| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
What is the structure of resistors that gives them their resistive properties? Do you know of any materials that are thin, flat, stiff, durable, and have consistent resistive properties? I’d like to be able to measure distances on such a piece of material about 2 feet by 2 feet as a function of resistance applied to 3-5 volts. So, the amount of resistance that the material offered would have to vary consistently as a function of distance from a point on the material where electricity would be connected. I’d also like to be able to represent hypothetical land formations on a game board using this material. So, the material might have to be transparent or mesh-like – so that the appearance of the game board design could be seen through the material. Do you know if there is a conductive paint that would allow electricity to flow from the material through the paint and into game pieces that I would like to use on the game board? The position each game piece could then be calculated, I think, as a function of the voltage drop between three points where electricity is connected to the material and the location of each game piece on the material.
Search telo | |
try a google search: ![]() ![]() electrically conductive paint | |
| Ever hear of this type of paint coming in colors besides silver, like green, blue, gray, and black?
| | #6 |
Well gold but that would be expensive. It's not going to work as an X-Y gameboard for a few reasons, one is it's not going to be linear unless you somehow apply it perfectly. | |
| | #7 |
| | #8 |
Does anyone know of a site where I could find a list of the resistive properties of materials, and maybe even the stiffness of these materials? I don’t know if resistive properties change according to the shape of the material being evaluated, but I am looking for a material whose resistance to about 3-5 volts varies consistently and significantly as a function of distance on a thin piece of material between very small distances – the smaller the better, and also distances as large as about 3 feet. Are there any other properties of electricity that change as a function of distance in thin materials that can help me expand my search for a material that I can use to measure distances electronically? The list has to include materials that are commercially available in thin, flat, stiff sheets that can be reduced in size to about 2 feet by 2 feet without specialized tools. Should I be searching for semiconductors or alloys? Someone helped me out earlier with the idea of carbon paper, but carbon has so many different forms. And I am looking for something a little more durable. Also, out of curiosity, and correct me if I’m wrong, but why is it that the conductive properties of chemicals increase toward the lower left of the periodic table; but gold, silver, and copper are to the right of the periodic table? Also, what are the chemical properties of the material that I am looking for?
| | #9 |
I can't think of anything that's simple / cheap that meets your requirements. Look at electronic chessboards. The use a 8x8 grid often with simple magnetic sensors and magnets on the piece bottoms. How would you identify different pieces on your resistance grid? One piece would be simple but with two or more it wont work. Complex but possible would be a grid of small coil antennas on the board switched on one at a time with RFID tags in the game pieces. | |
| | #10 |
What about a matrix of resistive wires, not as discrete as the paint method, but if you setup a grid of X and Y axis, with the values of each axis monitored individualy,and insulated from each other, you should then be able to calculate positions on the board, asuming that your playing pieces have conductive bases. Karl.
| | #11 |
Is it enough to know there is a piece at a location, or do you also need to know which piece is at what location ?
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #12 |
Now we are getting technical | |
| | #13 | |
What did you mean by a grid of small coil antennas? | ||
| | #14 | |
| | #15 |
| I need to know which piece is at which location. However, if you would tell me of a way of identifying locations without identifying pieces, it might help me think of some more ideas. I plan on keeping the voltage between about 3 and 5 volts. So, I can connect the electricity running through any of the game pieces to analog microchip pins having a maximum voltage of about 3 or 5 volts. Then, a computer could identify the game pieces by identifying which of the many microchip pins is receiving each location-specific signal.
| question, resistor, structure |
| Simple question: What resistor to buy? | ajd344 | General Electronics Chat | 19 | 12th November 2006 07:04 AM |
| simple resistor question | Mark S. | General Electronics Chat | 4 | 5th September 2006 07:17 PM |
| A question about resistor uncertainties | pyg | General Electronics Chat | 1 | 10th June 2006 07:03 AM |
| led and resistor current question | themikestar | Electronic Projects Design/Ideas/Reviews | 6 | 26th December 2003 12:26 PM |
| Resistor rating question | haphazrd21 | General Electronics Chat | 3 | 17th November 2003 01:57 PM |
