Old 14th August 2008, 04:28 AM   #1
Default What is source breakdown voltage?
Sorry. I meant drain source breakdown voltage.
The thought is in the question; The information is in the anwser.
b_reagle is offline
Old 14th August 2008, 04:59 AM   #2
It is the voltage between the drain and the source at which the FET begins to conduct with no gate voltage applied. The gate to source voltage is zero and the FET is supposed to be off but you have applied too much voltage (exceeded the drain source breakdown voltage) so avalanche current flows and your FET blows up.
kchriste is online now
Old 14th August 2008, 05:10 AM   #3
Thank you.
b_reagle is offline
Old 14th August 2008, 07:15 PM   #4
Not that simple, most MOSFETs are avalance rated to some degree, for example the IRL540 can take a single shot of 440mJ without dying.
To put this into perspective, you could switch 20A though a 2mH load or 663mA through a huge 2H load with no back EMF diode and it won't die.
if I know the answer.
Hero999 is offline
Old 27th August 2008, 12:08 PM   #5
hero the question was breakdown voltage not conduction of 10,20 amps. if it breakdown at 400v and the leakage is .001amps that is 4 watts and because it gets hot at 4w it will beging to heat up more LEAKING MORE current and eventualy blow up.
neon is offline
Old 27th August 2008, 12:55 PM   #6
That's a form thermal runaway which is a different phenomena to breakdown voltage.
You've got one hell of a leaky MOSFET, the IRL540 only leaks 25ľA at 100V 25° which is just 2.5mW.
Even so if you use a good sized heat sink thermal runaway is unlikely to occur.
It was good idea to bring it up as it is certainly something you should be careful of at higher voltages.
Hero999 is offline
Old 29th August 2008, 07:50 PM   #7
ok here is my question so that you will finaly understand. on a square wave where is the maximun heat dissipation rise time, saturation, or fall time, or off. asuming a transistor switch.
finaly if I LIMIT THE CURRENT DURING BREAKDOWN of any device it can sustain that indefenetly. is true or false?
neon is offline
Old 2nd September 2008, 06:51 AM   #8
Default Re:What is source breakdown voltage?
In my point of view source breakdown voltage is a voltage when the device starts conducting. Then it will be ended at a particular point.
martin
Social Media Marketing - 497604809.341004
martin5 is offline
Old 8th September 2008, 12:02 PM   #9
As far as i know...kchriste ans is rite.....
architmh is offline
breakdown, source, voltage
single voltage source equivalent of multiple voltage sources sstimuluss General Electronics Chat 29 31st January 2007 10:33 PM
low power constant voltage source yagtoby Electronic Projects Design/Ideas/Reviews 1 25th June 2006 03:47 AM
Cooking with Resistors: Breakdown Voltage? DigiTan General Electronics Chat 12 5th November 2005 07:57 PM
NJFET and breakdown avalanche bartinla General Electronics Chat 5 2nd August 2005 11:07 PM
voltage and current source Gaston General Electronics Chat 14 8th March 2005 06:46 AM
