Old 20th February 2009, 03:10 AM   #1
Default Dancing fountain
I have completed a fun project that shoots "pulses" of water around a pond inside a greenhouse. The water pulses jump from one spot to another, there are 12 solenoids connected to a micro controller. The circuit is simple,the micro controller turns on a 2N2222 transistor, the transistor drives a 5 volt relay and the relay turns on the solenoid. Times 12.
I put a motion sensor on the unit so it only operates when someone is around to see it. I programed a Basic Stamp micro controller to run 5 separate valve sequences in a random order.
Here is a link to a video I shot just after installation. If you look close you can see my assistants leg triggering the motion sensor.YouTube - Dancing water feature
Enjoy
Mike2545
Mike2545 is offline
Old 17th April 2009, 04:56 AM   #2
Thats really Cool!!
Sockles is offline
Old 19th April 2009, 04:59 PM   #3
Interesting application mike, nice construction. A good example for a basic stamp.
Do the selonids feed city water or recirculated pond water ?
If you are using city water (or well) you could add a water level sensor and use the setup to keep the water level up.
I like it.
3v0
BCHS/3v0's Tutorials
3v0 is offline
Old 19th April 2009, 05:30 PM   #4
3v0,
The solenoids feed city water at about 50 psi. I was worried about recirculating the pond water, for fear it would gunk up the valves.
It does help fill the pond, which we did have to do weekly.
I did have to add a water hammer arrester, basically a tank with an air bladder, to absorb the shock of when the solenoids turn off.
Mike2545
Mike2545 is offline
Old 19th June 2009, 07:59 PM   #5
Default Valves and jets
What size/type/model of solenoid valve did you use? Also, what did you use for the jet/nozzle?
zakrzep is offline
Old 23rd June 2009, 04:20 PM   #6
What type of motion detector? How was it connected?
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 24th June 2009, 04:07 PM   #7
I picked up some solenoids from e-bay, they are 24vdc and have 1/4" threaded connections. Most solenoids will handle air or water, check the manufacutrer specs to be sure. The Nozzle is just a piece of 1/4" copper tubing.
Mike2545
Mike2545 is offline
Old 24th June 2009, 04:09 PM   #8
I used this PIR Sensor
There is plenty of documentation on their website.
Mike2545
Mike2545 is offline
Old 24th June 2009, 04:30 PM   #9
Very cool! I've wanted to explore this ever since seeing something like this in Vegas Nicely done!!
Michael Shimniok
http://bot-thoughts.blogspot.com/
Microcontrollers can solve world hunger, too!
shimniok is offline
Old 24th June 2009, 06:06 PM   #10
They have something like this in Vagas?
Mike2545
Mike2545 is offline
Old 24th June 2009, 06:43 PM   #11
Well, besides the Bellagio --- I was thinking of an interior garden/ponds with jumping water features... I *think* it was the Wynn... ??
Michael Shimniok
shimniok is offline
Old 25th June 2009, 06:16 PM   #12
Thanks for the complement
Mike2545
Mike2545 is offline
dancing, fountain
Dancing lights asorensen General Electronics Chat 13 26th January 2009 05:16 PM
time fountain circuit help steev General Electronics Chat 0 4th January 2008 06:35 PM
Fogger/Fountain HarveyH42 General Electronics Chat 12 15th April 2007 01:36 PM
i need information about Dancing lights 6 LEDs 9volt sachinpol_85 General Electronics Chat 1 12th February 2007 03:55 PM
Sound Activated LED dancing light sunny12558 Electronic Projects Design/Ideas/Reviews 0 22nd March 2004 12:11 PM
