Thread Tools Search this Thread Display Modes
Old 20th July 2006, 03:39 AM
Experienced Member
srimannarayanakarthik is on a distinguished road
Send a message via Yahoo to srimannarayanakarthik
Lightbulb but
Originally Posted by Optikon
OK, here's the strange discussion! (and I can't explain it!)
The person who is driving car 2 does see forward and backward moving cars 1 & 3 from THAT perspective. However, an outside observer sees all three cars moving in the SAME direction.
Now, are you an outside observer (with ammeter in hand!) or are you riding on an electron trying to measure/observe the current?
An electromotive force can "push" an electron. Electrons can push each other due to same charge even though they don't need to "move" very far.
So if it makes sense to you how they can "flow" in one direction in a conductor, then they can also flow the other way.
Here is the collection of smilies apparently available:
:cool:
but if they are movin in either direction then how can say 1 wire as phase and the other as neutral.
and about the ammeter, it too contains coils. so what v measure is just a reference quantity. but not the exact value. so the electrons in the ammeter either vibrate with the same frequency of car2 so that v would be able to meaure the accurate value
srimannarayanakarthik is offline   Reply With Quote
Old 20th July 2006, 08:03 AM
Super Moderator
Phase and neutral don't mean anything, they are purely arbitary terms, it's ONLY how the neutral is connected that makes it neutral, and the other phase (or live).
Old 21st July 2006, 05:00 AM
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
The voltage difference between the two leads just happens to be the AC sinusoid. In reality, either lead could be whatever voltage you want relative to the surroundings/ground, as long as the voltage difference between the leads always makes a sinusoidal wave.
The neutral just means that one of the leads just happens to be tied to the ground so that it doesn't float around too much. But it doesn't have to be for AC to work.
IN the general case it is not necessary to have a "fixed constant" voltage reference in AC. It's just the difference between the two. You can think of it one of the wires (it doesn not matter which one,) as a reference that changes. Sometimes one is tied to ground which fixes the reference, but again, it's not necessary.
Old 30th July 2006, 01:11 AM
dreadengineer is on a distinguished road
I think we should be clear that in AC current, the electrons do actually turn around and flow back the other way. If it doesn't make sense that you can get power out of that, think of it like water in a pipe. If the water flows back and forth, you can still put a propeller in the water, and it will be turned alternately forward and backward, and you can get power from that. The source of the power comes from whoever is pushing the water forward and pulling it back, which is the power company. You can get power from AC current the same way. For example, an AC motor makes the electrons do work as they move forward and again as they move back.
It's probably less confusing to just think of the voltage: the voltage between the two plugs on a power outlet alternates -- first a higher voltage on the right one, then a higher voltage on the left one, and you take that voltage and do something with it.
dreadengineer is offline   Reply With Quote
Old 30th July 2006, 01:21 AM
Also, about voltage, like the post above was saying, voltage only has meaning as the RELATIVE voltage between two things. That's how we can say that one wire of the power outlet is neutral: it's held at the same voltage as the ground. So if you touched that wire and touched something that was grounded, like a water pipe, you shouldn't get shocked. But the other wire is going between +120V and -120V relative to ground. So if you touch it and the ground, you will get shocked, because there's a relative voltage. Whenever someone says something is at a voltage, like, "this wire is at 5V" it is implicitly relative to a reference. For example, in a portable device, it's relative to the - terminal of the battery. Saying that the wire is at 5V means it's 5V higher than the - terminal of the battery.
Old 30th July 2006, 03:33 PM
Experienced Member
Hero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to behold
The -v terminal of the battery is often considered to be the referance point 0V. Dual power supply circuits have the referance point taken between the two batteries.
Old 5th August 2006, 10:49 AM
gokulakannan is on a distinguished road
hi i'm a Final year Electrical & Electronic Engineering student like to do a project in Embedded systems i need a sample projects for my reference
gokulakannan is offline   Reply With Quote
Old 29th January 2007, 03:26 AM
Experienced Member
mybuickskill6979 is on a distinguished road
so the amount of electrons that pass a given point in one second is an amp? and a coulomb? Sweet!!
thats one word that confused me when reading about farads and capacitance!!
mybuickskill6979 is offline   Reply With Quote
Old 29th January 2007, 03:51 AM
Experienced Member
Roff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to behold
An amp is one coulomb per second. The number of electrons in a coulomb is 6.2415*10^18.
Ron
Roff is offline   Reply With Quote
Old 29th January 2007, 07:36 AM
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
Thumbs up
hi srimannarayanakarthik,
Look at the thread 'electron velocity' download the *.zip posted by luisgerman.
This should help you visualise electron 'movement' in a conductor.
Regards
EricG
ericgibbs is online now   Reply With Quote
Old 29th January 2007, 04:29 PM
Experienced Member
thats alot of electrons. Thanks Ron.
Old 30th January 2007, 01:16 AM
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
You should try calculating the amount of electron motion that occurs for a thousand watt space heater benig on for 8 hours.
Curiosity killed the cat; That's why they have nine lives.
Old 22nd March 2007, 10:20 PM
Experienced Member
ikalogic is just really niceikalogic is just really niceikalogic is just really nice
Send a message via MSN to ikalogic Send a message via Skype™ to ikalogic
i like this analogy between hydraulis and electricity
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline   Reply With Quote
Old 23rd March 2007, 01:38 PM
Experienced Member
OutToLunch is on a distinguished road
i don't remember the specifics anymore, but in a system dynamics class in college, we took mechanical systems and translated them to an 'equivalent' electrical circuit and would use that to predict response. i remember having to do a project where the response of a car was found in relation to the tire hitting a bump in the road. The mass translates to inductance, Springs translate to capacitors and the shocks (dashpots) translate to resistors.
OutToLunch is offline   Reply With Quote
Old 23rd March 2007, 01:51 PM
Experienced Member
Sounds like LRC circuits and second order differential equations, I was never any good at that the lecturer being crap didn't help much either.
Search this Thread:
Advanced Search
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 02:44 PM
Voltage Clamp ThirtyTwo General Electronics Chat 41 11th August 2006 04:05 PM
I am not getting ripple voltage at the output dar2525 General Electronics Chat 3 14th July 2005 02:21 PM
LED Project... Is the diagram correct? Maxer Electronic Projects Design/Ideas/Reviews 45 9th December 2004 03:18 PM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
