Old 9th June 2009, 04:48 PM   #1
Default Analog motor controller
Hi.
Once a time several years ago I came over some theory about a motor controller. What I remember now is this:
It contains 4 opamps. One integrator, one differentiator and a regular noninverting opamp amplifier stage. Then I think all three stages mentioned above had their input connected together and I also think that the output from the three stages went into a adder circuit.
The input comes from a frequenzy to voltage converter on the motor shaft.
However I don't know what this technique is called and therefore it's impossible to google for it. Anybody knows?
Grossel is offline
Old 9th June 2009, 05:00 PM   #2
pulse width modulation with feedback from a tacho on the motor shaft.
Eccentric millionaire financed by 'er indoors
Chippie is offline
Old 10th June 2009, 12:40 AM   #3
Originally Posted by Grossel View Post
Hi.
I don't know what all those circuits you mentioned do, but the techniques are fairly standardized these days. I think most of the motor types are single phase AC induction motors. They call them induction motors because the secondary windings (squirrel cage) have no direct electrical connection. The electricity in the squirrel cage is induced from the electromagnetic field of the primary windings. In a free running (uncontrolled) AC motor there is a START capacitor in-line with the secondary windings to shift the phase by 90 degrees so that the motor will begin to rotate, then a centrifuge switch will drop out the phase shifting capacitor after it begins to rotate.
Now days they use the same techniques as a power inverter where the motor windings are considered like a transformer. So the input AC line voltage is rectified and fed into an oscillator circuit as is done with an inverter. Then as the guy before me said, they use pulse width modulation to control the speed of the motor rotation.
Here's some good websites to get you started:
Three Ways to Control a Single-Phase Induction Motor - 2004-12-13 00:00:00 | Design News
Schematics For: 1Ø Split Phase Motors - Series 2 - ECN Electrical Forums
Space Varmint is offline
Old 10th June 2009, 09:42 AM   #4
The motor could be a universal type rather than an inductive?
Just a thought
Chippie is offline
Old 10th June 2009, 10:51 AM   #5
Just a thought
Oh man, They even use 3 phase off the same theory. I think that they mostly use what I was describing, but I'm no expert by any means. I have never followed through with any design of this sort. It's just that I was bidding a job recently where they needed extra efficiency, and that was some of the stuff I came across in my research.
Old 10th June 2009, 12:32 PM   #6
Hello,
It was a PID controller circuit.
Almost every controller (probably every one) contains a P controller, but when you add the I and D you
get better control. The P makes the basic controller, the D is so the control has a faster response,
and the I is to get lower steady state error.
MrAl is offline
Old 10th June 2009, 12:43 PM   #7
Proportional, Integral and Derivative are the three terms...
Derivative is commonly used in temperature control loops to reduce Dv/Dt lags.....
Chippie is offline
Old 10th June 2009, 12:56 PM   #8
First of all, you seem to be experienced in this stuff Chippie.
Second of all, MrAl is just a genius.
Old 10th June 2009, 12:58 PM   #9
I'm a time served Instrument Technician.....
Chippie is offline
Old 10th June 2009, 01:02 PM   #10
Default Wireless robots
Well friends
i m beginner well i have made a wired racer robo car but now i want to convert it into wireless
so please guide me wat to do please from starting to end
himanshusinha is offline
Old 10th June 2009, 01:12 PM   #11
Originally Posted by himanshusinha View Post
Well friends
You should start a new thread!
Chippie is offline
Old 10th June 2009, 01:20 PM   #12
Well, you don't sound like no dummy
But yeah, what's with this other guy? He wants us to build him a robot in the motor thread....lol
Old 10th June 2009, 08:23 PM   #13
Originally Posted by MrAl View Post
Hello,
Thanks a lot
Problem solved.
It's a "dumb" problem really, but for a no-native english it make the difference between know-how and completely confusion
Grossel is offline
Old 10th June 2009, 08:28 PM   #14
The motor is just a regular DC. It's not important what is between the adder circuit and the motor.
Do you just want to control the speed of the motor?
A pwm cct will do that for you...search for PWM motor control..
Chippie is offline
controller, motor, name of
dc motor controller for treadmill motor wistlepig1 Electronic Projects Design/Ideas/Reviews 9 6th April 2009 02:18 AM
Analog control of a Stepper Motor Aberdeen57 Electronic Projects Design/Ideas/Reviews 8 5th December 2008 10:10 PM
Smooth Analog Stepper Motor Control Bob Scott Electronic Projects Design/Ideas/Reviews 6 1st March 2008 02:54 PM
R/C Motor controller windozeuser General Electronics Chat 3 10th February 2006 05:38 AM
Motor controller for a e-motor/generator Combo dreamtoys Electronic Projects Design/Ideas/Reviews 1 4th October 2003 12:42 AM
