Old 18th June 2009, 06:33 PM   #1
Default C charged by L above its rated V = ?
Suppose the initial circuit is as in 1 on my sketch.
After all transients have died away the current through inductor L is V/R
The capacitor has an intial voltage of V on it
Then the swicth 1 opens and 2 closes
The inductor will supply current V/R to the capacitor depositing a charge Q.
However what i would like to know is, if the capacitor is rated at voltage V, what will happen?
Will the capacitor explode?
confounded is offline
Old 18th June 2009, 06:47 PM   #2
Short answer:
Yes if there is enough energy. No if there is only enough energy to
short it out and discharge the inductor and the remaining current
isnt enough to blow it up (depends on actual supply voltage internal
resistance).
Sometimes a cap will arc over and then seem to work ok after that too.
What you have there if you make R very low is basically a boost converter.
The voltage to the cap gets boosted up to a voltage higher than the
supply voltage. If the voltage is too high, the cap either blows out or
explodes.
I've seen large electrolytic caps blow up like cannons.
MrAl is offline
Old 18th June 2009, 06:53 PM   #3
lol so i also have a capacitor detonator
Thank you for replying i wasnt sure of how a capacitor behaves in this situation. I assumed something bad would happen but needed to get it confirmed
Old 19th June 2009, 05:53 PM   #4
I remember back in one school i went to we used to blow up stuff just to
see what it would take...sort of like the Mythbusters of electronic parts.
We preferred resistors as they made a lot of smoke before they blew. With
enough energy though (mains) we could get them to pop like firecrackers.
This may sound like silly fun, but it actually taught me the dangers that can
come up when dealing with high energy and regular electronic components.
The possibility for personal injury is always a factor.
I've also seen high power metal case transistors blow from too much current
(huge overcurrent) and i can tell you that is not something you want your
eyes (or anything else for that matter) in line with. The HOT metal and si
go flying in all directions as the case melts and spews out.
Eye protection is a must.
MrAl is offline
charged, rated
LA Battery not getting fully charged sivankls Renewable Energy 18 29th October 2009 07:19 AM
stop the battery from over charged how? munir Electronic Projects Design/Ideas/Reviews 3 13th February 2009 08:46 PM
What is an X2 rated capacitor? William At MyBlueRoom Datasheet/Parts Requests 3 24th November 2006 11:51 PM
When to use X2 rated capacitors Dave#2 General Electronics Chat 4 28th April 2006 12:53 AM
Charged battery the wrong way! hantto General Electronics Chat 2 28th January 2004 09:23 PM
