Notices
Old 7th May 2008, 12:14 AM   #1 (permalink)
Experienced Member
Bob Scott is just really niceBob Scott is just really niceBob Scott is just really nice
Default Electromagnetic Theory
I'd like to understand electromagnetics a bit better. What is the definition of electromagnetic flux? I'm attempting to make a better equation for flux density.
Is flux static, like a measure of the magnetic field intensity, as the lines of force that you can see using iron filings over a bar magnet?
Or is it defined as dynamic only, applying to AC fields only? The equation for B (AC flux density) in Gauss in my Dad's old engineering books applies to AC voltages. These books are really terse.
The ambiguity is in the word "flux" itself. When something is in a state of flux it is changing.
Bob Scott is offline   Reply With Quote
Old 7th May 2008, 12:50 AM   #2 (permalink)
Experienced Member
Papabravo is a glorious beacon of lightPapabravo is a glorious beacon of lightPapabravo is a glorious beacon of lightPapabravo is a glorious beacon of light
Flux is like fluid flow. It is a characteristic of vector fields.
A fluid flowing through a pipe is a vector field, that is there is a velocity vector at each point in the field.
An electric field is a vector field, that is there is an electric field vector at each point in the field.
A magnetic field is a vector field, that is there is a magnetic field vector at each point in the field.
Atmospheric temperature is a scalar field, that is there is a scalar quantity at each point in the field.
Vector fields exert forces on real particles moving through them, scalar fields do not.
We never have time to do it right; but we always have time to do it over.
Papabravo is offline   Reply With Quote
Old 7th May 2008, 12:58 AM   #3 (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Flux does not always mean change. There are of course static electric fields, lightning being an obvious example. There are static magnetic fields, any polarized magnetic material is an example. One of the meanings for flux under the physics subdefinition of flux according to dictionary.com is:
A quantity expressing the strength of a field of force in a given area.
Static electric flux is easy to define, the number of electrons in a given area, moveable flux is different as the bulk of electrons in matter are all 'in use' so the net electric flux is zero. Magnetic flux is a bit more complex, I know little to nothing about exactly what gives rise to a static magnetic field, something I should probably look up one day. Electromagnetic theory is based primarily on the interaction of electric and magnetic fields which implies them changing, and non-moving electric or magnetic flux is pretty boring stuff.
Curiosity killed the cat; That's why they have nine lives.
Old 7th May 2008, 02:35 AM   #4 (permalink)
Experienced Member
Thank you very much Papabravo and Sceadwian! That clears that up for me.
Papabravo, thanks for refreshing vector/scalars for me. Thanks Sceadwian for seeing it at a different angle. The more points of view that you can get of a subject, the easier it is to understand intuitively.
Old 7th May 2008, 07:43 PM   #5 (permalink)
microtexan is on a distinguished road
Default Flux density equation
Why are you trying to make a better equation for flux density?
microtexan is offline   Reply With Quote
Old 7th May 2008, 08:05 PM   #6 (permalink)
Experienced Member
I thought it would be easier to design a saturating switching power supply transformer with a different equation for B.
The existing B=V*10^8/(4.44*A*N*f) uses AC voltage and frequency. I think current is more suitable.
So I've come up with some new ones:
B=0.1415*Al*N*I/A
B is in Gauss
Al is the core's inductance in milliHenries at 1000 turns.
N is the number of turns that pass through the core.
A is the core's cross sectional area in cm^2.
I've also come up with:
Al= *0.89*A/Le
= the core material permeability.
Le is the core's magnetic path length in cm.
This way you can easily see that the Al value is dependent only on core material and core geometry.
You see I had some trouble verifying the published specifications of an Amidon toroidal core FT240-77 made of type 77 material that has a characteristic permeability of 2000. The specs in Amidon's leaflet said it had an Al value of 3130. Their catalog said it was about 2750. My own test with an oscillator to determine inductance found the real thing to be closer to 1690.
I can elaborate on the derivation of the formulas but only if you're interested.
Old 7th May 2008, 08:20 PM   #7 (permalink)
Experienced Member
I don't mean to be impertinent but a saturated inductor in an SMPS sounds like a really bad idea. Are you sure that is what you want to do?
Old 7th May 2008, 11:00 PM   #8 (permalink)
Experienced Member
Oh, you would never sound impertinent.
The saturation is part of the oscillation cycle. As soon as the core saturates, the driving transistor turns off. It's been done before in photographic Xenon flash units and... remember the old Mark 10 capacitive discharge ignition? See:
Piezo + electromagnetic preamp steven_first_2001 Electronic Projects Design/Ideas/Reviews 2 25th October 2007 07:00 PM
difference between chat and theory?? philba Feedback/Comments 4 23rd September 2006 01:56 AM
Electromagnetic field interference. bananasiong Electronic Projects Design/Ideas/Reviews 2 11th June 2006 02:33 PM
Electromagnetic Flashing Stickers rahul986 Electronic Projects Design/Ideas/Reviews 24 13th July 2004 04:22 PM
Simple Remote Control Theory?? HANDzCLEANx General Electronics Chat 1 1st July 2004 06:12 AM
