Notices
Old 28th April 2008, 03:30 AM   #1 (permalink)
Experienced Member
rjvh is a jewel in the roughrjvh is a jewel in the rough
Default lightning
hi just wondering if sombody can explain this to me
so far i know the electrons flow from a negative pole to a positive one
but in the case of i lightning strike the positive ions build up in the sky and have a discharge to the negative pole (which is in most cases the ground)
is it than that the actual electron flow comes from the earth? according the the theory it should be
how can we explane the lightning flash that branched out in separate ways conecting it to the earth?
and how do we explane a lightning bold that first hit the surface and than travel to other directions until its power is absorbed by other points?
personaly i saw one in my life and the spot of impact was a small crater and sand that was turned into kinda glass but you still did see a track where it went then and that was still a 50 meters furter to an electrical distribution eclosure on the street
Robert-Jan
rjvh is offline   Reply With Quote
Old 28th April 2008, 04:13 AM   #2 (permalink)
Experienced Member
kchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of light
Lightening bolts can come from positive (more rare) or negative (more common) charges in the sky. So most of the lightning travels from a negative charge in the sky to the positively (relatively) charged earth.
kchriste is offline   Reply With Quote
Old 28th April 2008, 07:51 AM   #3 (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
I don't know whether positive or negative is more common in the sky- just that the earth is a giant source/sink for extra charge. But isn't there usually a smaller "leading" bolt that comes up from the ground to meet the larger main bolt coming down from the sky?
Perhaps the path is due to "the least resistance"? Except instead of wires it's air so you can see it. I suspect it is far more complicated than that though, and is in the realm fo electromagnetics. Lightning bolts like to hit where the electric field is most concentrated which tends to be at sharp points. From here it spreads out. It has to do with electromagnetics.
Disclaimer: Avatar for entertainment purposes only.
Old 28th April 2008, 12:50 PM   #4 (permalink)
3v0
Moderator
3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all3v0 is a name known to all
The potential between the striking and the struck is reduced by a strike. If another target is close the lighting may move to the 2nd target after the first has had it potential reduced.
To control the world from your PC with USB I suggest USB Bit Wacker
3v0's Tutorials for ABSOLUTE BEGINNER
C, PIC 18F, MPLAB® and MCC18 Compiler
3v0 is offline   Reply With Quote
Old 28th April 2008, 01:16 PM   #5 (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Lightning branches out in several directions, because it is following levels of low resistance. When lightning travels through the air, it creates a large amount of Ozone, x-rays and gamma rays (reccently discovered).
Visit my website!
http://www.freewebs.com/electronic-hobbyist
Krumlink is offline   Reply With Quote
Old 29th April 2008, 05:39 AM   #6 (permalink)
positronicle is on a distinguished road
This strike almost looks upside down.
http://youtube.com/watch?v=bNhY3Hx83fA&feature=related
positronicle is offline   Reply With Quote
Lightning Protection on Wind Turbines Aloefundi Alternative Energy 10 18th February 2008 08:09 AM
Ball Lightning Mystery Solved? Electrical Phenomenon Created in Lab Analog Chit-Chat 16 27th January 2007 03:09 PM
Lightning Warning? DigiTan General Electronics Chat 5 9th March 2006 04:06 AM
Lightning emp Oznog General Electronics Chat 4 5th March 2005 10:55 PM
Protection from Lightning??? grrr_arrghh General Electronics Chat 14 5th June 2004 12:57 PM
