| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
What are the active components in differential amplifiers used to drive servo motors. I'm not getting specifics in my Google searches. What I am seeking is due to the fact that it is a feedback system, what device or devices are used to produce the needed feedback information?
There are at least two answers to the question. I think the one you are looking for is rotary encoder. It has two digital outputs called A and B and they are 90 degrees out of phase. As the motor moves the digital signals A and B beat up and down. Counting the transitions allows you to figure out how many radians the shaft has moved. You can also tell direction by looking at which transition happens first as you start to move.
__________________ We never have time to do it right; but we always have time to do it over. | |
Try searching for something about converting a servo for continuous rotation (robotics). Been a long time, but remember a site that went into great detail on how servos work, and most importantly how to bypass the feedback. If I remember it, there is a pot attached to the motor shaft for feedback. There is a physical stop for the limits, don't remember any switches.
| | #4 | |
The Harvmyster is right. http://www.kronosrobotics.com/an116/GAN116.shtml Here is another link. http://www.seattlerobotics.org/encod...0for%20PWM.htm
__________________ Pay it forward. Last edited by Mikebits; 5th September 2008 at 02:48 AM. | |
| | #6 |
You should find this most interesting... http://www.freepatentsonline.com/4050002.html I'm talking real servo systems. There is no digital and no use of PWM. It is a purely analog feedback loop system. | |
| | #9 | |
A comparator is generally inappropriate in this context since its digital output can represent only two states. At the point in the system where you need to compare the "Command" signal with the "Error" signal a simple summing amplifier would work just fine. A summing amplifier is made from an operational amplifier with a large open loop gain, by placing a simple resistor from the output to the input. Is that what you are after? I guess the original question was too vague to allow a precise answer. Relative to the patent abstract: Rectification is done with diodes, just as in a power supply. The diodes can be configured as half-wave, full-wave or bridge rectifiers. Subtraction of two signals is performed by inverting one of them and adding them together. Nowadays you get functions in a single chip that used to take a significant piece of an ATR rack.
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 5th September 2008 at 05:04 AM. | ||
| | #10 |
Apparently the receiver too. I would like to see the electronics around the unit. Still, it's pretty slick! I believe you got it right there. Electronic terminology tends to adapt over time. I have always heard this technology referred to a servo mechanisms whereas now days I have noticed with the growth of robotics they tends to use this terminology but it is actually incorrect. Most of that is digital stepper type technology. It really first appeared with things like printers to spin the daisy wheel and feed paper through the platen. | |
| | #11 | |
Where could I get more information on these circuits? Analog beats the hell out of digital for speed. Let's not generalize too much. Take an analog computer for instance...Fast!!! | ||
| | #12 | |
It is my understanding that servo devices refer to analog. A stepper motor is not a servo device. Look at the date on the the mechanism Jpanhalt came up with. It's like 1925. Servo has been around a very long time and was never digital. It's just a blending of the terminology in recent years. | ||
| | #13 | |
http://en.wikipedia.org/wiki/OpAmp http://focus.ti.com/lit/ds/symlink/tl082m.pdf http://focus.ti.com/lit/ml/slob090/slob090.pdf http://www.national.com/an/AN/AN-A.pdf Search the forums for other keywordws that you encounter in the articles and follw the links at the end of the Wikipedia article. Have a ball, and knock yourself out
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 5th September 2008 at 05:31 AM. | ||
| | #14 | |
Yes it has been around for a long time. So have I and my father before me. Like everything else it has grown, evolved, and adapted. It now encompases digital techniques including the use of wicked fast VLIW Digital Signal Processors, A/D and D/A converters with unheard of precision. I can one up jpanhalt on the date. Check out the flyball governor on the steam engines that drove the industrial revolution circa 1850. There is an analog servo mechanism that is truly a thing of beauty. http://en.wikipedia.org/wiki/Centrifugal_governor http://en.wikipedia.org/wiki/Servomechanism Note the picture includes the motor, the reduction gears, and an optical encoder.
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 5th September 2008 at 05:42 AM. | ||
| | #15 | |
| question, servo |
| controling servo question | crys | Robotics Chat | 4 | 11th February 2008 01:44 PM |
| I want to run a big servo | jnnewton | Electronic Projects Design/Ideas/Reviews | 5 | 6th December 2007 07:15 PM |
| Servo Help! | Night Rider | Datasheet/Parts Requests | 2 | 29th June 2007 06:04 PM |
| Replacing RC Servo w/ Custom PCB (Open Servo) | dknguyen | Electronic Projects Design/Ideas/Reviews | 3 | 29th May 2006 03:48 AM |
| servo question | evandude | Micro Controllers | 1 | 18th August 2004 08:51 AM |
