| | #76 | |
Well...okay...I didn't really... But, it's true that there's energy in sugar. Since we've veered a bit, here's a video that I find rather interesting (and, more than just a little disturbing). The guy builds a model rocket motor using methods that should give everyone pause for thought about just how little it takes for terrorists to produce some pretty potent stuff. Anyway, here's the link if you're interested to see: http://www.tricklife.com/view.php?id=2217 Oh, yeah...since it catches fire or blows up, you do have to sign up for the site to view it but, I'm sure the same video is available at several places on the web. | ||
| | #77 |
Hehe, very good :Þ They made this one sideways but you don't have to join...Just imagine if it was not open and the gas had no escape.. A smoke bomb when in can vent, something very much different when it can't... http://www.youtube.com/watch?v=m903HoTnk80 Yep, lots of energy locked up in atoms in general ![]() -BaC
__________________ Error[888] "while trying to load":[reality.sh] kernel: [Panic!]...{Universe has been Modified!}... Last edited by BaCaRdi; 11th October 2008 at 10:54 PM. | |
| | #78 | |
- Worst thing was absolutely no technical details of what they were doing. - Very poor camera work with an obviously cheap digital camera in movie mode. - Lots of snickering in the sound, suggesting dweebs trying to pull off some "Jackass" type stunt...and, pretty much failing... - Video was way too long for essentially doing nothing but burning out most of their mixture. - The lingo was in some crazy foreighn language. Okay...that's okay because it shows that we Yanks aren't the only incompetent idiots in the world... I did look at a couple of other "sugar bomb" videos that came up as suggestions at the end of the video and, sad to say...they were no better or useful. | ||
| | #79 |
Well the term "backwoods" doesn't mean the woods of USA, in all counts ![]() Matter of fact, "Darwin" comes to mind...off-hand of course ![]() -BaC **Please don't try this, or else you may become an statistic.**
__________________ Error[888] "while trying to load":[reality.sh] kernel: [Panic!]...{Universe has been Modified!}... Last edited by BaCaRdi; 13th October 2008 at 05:43 AM. | |
| | #80 |
| Two questions come to mind while watching the posted video (without audio because I was in a public place) – what types of combustion are best for harnessing pressure, and why are so many pictures taken of the smoke in the road? Also, in what ways can heat energy be harnessed? One person was able to provide what seemed like a really good explanation of why heat can’t be used as an energy source in terms of entropy and enthalpy (which is a little too much for me to try and explain right now), but, then again, heat rises in one direction.
| | #81 | |
At the local level, I guess my consideration would be the type of containment one might need to turn what they did into an explosive device and what sort of power could be extracted from it. Often, when building something like this, the rate of combustion is too slow and the pressure just "leaks" out (basically what happens with a rocket motor). Considering that it took several minutes for the boys to burn out their mixture, I'm guessing that their pyrotechnics would not be suitable as an explosive device in itslef but might serve as something like a fire bomb that would have a minimal explosion but, that would spew incindiary material into the vicinity. Others may have different opinions. | ||
| | #82 |
| Were you referring to sound pressure, the way that the words sound, or something else? I learned – actually from someone in the biology department, that enthalpy energy can be harnessed. However, in at least one case, the heat released by a system was regarded as entropy – and therefore couldn’t be harnessed. We were talking about the Sony glucose battery - and, in general, to biological sources of electricity (which lose energy due to heat) at the time. I’ve heard of steam engines. If there is such thing as a steam generator, then it would produce electricity from heat mechanically. I was thinking of ways to harness heat chemically or physically – such as by facilitating or increasing the rate of a endothermic chemical reaction that generates an EMF.
| | #83 | |
Well, matter can be neither created or destroyed (in our univers, anyway) so, (as I undertand...or misunderstand it), every action that converts energy to matter represents a loss of energy and a correspnding increase in the matter of the universe. Since it takes more energy to "reconvert" the matter to energy than it took to change it from energy to matter, the energy is lost to the system (entropy). In the immediate "present", sometimes it would seemt to work the other way. If yoiu light a match, some of the mass of the match is converted to energy and the match becomes lighter and there is more energy around. But, there is an eventual cost of the energy. On the nuclear level, once you convert a lighter element to a heavier one, through fusion, I'm not sure there'a a mechanism to convert it back. Are there "atom smashers" that have enough power to do it? Even if there is, it takes more power than you get back. Presumably, within the realm of the elements of our universe, the materials will all go to the lowest energy state (represented by iron) and can go no further. But, we know that's not true because we know of at least two further levels; the neutron state (where the electrons, protons, neutrons and presumably all other particles are crushed together into a neutral state), and the black hole (where the compression is so great that nothing can escape to measure and thus may remain an enigma). I suppose it would be trite and foolish to think that the black hole is the endpoint of it but, from our perspective it may always be. I suppose it's reasonable to surmise that the eventual fate of the universe (as we know it) will be when ALL the matter eventually succumbs to gravity and produces a massive black hole of the mass of the entire universe. My prediction (safe, since I can't be proven wrong) is that when that happens, it will trigger another explosion that will represent another "big bang". In other words, our universe is an oscillator (which may be the perpetual motion machine the dreamers dream of ...or, it may be something else entirely). If it is an oscillator, then the whole concept of entropy may go out the window because all the energy comes back again in the next iteration of the universe. Hmmmmm...but, if not ALL the energy comes back (damped oscillation), then, we must create a theory of where that energy goes to........... | ||
| | #84 | |
Funny but that has always been my "gut feeling" on the how and why of the Big Bang. However I've never seen it expressed in any of the science channel programs dealing with the subject. Anyone know if it is an "official" possible theory in Astrophysics circles? Lefty
__________________ Measurement changes behavior | ||
| | #85 |
| What happens when a positron and an electron meet? I thought they canceled out and basically became nothing. Or maybe it wasn't the positron, it was one of those imaginary particle things that Stephen Hawking covers in his book A Brief History of Time or something like that. I know what I'm talking about happens at the edges of black holes, but I can't remember the exact name of it as I read the book like 6 years ago.
| | #86 | |
But, that's something different. It's the last thing we are able to see of something before it's sucked into the black hole. But, we don't really see it What we see are strong emmissions of radiation as the matter (and energy?) disappear from our ability to perceive it. | ||
| | #87 |
| | #88 |
| I think it is like a tube full of marbles. The marble that immediately comes out of the tube is not the same one that just went in but it might as well be.
| electron, velocity |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| how to identify the layouts in a die seen 4rm electron microscope? | monica_mit8 | General Electronics Chat | 3 | 19th January 2007 09:34 AM |
| Just the basic but not simple: Control velocity of DC motor. | wonbinbk | General Electronics Chat | 1 | 1st May 2005 11:46 PM |
| controlling velocity | zika1212 | Micro Controllers | 3 | 25th May 2004 10:49 PM |
| velocity and direction control | lepton | Robotics Chat | 0 | 18th November 2003 01:00 PM |
