Old 3rd February 2007, 01:31 AM   #16
The water doesn't go anywhere until it gets close to shore at least, what little water motion actually occurs in large bodies of water is basically the same as heat generation in a conductor. There's actually very little difference.
straight answer, har har."
Sceadwian is offline
Old 3rd February 2007, 07:42 PM   #17
Originally Posted by luisgerman
In a vacuum the electric field would cause a charge to accelerate. In a wire, collisions of the conduction, charges with impurities, imperfections, and vibrations of the atomic lattice causes the motion of the conduction charges to be slowed down. This represents a loss of energy which is dissipated as heat.
Is it not the other way round? I mean its heat that causes the vibrations of the atomic lattice, not the vibrations causing heat?
Its been a while since my devices class so i cant remember much.
My Space
elMickotanko is offline
Old 3rd February 2007, 08:21 PM   #18
If two particles are next to each other, and they are given energy in the form of motion, then they collide, they change their relative amount of kinetic energy(motion) and transfer some of it as heat. Energy can neither be created nor destroyed.
ZIGGY_DAN is offline
Old 3rd February 2007, 09:38 PM   #19
elMickotanko:
Acute observation, yet not precise elMickotanko
(but indeed this kind of queries are what make things to be cleared up, and concepts to become solid and improved; thanks)
Heat transfer occurs by atomic lattice vibrations in solids. These vibrations can be broken down into the superposition of normal modes normal vibration. Through quantum mechanics and the wave-particle duality, these normal modes can be treated as particles. These particles are called phonons, which are in the class of particles called bosons. Lattice vibrations, and therefore phonons, travel at the speed of sound through a solid.
In thermodynamics and solid state physics, the Debye model is a method developed by Peter Debye in 1912 for estimating the phonon contribution to the specific heat (heat capacity) in a solid. It treats the vibrations of the atomic lattice (heat) as phonons in a box, in contrast to Einstein model, which treats the solid as many individual, non-interacting quantum harmonic oscillators. The Debye model correctly predicts the low temperature dependence of the heat capacity. Just like the Einstein model, it also recovers the Dulong-Petit law at high temperatures. But due to simplifying assumptions, its accuracy suffers at intermediate temperatures.
Following Planck’s idea on “energy quanta” originally applied to black-body radiation (1900), or according to the quantum mechanics founded by Heisenberg and Schr¨odinger (1925-26), physicists usually go forward as follows.
(1) Consider the lattice vibration as an infinite-dimensional system of harmonic oscillators.
(2) Decompose the system into independent simple harmonic oscillators, and calculate the distribution of vibration frequencies.
(3) Apply statistical mechanics to determine the macroscopic equilibrium state (the Gibbs state) of the quantized lattice vibration, and compute the internal energy U = U(T) (per unit cell) where T is the absolute temperature.
Then the specific heat is given by
C(T) =∂U/∂T
The surface relaxation effect and the local clamping effect are shown to be responsible for the specific heat of a small particle.
What you might refer to, and there you´re right it's about the amplitude of lattice vibration as a function of the temperature which is also calculated by the Debye model of a solid (Thermal Lattice Vibration).
For example, the wafer temperature during ion implantation is normally below 400 K, the lattice vibrations can influence the trajectories of the implanted ions. Especially the probability for scattering an ion out of a channel (de-channeling) is increased by increasing the wafer temperature. Due to the fact that the knowledge of the atomic lattice behavior is required for the simulation it is necessary to apply a temperature dependent lattice vibration model.
Luis German
luisgerman is offline
Old 4th February 2007, 08:59 PM   #20
elMickotanko:
Acute observation...
...What you might refer to, and there you´re right
Sorry, I paraphrased a bit. Put my on 'spin' on it hehe. I kind of understand some of it, but a lot of it is over my head because i dont have much knowledge of quantum mechanics/physics. I had a couple of classes on semiconductor devices which was really interesting but its hard to get my head around it all (and they were simplified to fit a broad branch of physics into a 1 semester class for engineers)! I understand that energy cant be created or destroyed so fair enough when two particles collide some energy is given of as heat.
