hi, Most of us 'know' the velocity/speed of radio waves and electrical effects. A tutor once asked me, what is the actual drift velocity of 'individual' electrons, as current carriers in a conductor. I took the trouble to reference the answer this, its an unexpected result. I expect the more experienced members will know. Any Newbie want to give it a shot? EricG | |
| | #2 | |
I was about to upload a .doc file, but it exceeds the permissible weight Please e-mail me so I can send it to you Kind Regards: Luis German | ||
I don't know exactly what you're asking, but electricity generally flows through wires at a lower speed than the speed of light. Perhaps you should do some research into transmission lines. http://www.google.com/search?client=...utf-8&oe=utf-8
| | #4 | |
(excerpts from the document I tried to upload) The drift speed of electric charges The mobile charged particles within a conductor move constantly in random directions. In order for a net flow of charge to exist, the particles must also move together with an average drift rate. Electrons are the charge carriers in metals and they follow an erratic path, bouncing from atom to atom, but generally drifting in the direction of the electric field. The speed at which they drift can be calculated from the equation: ....................... Over a wide range of conditions, the flow of the charges quickly achieves a steady state value and remains constant. The "average speed" at which the "free" charges are moving in the wire is called the drift velocity vd. .......................... The current in a wire can be expressed as function of the number of charge carriers/volume, the magnitude of the charge carriers, the drift velocity of the charge carriers, and the cross-sectional area of the wire. ........................... Electric currents in solid matter are typically very slow flows. For example, in a copper wire of cross-section 0.5 mmē, carrying a current of 5 A, the drift velocity of the electrons is of the order of a millimetre per second. To take a different example, in the near-vacuum inside a cathode ray tube, the electrons travel in near-straight lines ("ballistically") at about a tenth of the speed of light. The above are just excerpts which donīt include the math, discussion ...etc Last edited by luisgerman; 28th January 2007 at 05:29 PM. | ||
hi luisgerman, Many thanks for you informed response. Like you I have an understanding of the actual flow rate. Once an novice engineer realises what is actually happening at the electron flow level, it brings a greater understanding of the meaning of 'resistance' and 'impedance also the causes of heating in a conductor. Ohms law is ideal for solving circuit equations but does not explain the cause. Regards EricG PS: I will PM asap. Is it possible to zip your *.doc and try to re-post it, I am sure other members would appreciate it. Last edited by ericgibbs; 28th January 2007 at 05:53 PM. | |
| | #6 |
hi hero, Thanks for the 'transmission line' link, but as you can see from Luis reply, that was not what I had in mind when I posted the OP. Like yourself, many engineers think that the electron current carriers 'move' along the conducter just below the speed of light. As you can see its actually 'flows' at mm/Sec. Thanks for the interest. Regards EricG | |
| | #7 | |
| | #8 | |
Regards: Last edited by luisgerman; 28th January 2007 at 07:33 PM. | ||
| | #9 |
You might not care Nigel and it doesn't make a practical difference but it does make a difference from a scientific standpoint. Simply teaching only the way things practically work is basically trying keeping people dumb about a fundamental way things work. Not saying the whole world has to be brainwashed into only doing things from one standpoint but saying it's not important is short sighted.
| | #10 |
hi nigel, I placed the OP on this section as its the 'theoretical' section, to stimulate a discussion on the topic. I see that you have also posted to the thread, OP 'voltage' You can see the that a poster to 'voltage' has limited knowledge of whats actually happening in a metallic conductor carrying a current. If he had some insight into electron flow, he would know the answer to his question.[ the guy using the car analogy] Regarding 'I don't care what the electrons are doing' in your post, how do explain to your students the causes of 'noise' generation in a conductor carrying current.? How do you explain the function of semiconductors ? Most students still think a semi-conductor is a conductor that dosn't conduct very well!! [the answer one gets to technical questions, when interviewing students for technical posts can be quite 'scary'] Regards Eric PS: thanks luis for zip. Last edited by ericgibbs; 29th January 2007 at 09:31 AM. | |
| | #11 |
Wait before we close the discussion now the drift velocity is very small in practical situations for example the drift velocityof electrons through a copper wire of cross section 2millimetresquare if 1 cc of copper contains 8.5*10 to the power 22 electrons is 0.0036mm/s which is very small but the moment we switch on things start working which are connected by copper wires covering long distance can someone explain this?
| | #12 | |
electrical signal down a wire.Electrical signals are electromagnetic waves which propagate at very high speed outside the surface of the conductor (moving at the speed of light, as can be deduced from Maxwell's Equations). The waves of electromagnetic energy propagate rapidly through the space between the wires, moving from a source to a distant load, even though the electrons in the wires only move back and forth over a tiny distance. Although the velocity of the flowing charges is quite low, the associated electromagnetic energy travels at the speed of light, the velocity factor being the ratio of the signal velocity versus the speed of light. When a Voltage is applied across the ends of a wire, an Electric Field is created inside the wire. In a vacuum the electric field would cause a charge to accelerate. In a wire, collisions of the conduction, charges with impurities, imperfections, and vibrations of the atomic lattice causes the motion of the conduction charges to be slowed down. This represents a loss of energy which is dissipated as heat. The "average speed" at which the "free" charges are moving in the wire is called the drift velocity vd. The current in a wire can be expressed as function of the number of charge carriers/volume, the magnitude of the charge carriers, the drift velocity of the charge carriers, and the cross-sectional area of the wire. (arranged excerpts from zip above)
__________________ Luis German | ||
| | #13 |
THANX Luis I couldnt open the zip file .so current is not flow of electrons????????
| | #14 | |
Electrical current is a coarse, average quantity that tells what is happening in an entire wire. So, as stated above the current in a wire can be expressed as function of the number of charge carriers/volume, the magnitude of the charge carriers, the drift velocity of the charge carriers, and the cross-sectional area of the wire, not just the flow of electrons.
| | #15 |
Well in some ways it's similar to a wave travelling across the water. The wave travels at a fairly high speed but the water itself goes nowhere. Like a stick in the water will stay in the same place as the wave rushes past. Of course there are major differences- electrons do actually move in the wire.
| electron, velocity |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| how to identify the layouts in a die seen 4rm electron microscope? | monica_mit8 | General Electronics Chat | 3 | 19th January 2007 09:34 AM |
| Just the basic but not simple: Control velocity of DC motor. | wonbinbk | General Electronics Chat | 1 | 1st May 2005 11:46 PM |
| controlling velocity | zika1212 | Micro Controllers | 3 | 25th May 2004 10:49 PM |
| velocity and direction control | lepton | Robotics Chat | 0 | 18th November 2003 01:00 PM |
