Old 19th August 2008, 03:17 AM   #16
If you want wide range, use a YIG tuned oscillator. Though they generally operate above 2 GHZ.
Another way of getting a wide tuning range:
http://hem.passagen.se/communication/rfinject.html
kchriste is offline
Old 19th August 2008, 01:16 PM   #17
Thanks Kchiste. I guess I should have mentioned I'm looking for something in the HF range. By the time you divide down 250 MHz to say 10 MHz, that divide ratio becomes the HF bandwidth. Another thing. I don't want a divided signal is my f0 signal. Too much harmonic content. Spectral purity is key in a good HF receiver.
Space Varmint is offline
Old 19th August 2008, 02:11 PM   #18
You don't divide down, you hetrodyne down, so you get the full bandwidth. This is how continuously tuned HF receivers work.
Nigel Goodwin is online now
Old 19th August 2008, 05:44 PM   #19
Good point! Yes I know you can do this. It scares me to have so many unwanted components on the 1st LO. I may try the multiple VCO approach. I just built the Hartley and it is very spectrally pure. Beautiful sinusoidal sine-wave! You seem to know your stuff Nigel. Have you built any receivers?
Still, when you mix it down to produce a first LO then divide that down for your reference. If you want say 10KHz step rate (for instance) then when you hop to the next step it will be multiplied through the mixer still limiting your range.
Wait a minute. Have to think that through. I got so much crap to do right now. Just ain't got time to think about it...lol
I'll be mad if I have to do this oscillator again. Especially after fighting with the Armstrong.
Old 19th August 2008, 09:18 PM   #20
Not for years, and only simple ones.
I would suggest you buy the ARRL or RSGB manuals, these are essential for anything radio based - everyone here should really have one or the other (or both).
Old 19th August 2008, 10:44 PM   #21
Absolutely! I got my ARRL Handbook. WHat did you build? DC receivers? I've built a couple of dual conversions. Just never made a good full coverage digital synthesizer. I've made single band. I never put a transmitter on the air anymore without digital lock. But my VFOs never chirped. They may drift a little but no chirp! Drift is not tolerable for SSB reception.
Old 20th August 2008, 09:48 AM   #22
I've built various single band DC and TRF receivers, there never seemed much point building superhets, as they are so freely available.
Old 20th August 2008, 04:19 PM   #23
Oh Lord, not a TRF. Parish the thought. I love building receivers but hey can be time consuming. One day I will get one on PC board for the life of me. Man, there are so many things you can do. You know me. I look for rat under every wood pile. I keep thinking about that 2nd IF frequency. Now days I believe all 2nd IF's are 455 KHz. Man, too easy to jam the world! Hell, you could broadcast it over HAARP. I've had some fun playing with the 2nd IF. There are some neat things you can do. If the first IF is sharp enough, you got your selectivity. Now by shifting the 2nd IF you can move images to where they are non existent.
Another major factor. Other that a few low end radios like Grundig and Beagine which work fairly well, have you ever priced a good communications receiver lately? Man it's nothing to drop a few grand on one. We're talking the good stuff. Kenwood, Tentec, Icom etc.
Old 20th August 2008, 05:21 PM   #24
Well Grundig were never 'low end' radios, they made some really nice stuff - but are now long gone!
Lowe Electronics produced a fairly well received communication receiver, and I actually know the guy who designed it he's a genuine genius, bordering on insanity - a really, really clever guy.
Old 21st August 2008, 02:43 AM   #25
Space Varmint,
The challenge of good HF receiver design is to maintain the snesitivity and selectivity you want in the mass of other (often much stronger) signals coming in the antenna.
Generally the most important thing is linearity, it's bad enough that there is a mess of other signals there, you don't want to mix them together to create something on top of your signal. So you will often see no LNA, a mixer running at obscene levels of LO power (100mW and up), followed by significant filtering. Often there is an absolute mmiminim of amplification before there has been significant filtering.
LO spurii are a no-no, they simply create spurious responses.
LO phase noise can limit your sensitivity in the presence of large interferers due to reciprocal mixing.
Don't make the mistake of going for sensitivity, below about 20MHz it is unlikely that you will be receiver noise limited and you are better off with linearity. So LNAs are not much use except at the higher end of the band and in quiet rural environments.
PLL design is a challenge, particularly if you want smooth (real time) tuning and frequency resolution suitable for SSB. One reasonably low cost way is to go for modest resolution in the first LO (say 1kHz), and instead of using a fixed second LO, provide +/- 500Hz tuning here. It does mean that the wanted signal moves around a bit in the first IF filter.
Providing the resolution in the second LO can be achieved using a second PLL and division, a second PLL using a n/n+1 divider, a DDS etc...
If you are serious check out Ulrich Rhode's books, there is one on Communication Receiver design I'm pretty sure. There is also a book called "SSB Design Handbook" or something similar.