I just meant that my understanding was that the lattice vibrations are caused by thermal energy (heat).
My Space
Old 5th February 2007, 02:19 AM   #21
Sorry, I paraphrased a bit. Put my on 'spin' on it hehe. .
That´s quite all right elMickotanko
Note to the forum users: please excuse me if I´m extending this topic to a feasible not adequate stage, but it´s just for the sake of responsibilty with the inquiry which I believe demands a response.
The statement is from a geometric standpoint; more specifically lattice vibrations in crystalline solids, from a geometric view point, in particular concerned with a mathematically sound computation of the specific heat, a typical thermodynamic quantity in solid state physics.
Maybe a distinction between heat and temperature must be recalled:
In physics, heat, is defined as energy in transit. Generally, heat is a form of energy transfer associated with the different motions of atoms, molecules and other particles that comprise matter when it is hot and when it is cold.
Heat is the transfer of energy caused by the temperature difference.
The temperature of a system is related to the average energy of microscopic motions in the system. For a solid, these microscopic motions are principally the vibrations of the constituent atoms about their sites in the solid.
Temperature increases as the energy of this motion increases. The motion may be the translational motion of the particle, or the internal energy of the particle due to molecular vibration or the excitation of an electron energy level.
Think of an isolated model:
Regardless of the temperature(except for the "theoretical" 0 Kelvin),lattice vibrations <A periodic oscillation of the atoms in a crystal lattice about their equilibrium positions> occur
Solely,the inter-atomic forces allow the vibrations of atoms which involve small excursions from the equilibrium positions.
There are two components to thermal energy. One component is the internal potential energy of the system - the energy the system contains at any moment due to the relative placement within the system of all its constituent parts. The second component is the internal kinetic energy of the system - the energy the system contains at any moment due to the relative motion within the system of all its constituent parts.
So there´s always a particular potential and kinetic energy associated with it, for any given temperature (not 0 K)
In physics, a phonon is a quantized mode of vibration occurring in a rigid crystal lattice, such as the atomic lattice of a solid
Phonons play a major role in many of the physical properties of solids, including a material's thermal and electrical conductivities
A crystal lattice at zero temperature lies in its ground state, and contains no phonons. According to thermodynamics, when the lattice is held at a non-zero temperature its energy is not constant, but fluctuates randomly about some mean value. These energy fluctuations are caused by random lattice vibrations, which can be viewed as a gas of phonons. (Note: the random motion of the atoms in the lattice is what we usually think of as heat.) Because these phonons are generated by the temperature of the lattice, they are sometimes referred to as thermal phonons.
In insulating solids, phonons are also the primary mechanism by which heat conduction takes place.
In a regular lattice with harmonic forces between atoms, the normal modes of vibrations are lattice waves.
Luis German
Old 6th March 2007, 05:44 AM   #22
Let m be a total number of current carriers (eg electrons)
then m = nAL where n=number of carriers per unit volume, A=cross sectional area of the conductor and L=length of the conductor.
thus the total charge in the conductor Q = nALe where e=1.602E-19(elementary charge)
Vd(Drift velocity) = L/t and i=Q/t
Solving these equations leads to Vd = i/(nAe) = J/ne (J=current density)
Obviously this result only holds true for conductor with constant A and DC.
thushy is offline
Old 6th March 2007, 07:59 PM   #23
Mostly you don't design electronic circuits with the individual charges in mind. You don't plumb your home with any consideration for water molecules. Some (e.g. semiconductor, radio, microwave engineers) might need to consider fields and charge movement, but for the most part voltage and current changes in one part of a circuit change the circumstances of the whole and at roughly the speed of light. For all intents and purposes, instantly.
