Old 27th June 2009, 09:09 AM   #1
Default 5W voltage-controller LED Current Driver
Here is a voltage-controlled LED current driver for those who are not afraid to burn some POWER! Forget those wussy switching things trying to achieve, what?, 85% efficiency maybe? What a hassle.
This driver is for a one-LED project. The LED is a 5-Watt royal-blue Luxeon Star. It cost $40 a couple years ago but you can get good Chinese counterfeits on eBay now for about ten. This device is a classified as a Class 2 laser - "Do not look directly at The Star!"
What can you do with one LED? The range of output is so great, that this LED is operated in analog mode. A voltage between 1 and 10 VDC is applied to the input of the driver to get a proportional percentage of The Star's output.
A controller generates eight different waveforms which run continuously. Lines from a pseudo-random linear feedback shift register choose which waveform is selected by the 4051 analog switch.
The current waveforms are shown, but their schematics are not revealed - yet. Only a hint - the waveforms are all generated using only 555 timers, 324 op-amps, or 3900 Norton amplifiers. I would like to see some good guesses as to how these waveforms may have been generated. If the results are worthy, I will post the solutions that were actually built and used to animate The Star of Captain Brock's BlueLight Box.
5W voltage-controller LED Current Driver-current-driver.jpg   5W voltage-controller LED Current Driver-star-current-waveforms.jpg   5W voltage-controller LED Current Driver-bluelight-star.jpg
JBrock is offline
Old 8th August 2009, 11:41 PM   #2
It looks to me like they were generated by the pencil and paper method. No need for a circuit then.You can make it anything you like.
What is the purpose of this device ?
Could I use it to warn incoming cars that I have cattle on the road ahead?
Could I drive say six of them to do the same?
What would you like me to guess at in a little more detail if you will?
My Property and my Family are not for Govenments to control.That is not the purpose of Governments.
To stop corruption in Government officials give them three times the penalty. They should, and do, know better. Let them commit to that when first employed
tytower is offline
Old 9th August 2009, 04:45 PM   #3
You can build an 85% efficient SMPs with the same amount of parts.
if I know the answer.
Hero999 is offline
Old 10th August 2009, 08:59 AM   #4
The circuit is built and tested, as shown in the third picture, and as required by the rules of this forum!
The purpose is to control current through the massive 5-Watt royal blue Luxeon Star LED in linear mode in response to the voltage waveforms. (Read original post again.)
No. Get a MagLite with an LED upgrade.
At 5 amp collector current rating, the TIP31 would be marginal. Get a nice beefy TIP3055 in a TO-247 case. The transistor is also operating in linear mode. But behold The Star! There is no need!
As stated, How might one generate the eight voltage control patterns graphed on page 2? I used 14 IC's to come up with all eight waveforms even though many share the same oscillators. Surely someone can do better. (No fair using microcontrollers!)
That is interesting. This controller can go from a few milliamps to 750mA. Does your switchmode have that kind of range? Remember, this is a voltage-controlled CURRENT regulator. Please share. I could be convinced.
JBrock is offline
Old 10th August 2009, 12:15 PM   #5
It's pretty simple, all you need is a comparator and a transistor (or a couple of transistors at most).
Read the following threads.
High Power LED Controller
LED Switching Regulator
Hero999 is offline
Old 12th August 2009, 11:14 AM   #6
Just following on
[QUOTE=JBrock;776220]The circuit is built and tested, as shown in the third picture, and as required by the rules of this forum!
Yes sir Mr Brock. I think I have it now . I did not follow your meaning before.
In fact I have a need for something bright and flashing in the daylight to alert traffic . I have settled on very bright LEDs ,18 of them. This Maglite and upgrade LEDs though sound interesting .Perhaps you might elaborate ,by PM if you wish to preserve your thread
Well this one is beyond my ability outright. I would use a waveform generator but I think you have them built up on the board and running in a random pattern . The decaying pulse though would be a capacitor discharging I suppose . Square wave and pulse might be a couple of 555s output . Ive not really ever studied the others so I would have to leave it there. I'll watch with interest
Thanks anyway for posting .I didn't doubt you had built it , but I would like to see a video of what it does ?
tytower is offline
Old 12th August 2009, 08:14 PM   #7
Default Check Out MAX16823 and Others
Ty, your application is so simple, all you need is a 555 timer and go with current-limiting resistors. (Ya, Hero will scorn that.) I would like to know your LED selection. You probably want red or yellow. There are some monsters available now, up to 12 watts. You will need to have a heatsink.
The point of my circuit is to run across the entire range of current from nearly zero up to ~700mA, controlled in response to an analog voltage. The star already becomes very bright at a few milliamps.
Here's a great blog on driving LEDs:
Constant-Current LED String Driver
Check out the milled circuit board!
JBrock is offline
Old 12th August 2009, 11:03 PM   #8
Did you check out the threads I linked to?
A PWM 555 can also be configured as an unregulated SMPS, simply by adding an inductor, a Schottky diode and a power MOSFET.
I'll post a spreadsheet which calculates the component values if you're interested.
Hero999 is offline
Old 13th August 2009, 06:32 PM   #9
Default Pwm?
Hero, I am intrigued... Since the project is completed, I don't plan on making any changes, but I am theoretically interested in the idea.
What frequency are you suggesting for the PWM?
How linear would the response be for this circuit?
What is the control range? For the BlueLight Star application it would need to go from 6mA to 750mA. That is greater than 100:1.
How much current ripple could be expected through the LED? (Probably not an issue at switching frequency.)
What is the response time? (Only need about 1ms or less.)
Yes, I did read the references. Many of these circuits are not intended for voltage-controlled response. It would be easy to convert voltage to PWM to use your idea.
Thanks for the input. Nice to meet a switching guy! -Brock
JBrock is offline
Old 13th August 2009, 07:29 PM   #10
The frequency will depend on the inductor size and ripple current. Higher frequencies will give less ripple but higher switched losses and larger inductors will reduce the ripple but are larger more lossy and expensive.
The circuit I previously posted won't be perfect, as it's unregulated.
Some of the circuits discussed in the other threads are more linear.
Anyway, even if the controller were perfectly linear, I'm not convinced that the over all device would be because LEDs certainly aren't linear. The voltage drop increase with current so the power consumption and power output won't have a linear relationship to the current.
The circuit previously posted can be controlled from 0mA to full power.
It's a trade off between inductor size and switching frequency, see above.
Ripple current isn't a problem with LEDs, providing the switching frequency is over about 500Hz.
That depends on the switching frequency.
Many of them can easily be voltage controlled.
Here's an example:
Just vary the value of Vref to alter the current.
Vref can be a voltage reference, such as a zener, with a potential divider in the output.
Hero999 is offline
led, luxeon, star
Constant Current Driver??? retic Electronic Projects Design/Ideas/Reviews 6 29th January 2009 08:43 PM
Request for Experience (Current Pulse FET driver) mdwebster Electronic Projects Design/Ideas/Reviews 4 23rd April 2008 01:15 AM
Driver- Temp vs Volt Vs Current Sense dknguyen General Electronics Chat 15 25th November 2007 06:30 PM
current Driver Pao Electronic Projects Design/Ideas/Reviews 7 25th September 2006 04:38 PM
Suppliers for USB/Serial Stepper Motor Controller+Driver? Alterscape General Electronics Chat 6 22nd January 2005 08:03 PM
