Thread Tools Search this Thread Display Modes
Old 16th November 2007, 01:20 AM
Experienced Member
mabauti is on a distinguished road
Default NiMH & NiCad batteries
What precautions must I take when connecting (2 1.2VNiMH 1600mAH batteries in series) and (2 1.2VNiCad 600mAH batteries in series) in parallel in order to have 2.4V?
mabauti is offline   Reply With Quote
Old 16th November 2007, 01:33 AM
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Your question is too vague. Under most circumstances 2 3 or 4 cells in series will require no additional precautions as long as the cells are from the same production line at the same time.
With multiple cells in series it's common to be a little understated in it's charging requirements compared to a full cell and to do a low current equalizing charge periodically.
12 volt car batteries are after all in fact 6 2 volt (nominal) Lead acid cells in series.
Curiosity killed the cat; That's why they have nine lives.
Old 16th November 2007, 01:50 AM
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
I think he wants to charge the old small-capacity Nicads from the newer higher capacity Ni-MH battery. That wastes power.
Instead of using 1600mAh plus 600mah= 2200mAh but it will never be reached, buy new 2500mAh AA Ni-MH calls. They just keep on going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and going and ....
Old 16th November 2007, 02:25 AM
Experienced Member
Oznog is a jewel in the roughOznog is a jewel in the rough
Send a message via AIM to Oznog
Even if you had 2x IDENTICAL 2.4V 1.6AH NiMH packs, you can't put them in parallel. Neither NiCd nor NiMH can be put in parallel, even though basic electronic theory predicts they'd be fine.
At odds with this practice is the charging voltage profile on these batts. When charging, typically one will take more current than the other leading to one fully charged batt and one partially charged batt. Continuing to charge may only result in further overcharging the already full batt.
So can we chare them separately and put them together to get one big storage batt? Unfortunately, no. When put in parallel, one batt will typically discharge into the other one- leading to one mostly dead batt and one which has been overcharged (which permanently decreases the batt's capacity).
Technically, you could charge separately and put each series string in series with a diode so it cannot take charging current from the other batt. Problem there is that's a 0.7v diode drop (Schottky may not be a great choice because of its own reverse leakage current). In a 2.4V batt losing 0.7v is probably not going to be acceptable.
Oznog is offline   Reply With Quote
Old 16th November 2007, 02:26 AM
Experienced Member
Gayan Soyza is just really niceGayan Soyza is just really niceGayan Soyza is just really nice
@ mabauti
Its useless isn't it? yes the above ideas are right better buy a higher capacity ones.
I always use same type & same capacity batteries.
Gayan
Forum Supporter
Gayan Soyza is offline   Reply With Quote
Old 16th November 2007, 03:25 AM
Experienced Member
I built a little stereo amp for the beach. It used two series strings of 6 AA Nicads with the strings connected in parallel. It worked fine and lasted for many years.
After about 10 years it didn't work and I discovered that all 12 cells were shorted.
Old 16th November 2007, 07:53 AM
Experienced Member
My vote is giving to your stereo amp which worked with you for ten years and not for your batteries .
I have notice that some DIY circuits last longer than ready made ones.
Gayan
Forum Supporter
Old 16th November 2007, 01:39 PM
Experienced Member
mvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of light
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
I feel , Mabauti wants to parallel two sets of 2.4V batteries. one is a set wirh ni-mh and another with ni-cd with different capacities.
Regards,
Sarma.
mvs sarma is online now   Reply With Quote
Old 16th November 2007, 04:25 PM
Experienced Member
TheVictim has a spectacular aura about
Send a message via AIM to TheVictim
I discovered the hard way that ni-cads' propensity for self discharge is magnified 198728912738912738912 times (OK, that's an exaggeration, but not by much) if they are in parallel. I built an external power pack for a very old laptop that ran for a dissappointing 20 minutes from some small ni-cad cells. I figured I'd get 40 minutes if I used another pack wired in parallel. I did, but if I let the thing sit for long after charging it would be stone dead. Eventually all the cells crapped out after a really short time.
Don't do it.
TheVictim is offline   Reply With Quote
Old 16th November 2007, 05:35 PM
Experienced Member
Was the server down yesterday? I could not connect it >_>
anyway, I forgot to poste a figure ,sorry :
Old 16th November 2007, 05:49 PM
Super Moderator
Originally Posted by mabauti
Was the server down yesterday? I could connect it >_>
No, don't do that! - BAD idea!.
Old 21st November 2007, 05:17 PM
Experienced Member
speakerguy79 is on a distinguished road
Send a message via AIM to speakerguy79 Send a message via MSN to speakerguy79
But straight series connections are fine, yes?
I also doubt ballast resistors to balance current output from each would be of any use here?
speakerguy79 is offline   Reply With Quote
Old 21st November 2007, 05:21 PM
Super Moderator
Never EVER, EVER mix different types of batteries - it's just asking for disaster!.
Old 21st November 2007, 07:35 PM
Experienced Member
so, what extra connections/elements I must use?
Old 21st November 2007, 08:20 PM
Experienced Member
I meant series connections of the same type of battery technology
Search this Thread:
Advanced Search
Simple 6xAAA NiMH or NiCad charger? William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 7 17th November 2006 04:57 AM
Most complex NiMH / NiCAD charger ever! William At MyBlueRoom General Electronics Chat 1 6th July 2006 03:10 AM
Charging NiMH batteries bonxer General Electronics Chat 2 9th June 2005 11:48 PM
NiCad Charing - with NiMh charger... pittuck General Electronics Chat 2 25th March 2005 11:51 AM
PC Controlled Charger for NiMH / NiCd / Batteries Ray_of_hope Electronic Projects Design/Ideas/Reviews 1 2nd February 2003 02:02 AM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
