| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
Can any one explain to me how you decide the capacitor values for a ckt. example a voltage divider for a transistor.. i know that the parallel combination of R1 and R2 is 1/10 of HfeRe but how do you choose Capacitor values?
__________________ I just cant come up with a good one! | |
It depends on the application. Sometimes the formula is given on the datasheet, i.e. 1.1RC for a monostable 555 timer. You might just use a standard value, i.e. 100nF for a decoupling capacitor. Often the capacitor's impedance is important because to want to make sure the capacitor can pass low enough frequency signal. The formular for impedance is:
| | #3 | |
Yeah I know, it is the formula for the impedance of a capacitor.
Impedance and reactance are not the same thing. Sorry, but that is, once again, the formula for capacitive reactance, not the impedance of a capacitor. For an ideal capacitor, you can get away with stating that the value given is also its impedance, but real-world caps also have inductive (particularly large electrolytics) and resistive components which, while generally small, are nonzero.
| | #6 |
i know that a capacitor has reactance. so is there no specific formula like ohms law for current,voltage,resistance which can be used to set the capacitor values in any circuit??
| | #7 | ||
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | |||
| | #8 |
i know this is an off topic question, but plz answer me. Can someone tell me, what does capacitor really do in a circuit?
| | #9 |
Deppends on the application. Can be used for filtering/bypassing, blocking DC, RC timing constants... | |
| capacitor, values |
