powered off my nife batteries.
Regards Bryan
bryan1 is offline
Old 24th June 2009, 12:54 PM   #7
No one has mentioned the correlation between LED color and its chemistry. On top of that, throw in what temperature the junction must be at to emit a particular wavelength of light and how much current that takes... and how that in turn relates to its forward voltage… etc.
indulis is offline
Old 24th June 2009, 04:02 PM   #8
Wikipedia:
This effect is called electroluminescence and the color of the light is determined by the energy gap of the semiconductor.
I will not pretend to know what they mean by energy gap. But I was under the impression that the color is not related to heat as in incandescence.
3v0 is online now
Old 24th June 2009, 06:38 PM   #9
Thanks guys.
Energy gap in semiconductors is the amount of energy thats needed for an electron in the valence band to pass to the conduction band.
alphacat is offline
Old 25th June 2009, 11:08 AM   #10
Hi there,
The voltage is something that is a bit harder to control in the manufacturing
process. The way the device reacts to current however is roughly the same
all the time, or varies in a way that doesnt really hurt anything.
The small LEDs take 20ma but their efficiencies can vary, so one LED might
have a different voltage than the other.
This voltage is usually called the "Characteristic Voltage", but sometimes when
the average voltage among many devices is mentioned it is called the
"Nominal Voltage".
It's nice to know though that the intensity curve is drawn with Intensity vs Current,
so when we drive the LED with a certain current we know we can get a certain
intensity. We also, at the same time, know that the LED should be relatively
safe if we stick with the current recommended by the manufacturer, letting
the voltage go to whatever it needs to be for that particular LED.
MrAl is offline
Old 25th June 2009, 12:40 PM   #11
The only point I was raising was that each different color LED has its own unique chemistry. And in order for a particular chemistry to emit visible light the junction must be raised to a certain temperature range which is done via current passing thru it, which correlates to a certain forward voltage. When a LED is spec’ed at say 20mA, that doesn’t mean you have to have 20mA of current flowing through it to make the LED “light”. That 20mA relates to a certain wavelength/intensity which will cause a certain forward voltage, and vise versa if you will.
indulis is offline
Old 25th June 2009, 05:33 PM   #12
Yes, i believe that is a very good point too. That's why different colors
have different forward voltages and it's good to have a feel for these
differences when using the various LEDs out there.
There is also difference between the 'regular' LEDs and the 'high brightness'
LEDs.
MrAl is offline
Old 26th June 2009, 01:31 PM   #13
Thank you guys, i learned a lot from this thread.
Its always wonderful to read your answers MrAl.
alphacat is offline
Old 26th June 2009, 02:28 PM   #14
LEDs.
Hi.
Being true the fact that different color LED's have different forward voltages, i think it has less to with the current it can be operated upon and more on the material used.Increasing voltage and inherently current causes an LED to turn a dull green(for a white 5mm LED atleast) before it burns which shows that temperature does not have a huge effect on LED color other wise its colors would be going haywire before it burns out.
Syed
Wond3rboy is offline
Old 26th June 2009, 09:41 PM   #15
Hello again,
Yes the semiconductor material is what causes the different color, except for white
which also uses phosphor. The different material also causes a different characteristic
voltage.
MrAl is offline
controlled, current, led
voltage controlled current source design wtwendy Electronic Projects Design/Ideas/Reviews 4 23rd May 2009 11:01 PM
Help:Digitally controlled current source abicash Electronic Projects Design/Ideas/Reviews 20 4th May 2009 08:07 AM
Voltage controlled current source Analog2008 Electronic Projects Design/Ideas/Reviews 2 2nd January 2009 08:54 AM
Possible to have variable resistor controlled via current or voltage? excetara2 General Electronics Chat 6 7th April 2008 11:18 PM
Why is a transistor a current controlled device Faiyaz General Electronics Chat 8 29th October 2003 06:51 PM
