Old 26th March 2009, 05:44 PM   #1
Default question about sensing resistors
is a sensing resistor a special kind of resistor, or is it just a resistor that is being used to make current detection possible? The issue in particular is that I have this motor driver with a connection diagram calling for a 10 ohm current sensing resistor and I'm not sure if thats just requireing 10 ohms of resistence there or something specialized.
Triode is offline
Old 26th March 2009, 06:18 PM   #2
Nope, just 10 ohms of resistance, generally they're 'overbuilt' resistors, so they dissipate heat well, nothing really special about them though.
straight answer, har har."
Sceadwian is offline
Old 26th March 2009, 08:28 PM   #3
THey aren't anything special. They are usually just much lower resistance (milliohm range) than other resistors with much better heat dissipation/current capability. They might also be made to handle surges better and have lower inductance because they are often used in motor switching applications.
Nothing really says you can't use a regular low value resistor. It's pretty hard to find a 10ohm resistor labelled as current sense anyways since that's very high resistor for most current sensing.
dknguyen is offline
Old 28th March 2009, 08:52 PM   #4
But keep in mind:
If resistor gets hot resistance may change, perhaps enough to matter, or not. Oversizing the resistor helps minimize this.
Wire wond resistors are fine for DC but may not work well as frequency goes up.
10 ohms seems high for current sense unless current is low. dknguyen is right on.
Russ Hensel is offline
Old 29th March 2009, 05:16 AM   #5
I wasn't looking at the diagram when i wrote that. It's actually 0.5 ohms, which sounds pretty normal. I guess I'm going to have to wait till i need to order a bunch of parts again to setup this motor controller, cause they don't sell these at any store I know of, and I'm not paying $7 shipping for a 5 cent part.
Triode is offline
Old 29th March 2009, 04:52 PM   #6
You may be able to salvage some nicrome wire from an old toaster to get high current resistance wire for free. Hard to solder, may want to attach with nuts and bolts and solder to them.
Old 30th March 2009, 12:33 AM   #7
Depending on the current you can use 5' of #30 awg wire wrap wire. It melts at 8A to 10A. Or 10' of #27. Or 20' of #24.
Willbe is offline
Old 31st March 2009, 11:55 AM   #8
Sense resistor needs to be very accurate (low tolerance) and very small, so it wont affect the current that flew in the circuit before connecting the sense resistor.
Its purpose is to let you calculate the current through the consumber/appliance, accurately.
What did you mean dknguyen by saying its built well for heat dissipation?
alphadog is offline
Old 31st March 2009, 01:54 PM   #9
well a long coiled piece of wire, like some spare electromagnet wire i have, would dissipate heat well, and as long as i test the length I'm going to use with a multimeter first, I can make the tolerance very tight.
Triode is offline
Old 31st March 2009, 02:37 PM   #10
A DIY resistor is a bit much in my book.
Mouser has SMD sense resistors for about 50 cents. They are not tiny.
This is 2 Watt .001 Ohm
ULR2R001FLFTR
BCHS/3v0's Tutorials
3v0 is online now
Old 1st April 2009, 09:11 PM   #11
Yeah, I normally order these kinds of things. I just wanted something to make the motor controller work for now so that I don't have to wait till next time I need enough parts to justify shipping on an order before I can learn how to use the controller.
Triode is offline
Old 2nd April 2009, 08:48 PM   #12
At 10 Ω it isn't very important, but it is quite common to have sensing resistors wired as 4 terminal resistors. That is where the wires that carry the current are separate from the wires that sense the voltage.
The reason is so that the resistance of any connections do not cause any measurement errors. Power Standards Lab - How 4-terminal resistors work explains why no.
Diver300 is online now
Old 2nd April 2009, 09:21 PM   #13
I am trying to understand this.
So if one took a standard resistor and ran two wires from the sense circuit directly to the resistor you have in effect a 4 terminal resistor ?
3v0 is online now
Old 3rd April 2009, 03:49 AM   #14
I'm pretty sure that its just a two terminal resistor, since that's how it appears on all the circuit diagrams. That's interesting though, i never knew such a type of resistor existed.
Triode is offline
Old 3rd April 2009, 04:33 AM   #15
This is also important when routing PCB traces to the sense element - they should connect directly to the sense element pads, and not to some arbitrary point of some track that happens to connect to the sense element.
dougy83 is offline
question, resistors, sensing
Question in resistors in series and parallel ormo General Electronics Chat 2 31st October 2008 01:48 PM
Newbie Question about resistors,transistors? AaronOregon General Electronics Chat 20 22nd August 2008 01:59 PM
Resistors & 48V DC Question Altanore Electronic Projects Design/Ideas/Reviews 11 22nd August 2008 07:37 AM
sensing think_its Electronic Projects Design/Ideas/Reviews 2 30th November 2006 01:14 AM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 05:55 AM
