Old 2nd June 2009, 11:00 PM   #16
Originally Posted by Pommie View Post
I don't like any scheme that involves analogue voltages or timed RC solutions as it really messes up the simple debounce and 2 key rollover code.
Only the 3rd cct fits into that category.
However, the third diagram is interesting. Can you explain how you read this matrix?
pressing a switch connect 2 unique resistors in series to a cap. The IO pin can time the charge/discharge rate of the cap by switching between output (to provide current) & input (to monitor voltage). There's a function in Proton+ picbasic called 'pot' (I think) that will do this for you.
If you wanted to make the code easier, in addition to allowing a simple wake up on key press, an IO pin would also be connected directly to the capacitor.
dougy83 is offline
Old 3rd June 2009, 07:09 AM   #17
I was looking at the page in portrait layout and so I was counting the first (left) as the third (bottom). Now I've turned it around the one that's interesting is the first one. That diagram will work without using the internal pullups and so solves the lack of pullups on the newer pic chips. I may have a play with this tomorrow just to make sure it works as I envisage. Assuming it does a programmable combination lock with one of the 8 pin pic chips should be doable.
Will you be watching "State of Origin" tonight?
Pommie is online now
Old 3rd June 2009, 07:45 AM   #18
Nah, sounds too much like sport
dougy83 is offline
autorepeat, key, keypad, rollover, rs232
Lizard PIC16F628A LCD, 4x4 keypad, relay, buzzer RS232 William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 0 13th October 2006 05:19 PM
keypad help... jrz126 Micro Controllers 6 9th November 2005 12:47 AM
keypad in a RC car dukeoverl General Electronics Chat 1 14th December 2004 07:33 PM
rs232 to rs232 data logger with 1meg buffer -help needed ccaammaaccaazzii Electronic Projects Design/Ideas/Reviews 11 20th October 2004 10:43 PM
Keypad ? lil_sti Electronic Projects Design/Ideas/Reviews 2 6th March 2004 03:31 PM
