Old 14th February 2009, 05:29 PM   #1
Default Rds(on) of mosfet.
I read in a datasheet of mosfet that its Rds(on) 1.35ohm @ VGS=10V, IDS = 2.7A.
When in ON state, is IDS = VDS / RDS(on) ?
Thank you.
alphadog is offline
Old 14th February 2009, 07:11 PM   #2
Basically, yes. VDS should be fairly low at that point and IDS should be within spec and limited by the design of the circuit.
kchriste is offline
Old 14th February 2009, 08:48 PM   #3
Thanks.
Correct me please if i'm wrong, in saturation state, Rds is very large, then how come IDS is maximal (for constant VGS) in sturation state?
alphadog is offline
Old 14th February 2009, 09:04 PM   #4
In saturation state RDS is very small.
ronsimpson is online now
Old 14th February 2009, 10:01 PM   #5
But in stauration state, Rds = VA / IDS, isnt it?
And VA (Early Effect Voltage) is very large, therefore Rds is very large also.
Where am i wrong?
alphadog is offline
Old 14th February 2009, 10:45 PM   #6
The numbers from a data sheet do not mean the FET will all wise work like that.
In your example from the first post: 10 volts is applies from G-S. A current source (2.7A) is applies to the D. The FET looks like a 1.35 ohm resistor. The voltage D-S is 3.6 volts, under these conditions.
Appling 10 volts to the gate will not cause 2.7 amps. It will cause the FET to turn on and look much like a 1.35 volt resistor. The current is a function of what is on the D.
Early Effect Voltage???? Are you talking about the first nano-seconds of turn on? Saturation is talking about being on (DC) not AC.
Old 15th February 2009, 01:09 AM   #7
This is a common misconception for people who cut their teeth on BJTs. Saturation in a MOSFET is basically opposite of that in a BJT. In a MOSFET, saturation is the high-impedance region (active mode) of the characteristic curves.
Ron
Roff is online now
Old 16th February 2009, 04:20 PM   #8
I know the early effect voltage (VA) is normally applied with BJT's. I don't know if it is applicable with FET's. It is actually the variation of the width of the base as the reverse voltage between collector base varies. Typically, the gate of the FET's as virtually isolated, high impedance input.
Chaerl is offline
Old 16th February 2009, 04:30 PM   #9
A search finds several references to the Early effect in MOSFETs. It's a different effect, but with similar results.
Ron
Roff is online now
Old 16th February 2009, 04:57 PM   #10
I see, I try to dig on that for more details.
Chaerl is offline
Old 17th February 2009, 03:48 PM   #11
similar to the way the VA describes the linear dependency of IC on VCE in saturation region in BJT, it also describes the linear dependency of IDS on VDS in saturation region in MOSFET.
alphadog is offline
mosfet, rdson
Need help with PWM mosfet smilem Electronic Projects Design/Ideas/Reviews 32 14th November 2009 09:48 PM
MOSFET Vgs dark General Electronics Chat 35 25th December 2008 08:10 PM
Mosfet Help NickLee Electronic Projects Design/Ideas/Reviews 20 19th December 2008 02:00 AM
Mosfet to ground or mosfet from +v? bh00 General Electronics Chat 4 23rd May 2006 07:42 PM
Why use MOSFET instead of BJT? StupidDum General Electronics Chat 8 3rd December 2004 07:56 PM
