Old 2nd March 2009, 04:17 PM   #1
Default Why has my lead acid battery gone high?
This might sound like a stupid question but I have several 14Ah lead acid batteries that i accidently left energising a relay and checked them recently. They all read between 0.5v and 1.5v which I know is very bad for this type of battery, and thought I can still charge them but they don't draw any current from the charger now. Why (chemically?) don't they charge anymore? And is there any way to bring them back from this?
Jules_Theone is offline
Old 2nd March 2009, 09:38 PM   #2
In general, lead acid batteries are damaged in terms of capacity and service life if discharged below the recommended cut-off voltages. It is widely recognised that the lead calcium alloy grid batteries are susceptible to over discharge damage. For example, if a lead acid battery was discharged to zero (0) volts, and left standing in either open circuit or on load for a long period of time, severe sulphation would occur, raising the internal resistance of the battery to an abnormally high level. In such an extreme case, the battery would not accept charge. Although over discharging IBT lead acid batteries is not recommended, they have been designed to withstand small levels of over discharge, provided that the battery is not left in a discharged state for a long period of time. It is necessary to avoid the over discharge situation as much as possible. To prevent this from happening, for some applications, it may be possible to incorporate a low voltage alarm and cut off circuit.
Hate to say it, but my experience says you're screwed!
I've never advocated drugs, alcohol, violence or insanity, but they have worked well for me!.......Hunter S. Thompson
GonzoEngineer is offline
Old 2nd March 2009, 10:10 PM   #3
There are some circuits out there on the web which are designed to"desulfanate" a lead acid battery, but as yet I have not tried to build one. I use a lot of the Gel Cells as emergency battery packs for in the field battery systems for our radios.
Try a search for "Desulfanater" or some other spelling.
microtexan is offline
Old 2nd March 2009, 10:22 PM   #4
Thanks. One of the batteries was recoverable when i put three power supplies in series to get like 75v. Although I don't know how long it will last. I've read somewhere that you can recover Ni-Cads in the same way.
I might get a charge regulator which can manage the charging / discharging of the battery pack.
Another thought is to get some bigger (car batteries), would those be better than 40 14Ah ones?
Old 3rd March 2009, 09:14 PM   #5
I have fix some lead acid battery car type with a charger I made it could put 20volts at 50amps in them but it didn't work on all of them found a chart some where that showed how much it took to
you may be able
to find it on the web.
be80be is offline
Old 6th March 2009, 09:39 PM   #6
I've asked my dad about this, and he says the acid gets stronger when it's discharged. Thats why the plates are disolved quickly. Does this sound like sulfanating?
I just thought, how does he know that the acid got stronger, he doesn't have anything to measure that - he must have tasted it! lol!
Old 7th March 2009, 01:40 AM   #7
I built the circuit found here battery gizmo but I do not have a beat-up battery to test it on. Hope to have one soon back from a friend.
On a good battery I can get the audible RF noise so I believe my circuit works, though putting a multimeter's leads across the battery terminals does not show a voltage "spike" at all. Either that way of testing does not work or I screwed up somewhere w/ the 555 I guess.
BlackSportD is offline
Old 8th March 2009, 12:47 PM   #8
how about just charging the battery back up letting it take its time and run it through a few charge/discharge cycles, I've got a gel battery gone real dead through lack of use I'm getting random charge readings of between 100 and 220 mA it just jumps wildly around.
www.simonsphotography.org.uk/ - My other hobby
www.rushdenrotaract.org.uk/ - make a difference and have fun !
Never buy "Trust" products, all mine broke !!!
Thunderchild is offline
Old 9th April 2009, 11:17 PM   #9
You can use a battery hydrometer to measure the specific-gravity of the electrolyte.
As you can see from the diagram, the "float" rises in the "battery acid" when the battery gets charged "more-and-more." This means the acid gets "heavier" not lighter, when the battery is fully charged - as the denser fluid pushes the float higher out of the water, just like a ship floating in salt water compared to fresh water (plimsoll line - or load line) .
colin55 is online now
Old 9th April 2009, 11:27 PM   #10
That of course is assuming the battery is flooded and not sealed.
if I know the answer.
Hero999 is offline
Old 11th April 2009, 05:59 AM   #11
I've done the hydrometer test too many damn times in the Navy lol.
My friend has a "beat" dead battery that won't come back to life in his old Toyota, so hopefully I can be testing the circuit soon.
Old 19th April 2009, 04:03 PM   #12
Here is a circuit I developed.
It produces a high current pulse to help to desulfate the battery.
It also measures this pulse across the battery terminals.
So because of the batteries internal resistance:
On a Really Good Battery, There will be No Meter Reading.
On a Really BAD Battery, it will give a FULL Scale Reading.
A Battery Desulfator/Tester
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 5th June 2009, 07:37 PM   #13
Lead sulphate is like the previous posts mentioned your problem .
Desulphation is in itself (partly) possible .
Over your plates you have a layer of lead sulphates which isolates .
The internal resistance of your battery is very high and it prevents the interaction between the plates and the now dilluted acid .
Lead sulfates resonate if i remember correct at 3.3 Mhz .
What you want in your desulfator is that it has powerfull pulses which contain high frequency's to have resonance effect take the sulfates of your plates .
I used switchmode controllers with (intentional) ringing from the mosfet to create that 3.3 Mhz needed to desolve the sulphatelayer .
It did (measurable) improve the state of health of the battery but it takes time and the battery doesnt come out as new .
You can follow progress by measuring the internal resistance of the battery from time to time given you don't use a method that draws large currents .
walkura is offline
Old 6th June 2009, 01:53 AM   #14
The VX-6 (?) battery rejuvenator fluid was based on baking soda (or baking powder, I cannot remember which).
Willbe is offline
Old 6th June 2009, 07:20 AM   #15
On this website they give a relative good explanation of the processes at work .
Personaly i don't know the VX6 fluid ,but i can ask one of our customers that runs a battery rejuvenation service .
At the moment i am doing trials with the chargers he uses (in combination with additives)
(those chargers do pulse but at just 60 Hertz and relative low powerlevels)
I assume that when that VX6 is based on backing soda the intention is the have the alkalic solution dissolve (neutralize) the sulphates .
To me it seems it would dillute the acid mixture ,taking a few % of the efficiency of the chemical processes but with cleaner plates the battery would function again just not at 100 % of its rating .
Its like cleaning the waterboiler with vinegar .
Personaly i would try to inform yourself on the working of desulphation pulsers .
I don't like meddling with the acid mixture especialy not when it might be possible to recover it from the sulphation on the plates .
walkura is offline
acid, battery, high, lead
Lead Acid Battery Desulfator wasrana Electronic Projects Design/Ideas/Reviews 24 30th August 2008 11:16 AM
lead acid battery charging dimper129 General Electronics Chat 3 14th April 2008 08:06 PM
Lead Acid Battery dimper129 General Electronics Chat 3 18th September 2007 10:23 AM
Lead-acid battery zapper d4d4ng Electronic Projects Design/Ideas/Reviews 17 24th July 2005 02:54 PM
Lead acid battery efficiency Oznog General Electronics Chat 2 22nd September 2004 07:08 PM
