| Electronic Theory Basic principles, ideas, concepts, laws, and formulas behind electronics. |
Is there a Formula for calculating household electrical items? I was thinking of buying a generator but I need to know how much electricity all the appliances use so that I can get the right generator for the job. I have all the manuals for each appliance which give how much power each appliance uses. I do not know how much power a combie boiler uses if anybody knows that information can you please share that information with me. | |
Just add up the power used (look at the manuals) by alll the appliances in your house. Also, look at the current rating rather than just the power. Generators are normally specified in apparant power (VA) rather than power. Some loads will have a poor power factor, meaning they will draw a lot more current than you'd expect. Short of going round with a meter and measuring the current consumption of everything, you're better off just estimating it if it isn't printed on the manual. For example the combie boiler uses natural gas for the heating, it only uses electricity for the ignition and control circuitry so I'd allow for 50W at the most.
Thank you for your reply the information is very useful
You might check the Northern Lights or Westerbeke or Onan sites. They should have tables and formulas. For reliability and a simple control circuit I recommend Westerbeke. Do not buy Onan.
__________________ C:\WHUT ? Beware the asterisk * | |
Let me ask you a question in return. Are the devices that you plug into a household socket in series or in parallel?
__________________ We never have time to do it right; but we always have time to do it over. | |
| | #6 |
Surely that's a silly question? The sockets are wired in parallel, therefore the devices are all connected in parallel.
| | #7 |
If they were wired in a series, wouldn't you need more voltage? Then again, i know nothing about AC...
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| | #8 | |
As I am with Scottish Power would they have that information. | ||
| | #9 | |
| | #10 |
It sounds like you're talking about an RCD which cuts off the power when some of the current leaks to earth. I was talking about series and parallel circuits. http://www.berkeleypoint.com/learnin...l_circuit.html All the devices in your house will be connected in parallel apart from a set of christmas tree lights.
| | #11 | |
AC works exactly the same as DC until you get tied up with the complecities of power factor. If they were all wired in series the voltage would depend on what else you have connected and all the plugs would have to have something connected for anything to work. Connecting loads in series done with a constant current supply, for example a LED lighting system might use one switching power supply which produces a constant current of 325mA - to increase the load you add more LEDs in series.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #12 | |
that is what happens when i get tired...
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | ||
| | #13 | |
| | #14 | |
| | #15 | |
i seen many building schematics and i came across 3 names ELB (earth leakage breaker) ELC (earth leakage contactor) EFR (earth fault relais) if you hear the full name it it's straight forward but if you but if you say to me RCD so RCD stands for what?? Robert-Jan Last edited by rjvh; 10th April 2008 at 10:16 AM. | ||
| electrical, formula, household, items |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| what is the formula for luminance(lux) | yuchween | General Electronics Chat | 2 | 24th July 2006 09:58 PM |
| UK - 3 PHASE ELECTRICAL SUPPLY | Asjad | General Electronics Chat | 3 | 7th November 2004 08:49 PM |
| Computer Engineering + Electrical Engineering ... | sonaiko | General Electronics Chat | 13 | 17th August 2004 12:23 AM |
| electrical conductance | xcidu | Electronic Projects Design/Ideas/Reviews | 3 | 18th November 2003 01:55 PM |
