Old 7th September 2008, 11:38 AM   #16
Originally Posted by Hero999 View Post
It's possible if you make a couple of modifications, you can either lower the reference voltage or reduce R1. R2 needs reducing to allow enough current to saturate Q1.
Your best option is to use a comparator with a push-pull output and a MOSFET.
If you must go for a BJT then use a good quality one like the ZTX753 or the 2SA1943. It needs to have a low saturation voltage, high beta at 1A and fairly fast Ft >20MHz.
If you coult give a schematic and little description with it then that will be great
RizF1 is offline
Old 7th September 2008, 11:46 AM   #17
The schematic is on the first post in this thread.
if I know the answer.
Hero999 is offline
Old 7th September 2008, 11:52 AM   #18
but what changes need to be done exactly??
I know very little things about electonics
RizF1 is offline
Old 7th September 2008, 03:29 PM   #19
All you need to do is change some of the component values. The post I made at the bottom of page 1 of this thread should give you a few clues as to what you should change.
I also forgot to say that you need replace the two series LEDs with your 60 LEDs in parallel but include a low value current ballancing resistor in series with each LED.
A lot of it depends on what components you have available. Try simulating it on LTSpice and playing around with it a bit.
Do you understand how it works? I tried to explain it in my first post but don't hesitate to ask if there's anything you don't get.
Hero999 is offline
Old 8th September 2008, 09:33 AM   #20
Originally Posted by RizF1 View Post
I just googled and came to know that switched mode power supply for LEDs is much efficient than directly hooking them up with powr source and LEDs are much brigher as well. I was looking for switched mode LED driver circuit and saw this thread
I have an LED pannel in an emergency light in which 60 LEDs are connected in parellel, they are driven through a 6 volt 4.5AH battery with one 2ohm 5watt resistor in series. They best operate when 1A current is flowing.
If they don't have series resistors for EACH string or device in parallel, the device will fail. Not one big resistor in series with the combination of parallel strings. The LEDs will not play nice and share current, the hottest one actually takes more current (negative temp coefficient of forward voltage), heats up more, takes even more current, blows out. Then the rest start going out.
HV9910 is an excellent switching reg. Don't give it an overly huge transistor with large capacitances. ZXLD1350/1360/1362 also great, and those have internal transistors.
Oznog is offline
Old 9th September 2008, 05:06 PM   #21
Here's a floating version of this circuit.
This can be used in the car with a chassis return.
It also has the advantage of being short circuit proof and of being more efficient since the current driving the transistor isn't completely wasted.
Hero999 is offline
Old 14th September 2008, 06:06 PM   #22
Another thing you should be aware of is that, if poorly designed, this circuit can fry LEDs if a brownout occurs. When the input voltage drops below a certain level, it will stop oscillating, this will mean the LEDs will overheat if they can't withstand the peak current continiously. The solution to this is to design the circuit so the peak current never exceeds the absolute maximum rating or add a low voltage disconnect circuit to protect it from a brownout.
Hero999 is offline
Old 1st November 2008, 07:07 AM   #23
Then why bother with a specialised IC when a cheap comparator and transistor will do most of the time?
Hi there,
The idea is to light the LED and also get good regulation
with fluctuations in power supply voltage and LED voltage.
Many converters like this draw more current as the power
supply voltage rises, and sometimes we want to keep the
output power at some predetermined level even if the
voltage changes drastically.
Perhaps you can do a quick study to see how much the
LED current changes with power supply voltage, but
you also need to add in some resistance in series with
the inductor and in series with the power supply.
MrAl is offline
Old 1st November 2008, 12:46 PM   #24
I've it at different voltage and you're right the current regulation isn't perfect. Generally the current drawn from the supply reduces with increasing voltage and the LED current increases slightly.
but you also need to add in some resistance in series with
I don't understand why you would want to do this, the inductor already has a series resistance and the current sense resistor adds to this; why would you put another resistor in series with the power supply which would only make it less efficient?
Hero999 is offline
Old 1st November 2008, 05:58 PM   #25
[inductor and power supply series resistance addition]
Yes, the regulator ic's usually have some form of regulation built in
to keep the output at some preset level, and it stays that way for
a wide range of input/output conditions.
The series resistor for the power supply is when you are using
batteries for the actual real life power supply, i apologize if you
are not doing this. The inductor series resistance also affects
regulation sometimes and even circuit start up. If it's low
however it wont be a problem, but i just thought i would mention
it.
MrAl is offline
Old 1st November 2008, 06:54 PM   #26
Actually, I have considered that. I always try to grossly over rate Schottkys so the voltage loss is really low. My estimate was based on SPICE simulations and was just a rough guess, I didn't do an exact calculations. I jusr looked at the figures spat out by it.
The Schottky I've used in the simulation is rated for 3A and it only passes a maximum of 369mA which is 13.2% of the rated current.
The loss is only 288mV at the peak current draw and 261mV just before the transistor turns on which gives an average of only 275mV; this is <10% of one LED drop and <5% of the total LED drop in this circuit.
The transistor saturation loss is between 83.1mV and 103.2mV giveing an aveage of only 93.15mV.
The duty cycle is 63.5%.
The rise time is 6.7ns.
The fall time is 28.8ns.
The over all period is 6.309µs.
The inductor ESR was just set to 1mΩ which I know is far too low and needs increasing but my guess took account for this. I could do some more accurate calculations but there's no point with SPICE, it's much better to build the circuit.
Sorry I missed this before... I usually post quickies unless I have something well formed already or my wife is out.
So it sounds like you had that end right... it is just often even the dissipation in the rectifier is missed, never mind the inductor losses.
Ubergeek63 is offline
Old 1st November 2008, 07:09 PM   #27
This circuit has regulation too, it just isn't perfect.
It uses a comparator as a schmitt trigger with preset on and off threasholds which vary very little as the power supply voltage changes.
it.
I still don't see why you need a series resistor regardless of what the power supply is. It's true that you might want to incorperate over-current protection but a simple fuse or PTC resistor would do that.
Hero999 is offline
Old 2nd November 2008, 05:23 AM   #28
Yes, while many regulation chips are made to be very close over
a wide range of operating conditions. They have some extra circuitry
built in for the sole purpose of regulating some parameter. This
extra step is what puts them in a class where you start looking
at little things like percent voltage regulation with line and
with load. The dc accuracy is made to be very good on purpose,
not as a by product of some other function for the same amplifier.
This is often done with an integrator, added in just for that.
When batteries are used as power sources in real life there is always
some internal resistance, while in a spice environment you have to
add it yourself. The point is that some power converters work
very well with a zero impedance source, but as soon as you add
some real world series resistance they dont regulate as well.
This is why i suggested trying a circuit with some series resistance
if it is going to be run on batteries.
MrAl is offline
led, regulator, switching
Switching regulator for dev board Blueteeth General Electronics Chat 10 5th January 2007 10:31 AM
Two transistor 5V switching regulator William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 5 3rd July 2006 06:01 PM
switching regulator ics manjiri General Electronics Chat 4 30th December 2003 10:52 AM
Switching Regulator Noggin General Electronics Chat 18 23rd October 2003 07:22 PM
Simple Switching voltage regulator need hs_ Electronic Projects Design/Ideas/Reviews 1 18th May 2003 08:29 PM
