| | #31 |
1cm a second? Where'd you come up with that random number?
| | #32 |
1cm/s. Right, that's that all cleared up then. I don't suppose you happen also to know the speed of water molecules in a pipe?
| | #33 |
I'm just really pleased I moved this silly thread to the Chit Chat forum! | |
| | #34 | |
The Super Moderator calling this thread a silly thread Next think I expect from you is to throw me out of this forum IŽll be pleased if you do so (My last post as long as you are the moderator)
__________________ Luis German | ||
| | #35 | ||
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | |||
| | #36 |
As long as it's actually in the chit-chat forum now I don't feel so bad about leaving one sentance pointless replys.
| | #37 |
Current measured in amps, 1amp = 1Coulum/1sec. 1 coulum = 6.25X10^18Electrons.
__________________ NeoMach | |
| | #38 | |
| | #39 | |
| | #40 |
according to einstein's laws e[v+phase ]=hc where e=electron charge =1.6x10-19 coulombs phase=work function in volts =6.6x10-34 joule/sec c=velocity of light=3x10+10 so now do your math.ephase=hc/lanbda=12000 armstrong units of course thiese are photons emissions.
| | #41 |
Eye Captain, I'm givin you all shes got, at this rate she is sure to blow at any moment. Lefty
__________________ Measurement changes behavior | |
| | #42 |
~4cm/s if I remember correctly
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
| | #43 |
See: http://hyperphysics.phy-astr.gsu.edu...ic/ohmmic.html In brief, the citation assumes a physical model in which each atom of copper has one mobile electron. There are so many atoms in a wire with a diameter of 1 mm that the wire can pass 1 A with a very low drift velocity. For example, the aforementioned wire has 6.62X10E20 copper atoms per lineal cm. Assuming one mobile electron per atom, that is equivalent to approximately 100 coulombs of mobile electrons per cm. Thus, a current of 10 A would have a drift velocity of only 1 mm/sec. Of course, that conclusion is dependent on the validity of the assumed number of mobile electrons per atom that are involved during conduction. John | |
| | #44 | |
| | #45 |
O.K. i just have had a look at this thread it is a mixture of scientific and silly discussion, any way I think it was earjun who asked that "How an electron get to the destination as soon as we turn on the switch, the destination being at very far?" and there was the answer from luisgerman explaining about electromagantic wave and that stuff ( all these on page 1 of the thread)....... Well I'm not a genius but this is what I was tought in school, an electron enters into conductor from negative terminal of source and at the same time one electron gets out of the conductor at the other end being pulled by positive terminal of the source.Look at the Doc, If an electron actually travels THROUGH the conductor than that would change the whole atomic structure of the conductor (COPPER), The image explains why the electricity reaches to destination as soon as the switch is closed.
__________________ CHRIS Last edited by c36041254; 24th September 2008 at 06:41 PM. | |
| electron, velocity |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| how to identify the layouts in a die seen 4rm electron microscope? | monica_mit8 | General Electronics Chat | 3 | 19th January 2007 09:34 AM |
| Just the basic but not simple: Control velocity of DC motor. | wonbinbk | General Electronics Chat | 1 | 1st May 2005 11:46 PM |
| controlling velocity | zika1212 | Micro Controllers | 3 | 25th May 2004 10:49 PM |
| velocity and direction control | lepton | Robotics Chat | 0 | 18th November 2003 01:00 PM |
