| Notices |
| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
I learned this from http://www.bcae1.com/resistrs.htm
I know some true nooBs would like this info so i decided to post it again How to calculate voltage drop across series resistors. Step 1: Determine Current of total resistors across the series. (I = Current/V=Voltage/R(t)=Resistance Total) I = V / R(t) I = 9 / (2k + 5k + 10K) I = .53 mA Step 2: Now that we have the Current across the resistors we can calculate the voltage across EACH resistor. I = Current Vx=Voltage (x=Current Value across X Resistor) Rx=Resistor value(x=resistor#) V = I x Rx V1 = .53 mA x 2k V1 = 1.06V V2 = .53 mA x 5k V2 = 2.65 V3 = .53 mA x 10k V3 = 5.3V V1 + V2 + V3 = 9.01 (voltage is 9V only 9.01 because i rounded up from .529 to .53) At .529 you can see barely a difference: V1=1.058V V2=2.645V V3=5.290V V Total= 8.993V Also If the resistors are all the same value its easier. Quote:
I = V / R(t) I = 9 / (5k + 5k + 5K) I = .6 mA THEN: V = I x Rx V1 = .6 mA x 5k V1 = 3V so since all Resistors are same value: V2 = 3V V3 = 3V Also To get different values for like switches just use gnd as a start point and the end of each resistor and a end point. This way you get 3 switches from this each having different voltages SW1 = 3V SW2 = 6V SW3 = 9V So I hope someone can learn something from this. Last edited by AtomSoft; 8th March 2008 at 11:25 AM. |
Thank for posting this, Im quite beside myself with being dejected for being to stupid .
Im trying to figure out how to figure the voltage drop over to resistors. The example Im using is a DC circuit V=25 R1=3.3 R2=2.5 I =6.3 I told ( according to an quiz) that the voltage drop @ R1 is described as 21V and R2 as 14 I have know idea how to come up with those values. Any insight would be greatly appreciated. Last edited by FITNAH; 21st March 2008 at 09:35 AM. |
So if E= IxR what do you get? Last edited by Rolf; 21st March 2008 at 02:27 PM. |
34.65a.
I get 6.36 for I ,dividing the combined resistance into V. which then in turn gives me a voltage drop of 20.79 =R1 and 15.75 =R2 which also doesn't add up to 35 the original answer. |
Sorry typo, the model I have here is V =35
4.54 is of course correct, sorry about being sloppy. |
I already feel like quit the idiot over not knowing how to find this answer and now flubbing the question hasn't helped,
In any case their must be a formula for finding the voltage drop over two or more resistors of different values |
Thanks, the voltage drop across the resistors must add up to the voltage correct?
For a start draw the circuit and post it here!.
Oh this is to embarrassing,
I glad it happened here before any classes started I haven't been in school for 20 years. I went back to find the problem and to my relief I found, Im still an idiot, just not the kind I was beginning to believe I was. I had mistake when I copied the problem off the internet, then went about trying to get the right answer with the wrong numbers. This has been a very good lesson for me. Take your time check what you are doing and pay attention . R2 is 2.2 not 2.5. |
Copying errors cause a lot of problems. Make sure you read over the entire problem on tests, too. That caused me a lot of headaches.
Thanks I'm now in class and doing well.
Im glad to see this was helpful.
| Read current (voltage drop across resistor) in two directions | Odysseas | Micro Controllers | 22 | 18th October 2007 04:24 AM |
| Power Supplies | jack23 | General Electronics Chat | 3 | 9th October 2007 04:11 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| E-C voltage drop on ULN2803 | William At MyBlueRoom | General Electronics Chat | 3 | 26th July 2006 04:41 PM |
| Battery Voltage Drop Off | roadkillbunny | General Electronics Chat | 1 | 1st February 2004 10:10 PM |
