Old 25th February 2009, 04:31 PM   #1
Default Combinatoric timing problem
I have a combinatoric circuit that will reset a stage (one of several sr-flipflops).
Then I discovered that if both A (set-button) and B (from reset button) goes high at same time (like if they're wired together) that will cause S to go high for some ns and then go because of delay in leftmost and gate.
Then I start working boolean algebra, but I won't get any similar circuit that won't producing spikes when A and B shift state same time.
Also I would like trying avoiding any aditional delay circuits that hasn't other purposes than only delay the signal.
Any ideas?
Grossel is offline
Old 26th February 2009, 10:20 AM   #2
This is the nature of combinatorial logic. Sequential logic is the fix, but this adds delay...
Pay it forward.
Mikebits is offline
Old 26th February 2009, 11:12 AM   #3
Add a buffer of the same type as the other gates on the 'A' input to the second gate. This will add a delay so both signals reach the second gate at the same time, minimising the delay between them.
Jules_Theone is offline
Old 26th February 2009, 01:40 PM   #4
I know I can do this easily, but as I mentioned in the first post, I want to avoid additional delay circuits.
I think it's impossible to achieve, can anybody confirm this?
What about an example on Sequential logic?
Grossel is offline
Old 26th February 2009, 01:57 PM   #5
Its a compromise between speed and hazard elimination. The sequential circuit would produce a longer delay but eliminate the hazards.
Are you using the fastest logic family because if you use fast logic the delay will be minimised. The fastest i believe is 74G**.
Old 26th February 2009, 03:38 PM   #6
At this moment, this is only a theoretical question, so the physical component isn't chosed yet. But I presuppose that all logic gates in the circuit provide roughly the same delay time.
But sure I get a very fast nand gate (the left one) and put in a slower one for the right. But then again, I probably have to spend more physical IC's on a board than neccesary just to provide a longer delay.
I think instead I can use two inverters in serie of same type (ttl-family) as the two and gates.
Grossel is offline
Old 27th February 2009, 09:41 AM   #7
But why would set and reset be asserted at the same time? Is this a likely situation? Can you assign priority logic to A and B So A overides B? If so, Some sort of encoder logic can be used.
Also, why is delay a problem? A few usec should hardly be an issue compared to pressing a button. Using sequential logic like flipflops for your switches can ensure that a race condition does not exist.
Clock A on rising edge and B on falling edge. This does add complexity so you have to decide how important it is.
Pay it forward.
Mikebits is offline
Old 5th March 2009, 10:49 AM   #8
Try to see the propagation delay of each gates (semicondutors produces interal delays).
Chaerl is offline
Old 5th March 2009, 11:07 AM   #9
Prop delay for most gates these days is in the nano second range.
Pay it forward.
Mikebits is offline
Old 5th March 2009, 11:18 AM   #10
True, but sometimes its an issue if you're working at highspeed specially if the timing is critical
Chaerl is offline
Old 5th March 2009, 11:34 AM   #11
Since the poster mentioned buttons (as in a switch), I doubt nano or microseconds is an issure.
Pay it forward.
Mikebits is offline
Old 5th March 2009, 11:48 AM   #12
and the poster mentioned, causes S to go high for some ns and then go because of delay in leftmost and gate.
Initially, the inputs are lo. the complementary input of the right most gate is actually hi. at the switch turned to hi, because of the propagation delay of some ns of the left most gate, the complementary input is still hi for some ns while A changes to hi. so the output S stays hi for some ns. when the input of the left most gate propagates to the output, the complementary input becomes lo and thus, S becomes lo until the change of status.
Chaerl is offline
Old 17th March 2009, 01:57 PM   #13
It's impossible to solve directly because the truth table of your circuit is:
A B S
0 0 0
0 1 0
1 0 1
1 1 0
so when you get A=1 B=0 on the inputs, you WILL get a 1 on the output, and the question translates to "how can I delay A without delaying A" which is obviously a contradiction.
However there may be a solution. The circuit is equivalent to S=A.!B (i.e. run B through an inverter and AND it with A), so can you get !B from anywhere? If C=!B then the truth table becomes:
A C S
0 0 0
0 1 0
1 0 0
1 1 1
and there is no transient for AC=00->10->11, or in fact for 00->01->11, because both must go high before the output can.
Sig 9 from Outer Space
xpi0t0s is offline
combinatoric, problem, timing
16F628 timing problem ahydra Micro Controllers 24 27th December 2008 01:53 PM
PIC Timing baberjaved Micro Controllers 10 21st September 2007 02:06 AM
555 timing help bunghole General Electronics Chat 24 13th September 2007 08:52 PM
Need Help with a Timing Circuit gb043 Electronic Projects Design/Ideas/Reviews 4 8th September 2004 04:32 AM
Strange timing problem 2camjohn Micro Controllers 1 19th March 2004 03:16 PM
