Old 20th March 2009, 08:39 PM   #1
Default purpos of branch with a capacitor leading to ground?
I'm wondering why on so many circuit designs, particularly ones involving ICs, there is a point, often right before the connection to the supply or drain where it branches to a capacitor, often 100nF or so, which connects to ground. Is this like a cushion for changes in current?
here is an example:
The odd thing is that looking at motor control designs, I have seen many that are almost identicle except for including or excluding these capacitors. And many chips have a similar branch to ground on their connection diagrams. So what does it do?
Triode is offline
Old 20th March 2009, 09:15 PM   #2
It kills high frequency noise (spikes) and keeps it from entering the IC.
Mike2545
Mike2545 is offline
Old 20th March 2009, 09:40 PM   #3
That makes sense, Thank you
Triode is offline
Old 21st March 2009, 04:59 AM   #4
It's also something of a shock absorber for IC power. The IC is typically pulling a lot of current when a logic state changes. The cap, being close to the IC, acts as a storage tank to fill in peak demands at those moments.
kenjj
All my pencils *used* to have erasers!
kjennejohn is online now
Old 21st March 2009, 12:12 PM   #5
.1mf does not act like you describe. It's sole purpose in this application is to squelch frequency noise.
What kind of IC's are you using that use a lot of current when the logic state changes?
Mike2545
Mike2545 is offline
Old 21st March 2009, 12:14 PM   #6
Note the 100u one mike, that's definitely a power supply buffer.
straight answer, har har."
Sceadwian is offline
Old 21st March 2009, 12:17 PM   #7
Yes, but that is on the other side of the voltage regulator and the original question is about the .1 next to the IC.
The 100uf is resisting changes in the current, kind of smoothing out any ripples in the DC.
But .1, no.
Mike2545
Mike2545 is offline
Old 13th June 2009, 04:10 AM   #8
google decoupling capacitor
adam.tucker55 is offline
Old 20th June 2009, 01:33 PM   #9
sometimes more than 100nF are required, for instance if you drive LED displays.
1uF, 47uF or even 220uF, if problems persist, add capacitors at multiple places until they disappear.
fast computer circuits (let say, 10MHz), which have RAMs, GALs, etc.,
need 100nF, 220nF or 330nF everywhere, not just one or two.
a CPU will introduce current surges in the 10s and 100s of mA, and if there are no capacitors, it can and will introduce logic glitches, means, the design can not work correctly.
for low-power PICs including some LEDs, i often just use 1 uF (note i supply via USB or battery, if you have 7805 etc., situation is completely different).
nike6 is offline
Old 22nd June 2009, 10:37 PM   #10
What C4 does depends on where it is located. If it is right at the regulator, then it is there to ensure regulator stability. If it is right next to the chip, it is a simple bypass cap for the logic IC to keep noise off the lines/provide low impedance to ground for AC noise. If it is close enough to both, it will act as both.
speakerguy79 is offline
Old 23rd June 2009, 03:27 AM   #11
Doesn't C4 also help in keeping the regulator from oscillating?
IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
Krumlink is offline
Old 23rd June 2009, 01:56 PM   #12
an oscillating regulator is an unstable regulator. If a capacitor is being used to help maintain stability then it is preventing oscillatory behavior.
OutToLunch is offline
Old 24th June 2009, 06:04 PM   #13
What? I know what you are saying, but why are you saying it?
Mike2545
Mike2545 is offline
Old 24th June 2009, 06:06 PM   #14
He's explaining in response to Krumlink that what he said as an alternative explaination is really the same thing.
Triode is offline
Old 24th June 2009, 07:25 PM   #15
thanks, yes
oh - that was in response to Triode's response to the response about my response to Krumlink.
branch, capacitor, ground, leading, purpos
Branch Circuit Monitoring rowlandsw Electronic Projects Design/Ideas/Reviews 6 21st January 2009 02:09 AM
What is Chassis Ground, Technical Ground, Circuit Ground? victor General Electronics Chat 8 11th October 2008 12:42 PM
simple oscillator - old chestnut new branch chukabuka General Electronics Chat 2 17th September 2008 03:58 PM
Branch on Less Than MrJammin Micro Controllers 4 12th June 2007 03:28 AM
Lagging/Leading PF - Lagging/Leading Q - Positive/Negative Q powersys General Electronics Chat 1 11th January 2006 04:56 AM