Peter
Tesla23 is offline
Old 21st August 2008, 10:41 AM   #26
Originally Posted by Tesla23 View Post
Space Varmint,
Peter
Hi, Nice to meet you Peter.
Well you seem like you have tried your hand a few times at receiver design. They are fun! I know exactly what you mean about sensitivity though allot of the documentation tends to down play it I have found that you still need at least a couple of stages of amplification. Too much of course will cause blocking and here is where we get into the all too intensive discussion of dynamic ratio. Of course the mixer can have allot to do with it as well. I have had allot of success with JFETs as mixers. Diode rings work good but as you said you usually need allot of power to bring those weak signals over the bias level of the diodes. That is why I was asking Nigel about germanium diodes. He says they are still available but I don't know where he gets them.
I would like to meet your friend Nigel. Is he a member? Would be nice if he has sold his own brand and written books and all. He sounds like a real hot shot. I was real lucky back when I first moved to Atlanta about 10 years ago I had been building transmitters down in Tampa then when I got here I started into building some DC receivers. I met this guy on 2 meters and he knew everything...lol. I mean everything! Didn't know the first thing about computers or programming so we swapped knowledge and he ended getting a job in computers with Johnson & Johnson. He had to move for the position but I will never forget the guy. He also taught me allot about building good rf power amps. Like I said. He knew everything.
Old 21st August 2008, 03:08 PM   #27
I have to take issue with that. I find the phase sidebands completely unacceptable at that resolution. Even if you attempt to filter it down to where it could be considered reasonable, you will drastically lose bandwidth and I would fully expect that a powerful station that comes up on the beat note of several of those sidebands would bleed through. Of course the closer to center freq. the worse the situation. I like to see the first phase sidebands down at least "full quite" and preferably 120 db down. At 120 db down you will actually have an improvement over VFO due to the sharp high Q resonance.
Old 21st August 2008, 09:42 PM   #28
Hey Peter? If your on tonight. Have you ever played around with noise limiters in the loop? I did once when I had to in a transmitter because one of the low frequency references coming out of the divider was adding some modulation to the carrier that was audible. My experience was that the loop was not as strong though I have read that many times noise limiters are used. Wonder what other advantages could they produce because it is the energy in the sidebands that steer the signal back on freq f0. Any ideas?
Old 21st August 2008, 11:34 PM   #29
Hi Space Varmint,
I have to say I really don't understand your requirements. On the one hand you talk of 120dB suppression which suggests you are interested in getting the sorts of dynamic range you need in a high performance receiver, but and on the other you don't like leaving out the LNA but prefer to add a couple of gain stages, and you like low power JFET mixers or germanium giodes, any of which would probably cripple a high performance receiver.
Performance HF receiver design is about linearity, linearity and linearity, then you can start thinking about selectivity, phase noise and sensitivity. For an idea of what sort of specs are achievable look at (I just grabbed these randomly)
http://www2.rohde-schwarz.com/file_6596/EM010_en.pdf
http://radio.tentec.com/commercial/r...rs/RX340#specs
Note that with the LNA off they offer a noise figure of about 17dB with a third order intercept point of 30dBm or greater. They don't guarantee a noise figure better than 10dB.
Do some basic system analysis to work out your intercept points, noise figure and headroom. If you want a simple system for comparison, try input sub-octave filtering, a minicircuits level 10 or 13 mixer with an LO of 40 - 70MHz, 1st IF around 40MHz, simple passive filter say 1MHz bandwidth then a lossless feedback IF amp (Norton style, say 10dB gain, 3dB NF, OPIP3 over 40dBm), then a 20kHz wide crystal filter. This is just off the top of my head, and I've been out of this game for quite a few years. Note that the mixer termination is critical to achieving the mixer linearity.
I agree that a first LO with a 1kHz channel spacing will not get you to state of the art performance, but it is more in tune with the other components you were suggesting.
Peter
Tesla23 is offline
Old 22nd August 2008, 02:22 AM   #30
Sometimes when I post here the posts go straight up, on other times they get put on hold for vetting. I haven't made many posts but I would have thought it was pretty clear they weren't spam. Sorry Space Varmint but it is a bit hard to have a conversation when there is a day or two delay in posting - so I'm off..
For some reason this one went straight through, whereas my reply to you was held for vetting - you work it out.
Tesla23 is offline
control, digital, frequency
Suitable pwm frequency for motor control? shehry Robotics Chat 19 26th October 2009 08:49 PM
PWM Frequency for DC Motor Speed Control Yongleloo General Electronics Chat 2 31st May 2008 04:48 PM
remote control frequency Kurupt General Electronics Chat 9 13th June 2005 09:37 AM
Changing mains frequency for motor control vik1501 Electronic Projects Design/Ideas/Reviews 12 11th November 2004 07:24 AM
Delaying digital signal (frequency dividing) onder Electronic Projects Design/Ideas/Reviews 3 8th March 2004 12:45 AM
