Old 13th June 2009, 09:20 AM   #1
Default Why is constant current region desired in amplifers?
I read that in CE amplifier, its desirable to bring the amplifier into the constant current region.
Is this region also called forward bias region where iC = beta * iB?
And why is it desirable to insert it into that region?
Thanks.
electricity86 is offline
Old 13th June 2009, 08:12 PM   #2
Because a transistor is a current controlled current source?
Willbe is offline
Old 13th June 2009, 10:59 PM   #3
I still dont understand why should it be in the constant current region?
In the saturation region, the current is not constant for different values of VCE, why cant it be there?
Old 13th June 2009, 11:13 PM   #4
It can't be in the saturation region for the very reason that the current is not constant for different values of Vce. You have to remember we want to amplify the base signal and we want to amplify it linearily.
You want to be in the constant current region because in this region, the collector current (which produces the output signal via the collector resistor) is mainly dependent on the base current and it's dependence on the the collector-emitter voltage is greatly reduced. In the saturation region, the collector current is dependent on both the base current and collector-emitter voltage. Your gain is not constant for all values of Ib because the gain is now influenced by collector-emitter voltage (which in turn is influenced by collector current running through the resistor producing a voltage).
The voltage output is being produced by the collector current running through the resistor. When the collector current changes due to a change in the input signal current at the base, the voltage across the resistor will change. But so will the collector-emitter voltage since resistor and CE are in series with the same fixed voltage source. In the saturation region, this means that your output voltage is dependent on base current and collector-emitter current. In the constant current region, the collector current is pretty much unaffected by collector-emitter voltage so much of this dependency is removed.
Look at the load line on the attached graph. Imagine what would happen if it was running through the saturation region instead of the constant current region.
dknguyen is offline
Old 14th June 2009, 12:08 AM   #5
That is because you want the amplifier to be linear with a minimum amount of distortion. If you go into the saturation or cutoff region, you'll have clipping and thus a lot of distortion.
kchriste is online now
Old 14th June 2009, 02:02 AM   #6
Is there going to be an exam? Heh!
BrownOut is online now
amplifers, constant, current, desired, region
Constant Current Driver??? retic Electronic Projects Design/Ideas/Reviews 6 29th January 2009 08:43 PM
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 1 4th October 2008 01:26 AM
Constant DC current source Affan Electronic Projects Design/Ideas/Reviews 26 4th May 2008 01:38 PM
Constant Current Source graemec General Electronics Chat 12 1st September 2006 04:21 PM
Will current Mirror circuit deliver constant current to LED? Haru General Electronics Chat 10 14th April 2005 11:07 AM