So it's not appropriate to lump physics and electronic design/analysis together. They are separate disciplines with some overlap.
For newcomers to electronic design, my opinion is that it doesn't help to understand charge flows in the majority of cases, because it conflicts with the application of principles like Ohm's and Kirchhoff's laws. Therefore I discourage it.
Ohm's law and Kirchhoff's laws are all applied holistically. One doesn't think "current flows in here, get's "modified" somehow, and flows out, then it goes through here, but over there current hasn't yet reached", and so on. The whole "charge movement" scenario only encourages that kind of thinking, which can't help the beginner.
I believe it is best to only consider charge movements and speed of propagation only after the fragile and rocky initial stages of learning circuit design and analysis is complete. If you must learn both, they are best treated as separate disciplines, and not combined - yet.
Cabwood is offline
Old 7th March 2007, 03:33 AM   #24
Actually the distinction here is instructive. When you turn the tap on, your flow rate doesn't depend on the drift velocity. But if you're waiting for hot water, it's something you need to know.
mneary is offline
Old 7th March 2007, 11:52 AM   #25
That's a wonderful analogy - waiting for hot water. May I use it?
Cabwood is offline
Old 7th March 2007, 12:40 PM   #26
hi cabwood,
Not wishing to pull the 'plug' on this water analogy.
When I started this thread running, it was to dispel the notion that the individual electrons forming an electric current in a conductor, travel at the speed of light thru the conductor.
Looking back thru the postings, some members, thought this to be so.
We all take for granted the electrical effect, as far as we are concerned, is instantaneous.
My tutor, way back, explained the reason for a conductor having resistance, is due to the 'impeded' movement thru conductor of individual electrons.
This also makes the student aware of one the reasons conductors can get hot if carrying current.
I agree 'early' on in a 'electronic' students learning curve, he/she should learn and understand the fundamentals.
Regards
Eric
ericgibbs is offline
Old 7th March 2007, 05:22 PM   #27
It sounded brilliant to me at the time, but now I see the analogy is flawed.
Perhaps the fact that water comes out immediately could be more analogous.
Feel free to correct it and use it. :-)
mneary is offline
Old 7th March 2007, 11:02 PM   #28
The simple way too look at the speed of transfer of electrons in a medium, and easy to understand is:
You have a horizontal pipe fully loaded with marbles, which are all touching each other, you put in one extra marble on one side, an other marble gets pushed out immidiately at the other side, hence an instant transfer of information.
The speed is almost equal as the speed of light 300,000 km/sec.
In case the marbles are not tightly packed you have a type of propagation delay which happens in certain timing circuits. One marble gets pushed in the pipe, next one bumps the next one and so on. The little spaces between the marbles cause small delays in the transfer of information and the marble at the end doesn't fall out immidiately.
And i have not lost my marbles yet, believe you me
Please don't sent me private messages, I will not answer them.
The questions asked can be discussed in the open forums.
http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
RODALCO is offline
Old 8th March 2007, 01:24 AM   #29
Originally Posted by Cabwood
..... You don't plumb your home with any consideration for water molecules......
Understanding the principles involved I think it´s the purpose of
this kind of threads
One might plumb a home without any consideration for water molecules, but an appropriate conceptual comprehension of the main principles involved is what makes the difference between a plumber and a hydraulics engineer
Luis German
Old 15th March 2007, 04:36 PM   #30
Speed of electrons in a wire: 1cm/s.
Keruskerfuerst is offline
electron, velocity
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
how to identify the layouts in a die seen 4rm electron microscope? monica_mit8 General Electronics Chat 3 19th January 2007 09:34 AM
Just the basic but not simple: Control velocity of DC motor. wonbinbk General Electronics Chat 1 1st May 2005 11:46 PM
controlling velocity zika1212 Micro Controllers 3 25th May 2004 10:49 PM
velocity and direction control lepton Robotics Chat 0 18th November 2003 01:00 PM
